Tyre & Alloy wheel Section Everything to do with footwear for your car!
Thread Tools
Old 11th February 2008, 15:18   #16 (permalink)
rks
rks's Avatar
Originally Posted by Technocrat View Post
rks: I don't agree with the statement that low pressure causes tire burst but a higher tire pressure will certainly cause a burst if its too high
As tsk1979 pointed out, low tyre pressures are the culprit.
As for excessive pressures causing tyre bursts, the question is how much is too much. I met a Michelin tyre dealer who swore that tubeless Michelin XM1 tyres will only burst if pressure exceeds 300 psi, even though they may have 44 psi marked on them as max. pressure. There is usually substantial over-design for obvious reasons and it is a myth that tyres will burst due to high pressure at the kind of pressures we run. Howerver, it is not advisable to run too high tyre pressures for other reasons: bad ride and poor braking handling on bad/wet roads, possibility of impact damage on stones/kerbs, uneven tyre wear, etc.
Secondly, tubes in tubed tyres may fail at lower pressures, though I suspect not anywhere close to 35-40 psi (I know this because one road side puncture repair guy inflated by spare tubed S322 tyre to 60 psi, and I didn't notice that for about a week).
Old 11th February 2008, 15:54   #17 (permalink)
deep_bang's Avatar
The very reason of going for tubeless tyres is so that the air leaks slowly in case of a impact and that the tyre does not burst immediately. Looks like that has not happenned here. Impact from the road can be in various shapes and even at 35kmph, a pothole is enough to cause a rim bend if pressures are low. Once the rim is bent, it obviously causes more airloss.
I would suggest (like others in this thread) to keep a watch on the tyre pressures (buy a guage if possible) and fill up when the tyre is cold. Also do fill up a PSI more so that helps in preventing rim bends (will also make the ride harsher - but lets first get to the root of the problem).
Is it one particular wheel that is getting bent every time? May be the rim-bend was not removed properly due to which there is airloss. Everything points to first monitoring the pressures (preferably cold tyre pressures) and ruling them out as the cause.
deep_bang is offline   Reply With Quote
Old 11th February 2008, 16:24   #18 (permalink)
Originally Posted by finneyp View Post
I think the stock tyres are the culprit, change over to Michelins asap!
Can this be done under warranty?
just curious to know, may be he can reduce the costs incurred.
raj.
__________________
kkr, unofficial hyd tbhp meet co-ordinator
....HINDUISM
........JAINISM
.......BUDDHISM
......SIKHISM
........ISLAM
CHIRSTIANITY
kkr2k2 is offline   Reply With Quote
Old 11th February 2008, 16:34   #19 (permalink)
finneyp's Avatar
raj.
Not sure if tyres come under warranty, but even if it does, they'll replace it with those crappy Bridgestone tyres, better to shell out some bucks & get a Michelin XM1 or something.
__________________
Drive Safe, your loved ones need you!!!
My Passion is not driving Cars, but driving a FIAT!
Finney, Bangalore
Palio 1.2 NV - 2004
finneyp is offline   Reply With Quote
Old 11th February 2008, 16:41   #20 (permalink)
ram_hyundai's Avatar
tyres do come with waranty of one year.you can easily get them replaced.but the question is are they the culprit.maybe the first puncture was a genuine one and then after the rims got bend maybe that has something to do with the subsequent ones.please check it with the spare rim.
ram
__________________
Become MAD SOON and join the MON SOON Drive.
one more from me-
hey MAN come SOON for the MONSOON drive
ram_hyundai is offline   Reply With Quote
Old 11th February 2008, 16:46   #21 (permalink)
ram
Then i guess the rims should also be changed under warranty. isnt it?
__________________
....HINDUISM
........JAINISM
.......BUDDHISM
......SIKHISM
........ISLAM
CHIRSTIANITY
Old 11th February 2008, 16:46   #22 (permalink)
Team-BHP Moderator
Technocrat's Avatar
I agree with Tanveer & Alfa Kilo but I doubt anyone who fills up regularly will have such a low pressure to have the tires burst specially in city driving condition. & anyone going on highway should ensure that the air pressure is just right.
__________________
180, 225, 150, ??? -> 159?
Old 11th February 2008, 18:35   #23 (permalink)
Since at low pressure, the tyre side wall flex more. At high speed the rate of flexibity is so high the heat generated will get accumalted and can cause tyre burst.
Hence the reco. for higher pressure before highspeed long drive.
regards,
-manju
manjubp is offline   Reply With Quote
Old 11th February 2008, 18:52   #24 (permalink)
vid6639's Avatar
Does your i10 have Bridgestone B250 or MRF ZEC..?
Kp, you think the bead shape has anything to do with this. I remember the i10 had 4B or 4.5B and not the standard J shape.
A tyre burst as in the tyre coming of the rim or getting a hole?
__________________
\ / ][ |) `/ [_] "!"
(o.o)
( X )
This is Bunny. Copy Bunny into your signature to help him achieve world domination.
vid6639 is offline   Reply With Quote
Old 12th February 2008, 14:32   #25 (permalink)
I too believe there is something with the shape. Otherwise, there is no apparent reason for it to happen this way.
__________________
TP
You live only Once!
talkingpebbles is offline   Reply With Quote
Old 12th February 2008, 14:50   #26 (permalink)
kpzen's Avatar
Vid
I'm not sure about it but i have heard some tire burst accidents in i10 with B250 which made hyundai to add MRFs also for their i10s.
I have driven i10 with both B250 and ZEC. Both tyres were pretty good in my experience.
__________________
Prajesh - << will be mostly offline till August >>
A true friend is someone who says nice things behind your back...
kpzen is online now   Reply With Quote
Old 18th February 2008, 18:41   #27 (permalink)
sandeepmdas's Avatar
Learnt just a while ago that the front left wheel of an i10 has caught fire today noon in my home town, Varkala; it happened at the busiest junction of the town. No one is hurt in the incident.
No further (tech) details are available as of now; I will keep you guys posted.
__________________
Remember, you are unique like everybody else.
sandeepmdas is offline   Reply With Quote
Old 18th February 2008, 21:06   #28 (permalink)
hi
i seriously think u should talk to ur dealer and caN ALSO talk to the authorised tyre companies for this defect other wise it will be difficult for ur BIL to drive for long.
fastcar is offline   Reply With Quote
Old 18th February 2008, 22:11   #29 (permalink)
rks
rks's Avatar
Possibly there is some flaw in the stock tyres/wheels. Or else we are seeing the difficulties associated with supplying tubeless tyres as stock. These do require more care and many people may not be sufficiently aware.
Old 18th February 2008, 22:55   #30 (permalink)
Team-BHP Moderator
tsk1979's Avatar
Tyres bursting at low speeds causing accidents, tires catching fire... I suspect foreign hand
__________________
Reclaiming.....!
Thread Tools
Frequent Punctures in Tubed Tyres muruganbs Tyre & Alloy wheel Section 14 6th February 2008 17:55
Query : Tubeless tires / Normal Tires nicejits Tyre & Alloy wheel Section 8 15th January 2008 01:56
Frequent short journeys are bad for car - yes or no? sbasak Technical Stuff 36 14th March 2007 17:24
Frequent Model Upgrades indian21r The Indian Car Scene!! 8 7th March 2007 19:33
A Disappointing 60th for Ferrari 1Day The International Automotive Scene 6 31st January 2007 19:09
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
