Old 23rd September 2009, 10:50   #31
Default spark apollo accelere..exchange with michelin or continental ?
Mine is a new spark which has done about 700km.Now it has Apollo accelere
155/70/13.I would like to improve Braking.when i took it to highway,the Tyres seems to be noisy. so planning to change it. I am getting exchange offer for existing Apollo 4 tyres either to Michelin 155/70/13 ( 5200 for 4 tyre exchange) or Continental 155/70/13 ( 4000 for 4 tyre exchange). Exchange rates inclusive of balance/alignment.
MY question.which Tyre would be better for getting improved braking ,Good FE, Ride comfort ,wet Grip, decent cornering as i dont take TURNS at high speed and psbl no or less noise.
Option 2- should i go for next up size 165 with Michelin or continental?
Thanks in advance.
shapath is offline   Reply With Quote
Old 25th September 2009, 00:11   #32
djay99's Avatar
Thanked: 491 Times
Shapath,
I would suggest you to upgrade your tires to 165/65-13 as this will give you good grip compared to stock tires and ride quality will be same as stock tires. A little drop in mileage is for sure. Your braking will definitely improve and you can put your car in corner at speeds of 100.
I suggest Michelin XM1+ any day compared to continental.
djay99 is offline   Reply With Quote
Old 25th September 2009, 08:52   #33
THANKS DJAY for the reply. what WAS your FE of your spark before 1st service and what is it now. Reg 165 upsize - over existing 155 - i see the 10mm diff, not much diff with sidewall /radius too and Diameter Difference: 0.47%. you say "A little drop in mileage is for sure". psbl can you enumerate this point.
I still see MRF ZVTS 155/70 R13 Tubeless in your spark gallery. any reason on sticking to the factory fitted . Thanks
Originally Posted by djay99 View Post
Shapath,
Old 6th November 2009, 15:48   #34
djay99's Avatar
Thanked: 491 Times
Shapath,
Current FE is around 17-18 KMPL on highways and around 13 in city.
Since the width of tyre has increased, traction will increase and a little drop in mileage is acceptable.
I have not upgraded MRF tyres because i gave car to my parents who are residing in other city. They drive 200KM per month. Hence tyre upgrade was ruled out and i bought a Getz CRDi.
Also MRF tyres are best suited where roads are not good.
Old 12th November 2009, 16:05   #35
Default Driving with Apollo accelere on 'rainy' highway
spark which has done about 2400km, has factory fitted Apollo accelere 155/70/13.
While driving on the highway (which had about 2-4 inches of water) @ about 70 -90km/hr the vehicle showed swaying tendency due to tyre and road grip is not effective so one has to naturally slow down. is it because of Apollo accelere's inherent tendency OR because of the 70km speed . Will this 'sway' and 'lack of grip' would get avoided by switching to Michelin 155/70/13- which i understand would improve braking as well as cornering. looking for suggestion and opinion on this . TIA.
Old 12th November 2009, 16:11   #36
nitrous's Avatar
Thanked: 285 Times
Its the 70km speed on 2-4 inches of water.
Old 12th November 2009, 22:41   #37
Thanks nitrous for the quick reply. does it (also) mean that even MICHELIN wont have small amount of advantage in that situation. what about upsize to say 165-65-13.My priority is to have improved braking (as spark braking is not that much instantaneously effective even in 40-50km) and at least enhanced road grip in that kind of 2-4 inches of water.
Old 12th November 2009, 23:06   #38
Nikhilb2008's Avatar
Thanked: 6,652 Times
Dont bother. Any tyre will aquaplane at speed and in that depth of water.
The Aceleres are good tyres. YOu will be throwing away money by getting Michelins or whatever.
Old 16th August 2010, 21:07   #39
kkg
kkg's Avatar
Thanked: 75 Times
Hi everyone,
My spark has done around 42000kms on stock MRF ( 155/70) tyres. I am planning to change the tyres soon. I already have 5 j Neo alloy wheels. I want to for Michelin 165/65 XM 1. Now my question is:-
1. Is this upgrade is needed at first place.I mean would it really provide any significant advantage over stock 155/70 profile?
2. In case i go for it, would the increased width at the front may touch anything (panel, body etc) while turning?
3. What is the approx. cost of these Michelins?
4. Has anybody done the tyre upgrade for Spark, If yes, share your inputs please.
My priorities are good handling on the highways and minimum noise ( on both these counts, MRF sucks).
kkg is offline   Reply With Quote
Old 25th August 2010, 12:22   #40
VeluM's Avatar
Thanked: 757 Times
A colleague has recently fitted Michelin XM1+ on his spark - stock size, I believe. He's very happy with the ride quality and reduced road noise. It came to approximately 2700 per tyre, here in Bangalore. Might want to check that. XM1+ has pretty decent grip too, and you could check about 165/65/13 (which wouldn't cause any problems with the wheel well).
VeluM is online now   Reply With Quote
Old 2nd September 2010, 15:22   #41
djay99's Avatar
Thanked: 491 Times
@KKG,
1] Upgrade is needed if you want more grip and stopping power.
2] If you go with 165/65-13, tyres wont touch any portion of body. Its safe upgrade.
3] Others can share info.
4] One of my friend has changed tyres to 165/65-13. I think he bought apollo tyres in that size. He is happy with upgrade.
Old 2nd September 2010, 15:37   #42
kkg
kkg's Avatar
Thanked: 75 Times
Thanks djay99
I am planning for the upgrade next month. More grip and stopping power is always welcome.
The only thing i am skeptical about is tyres touching the wheel wells since my car goes on long trips frequently and that too fully loaded. I have noticed that tyres go way into the wheel arches.
BTW i got a quote of Rs 3100 per tyre for XM1+ with samsung mobile phone free with four tyres.
Old 3rd September 2010, 18:17   #43
Thanked: 71 Times
Just yesterday i changed all tyres of my Spark. My current running is 45600 KM. I have chosen Continental CEC tyres with upgrade to 165/65 R 13. Each costed Rs. 2900.
I have not attempted any high speed or cornering. But some sharp U turns created no problems. In fact, I have feeling that steering is sharper than before. One major advantage is tyre noise is much less compared to stock Apollo Accelere.
radek is offline   Reply With Quote
Old 5th September 2010, 13:55   #44
djay99's Avatar
Thanked: 491 Times
@KKG,
I feel 3100 for 165/65-13 is on a higher side for michelins.
You can also consider Yoko A-drives. They are good and are comparable with michelins. They are cheaper too.
Old 5th September 2010, 14:56   #45
Thanked: 71 Times
I also got the same quote 3100 for Michelin. Comparatively, Conti with same quality are available for 2900. I was bit confused about Yoko as some say it has lot of noise.
Hyundai Grand i10 & Xcent : Tyre & wheel upgrade thread jkdas Tyre & Alloy wheel Section 18 8th July 2018 21:32
Chevy Beat : Tyre & wheel upgrade thread slayer87 Tyre & Alloy wheel Section 168 20th March 2017 19:11
Chevy Cruze : Tyre & wheel upgrade thread deepakvrao Tyre & Alloy wheel Section 131 18th August 2016 23:16
Chevy Optra : Tyre & wheel upgrade thread throttleking Tyre & Alloy wheel Section 33 4th December 2014 18:03
