Tyre & Alloy wheel Section Everything to do with footwear for your car!
Thread Tools
Old 11th February 2008, 10:20   #1 (permalink)
Default I10 tires disappointing terribly! Frequent Bursts
hi Guys,
isnt that a surprise? I am surprised too. I picked up the I10 Magna for my brother in law in December. From then on, it had two major accidents and one minor because the tire getting burst for no apparent reason! I just cant believe it. First time when the accident took place in Kerala, I thought it was because of the lack of experience in driving of my brother in law. The car had a bad accident and the door and even the steering column had to be replaced. Car came back in January and in three days time it had the next accident due to tyre bursting just because it went over some small stones lying on the side of the road for road repair work. Again the car went for repair and service. It came back last friday and my in laws came to Bangalore on it. This morning while they took the car out to return to kerala, again the tyre got punctured for no apparent reason! Tubless tyre! I just cant believe it! Already in two months flat we have shelled out around 50K for repair work on a brand new car! Unbelievable! Any I10 users had similar experiences? would love to hear. thanks.
__________________
TP
You live only Once!
talkingpebbles is offline   Reply With Quote
Old 11th February 2008, 10:48   #2 (permalink)
rks
rks's Avatar
I assume you are on stock rims and tyres. I think the i10 comes with Bridgestone B250 tubeless tyres (155/80 R13). These are supposed to be good tyres. Make sure you set tyre pressures at or slightly above the recommended levels. If you are driving some distnace to bunk before setting the pressures, you can keep them 2 psi above recommended levels. And for high-speed driving over long distances, I would recommend setting them even higher. Tyre bursting normally happens due to low tyre pressures and this is what you need to attend to first. Bunk gauges are notoriously inaccurate and I suggest you use your own accurate gauge, if possible.
I personally set my tyre pressures at 35 psi (cold, first thing in the morning with my own accurate gauge), very high because of my weekly high-speed drives to Mumbai and back. I have never had any problems with my tubeless tyres (either S322 or Turanza ER-60). You also need to inspect your tyres frequently for any damage (sidewall bulge, flat spots) and also for any nails/screws stuck in. With tubeless tyres, you will not know about these without an inspection and once you find them, drive straight to the tyre shop without removing the nails/screws.
And make sure that the tubeless tyres are properly mounted to the rims. This has to be done by skilled tyre shop mechanics, do not leave it to authorized dealers or road-side shops. Check the condition of the rims also; do they have any bends or other damage? If so, get them repaired.
Other than this I would suggest you and your brother-in-law take care and initially, do not drive at high speeds till you are confident and experienced enough with the i10.
Old 11th February 2008, 10:48   #3 (permalink)
snaronikar's Avatar
. Did you claim insurance for this or not ? Atleast for Steering column, door etc?
As far as the tyre is concerned, what was the tyre pressure recommended and what did you fill in it? Can you give some data pls.
__________________
Love your job but Never love your company
because you never know when your company
stops loving you-NRN
snaronikar is offline   Reply With Quote
Old 11th February 2008, 11:13   #4 (permalink)
jkdas's Avatar
Originally Posted by rks View Post
I
Should be a tyre issue. Did the burst occur at same spot?
__________________
"She may not look like much, but she's got it where it counts, kid."
Old 11th February 2008, 11:27   #5 (permalink)
kpzen's Avatar
Does your i10 have Bridgestone B250 or MRF ZEC..?
__________________
Prajesh - << will be offline till August >>
A true friend is someone who says nice things behind your back...
Old 11th February 2008, 11:52   #6 (permalink)
hi folks, thanks for the questions.
1. I had filled the correct tyre pressure according to the manual. I dont remember exactly the number. I believe it was 32.
2. I10 has Bridgestone tyres.
the surprising fact was that in both the accidents the wheel rim got bent. So i do not think it was a tyre issue exactly. And I find no reason for the rim to get bent on both the accidents. first one was while climbing a slop at a speed of max.10kms/hr. second was on a straight good road at around 35 kms/hr.
__________________
TP
You live only Once!
Old 11th February 2008, 11:53   #7 (permalink)
And yes. we did claim the insurance. otherwise it would have been a disaster.
__________________
TP
You live only Once!
Old 11th February 2008, 12:34   #8 (permalink)
rks
rks's Avatar
If you don't remember the recommended tyre pressures, that means you are either relying on the bunk attendants or you are not checking your tyre pressures frequently enough. Especially since you may have rim bends, I would suggest you keep a close watch on your tyre pressues, say, at least once a week initially, apart from daily visual inspections. Quite possible that you may be setting tyre pressures correctly, but the tyre(s) may be losing air due to various reasons (valve leaks are one possibility).
At those speeds you (or whoever the driver was) should not have had any accidents, tyre burst or no tyre burst.
Normally rims will get bent if you hit potholes or stones/kerbs at some speed. But I suspect in this case your rim(s) may have gotten bent because you tyre(s) went flat and you may have run flat for some distance. In that case, I strongly suggest that:
(a) get your rims straightened out at a well-equipped tyre shop (there are machines for this purpose). If damage is severe, replace the rim(s).
(b) Get your tyres inspected very carefully before using them again. If they have run flat, there is a good possiblity that you have damaged your tyres. If necessary replace tyres.
(c) Never ever let your tyre pressures drop substantially; inspect your wheels/tyres and check tyre pressures frequently.
Old 11th February 2008, 13:14   #9 (permalink)
Thank you very much for the suggestions.
Regarding me not remembering the tyre pressure, I do not use the car myself. Its my brother in law who uses it. However, I had kept a close watch on the car and the way it is handled in the initial days when it had the first two accidents. And I was very particular about the tire pressure because I do keep checking my tyre pressure in my Fiesta every time I am at a bunk. I am very sure the tyre pressures were right. However, I will ask him to keep a watch on the tyre pressure. And remember, the car never ran continuously for a full week without an accident. First accident took place within the first week of the car being brought. It went for repair and came back in about 3 weeks and within the next one week the next accident took place. It came back on last friday and today the tyre goes flat again! I am clueless!
__________________
TP
You live only Once!
Old 11th February 2008, 13:33   #10 (permalink)
OT:
Sorry for going off topic...but @rks got me really worried.
I generally set the tyre pressure on my esteem to 30psi(even for long distance high speed(say arnd 90kmph) drives).
Do i need to change this practice?or its ok.
__________________
Mohit
Finally...Esteem VXI.
amohit is offline   Reply With Quote
Old 11th February 2008, 13:55   #11 (permalink)
finneyp's Avatar
I think the stock tyres are the culprit, change over to Michelins asap!
__________________
Drive Safe, your loved ones need you!!!
My Passion is not driving Cars, but driving a FIAT!
Finney, Bangalore
Palio 1.2 NV - 2004
finneyp is online now   Reply With Quote
Old 11th February 2008, 14:21   #12 (permalink)
Team-BHP Moderator
Technocrat's Avatar
rks: I don't agree with the statement that low pressure causes tire burst but a higher tire pressure will certainly cause a burst if its too high
__________________
180, 225, 150, ??? -> 159?
Old 11th February 2008, 14:31   #13 (permalink)
benbsb29's Avatar
I believe in the same as well.
__________________
"Wise are they who invested in a diesel powered automobile" - Benny
Old 11th February 2008, 14:45   #14 (permalink)
Team-BHP Moderator
tsk1979's Avatar
If your manual says 30PSI, you should have 32PSI cold pressure if you are going to do high speeds.
Low tire pressure causes standing wave formation, which leads to tire burst.
But then 35kmph cannot cause standing wave even if tire pressure is low.
__________________
Old 11th February 2008, 15:12   #15 (permalink)
Alfa_Kilo's Avatar
Extended running at low pressure may cause delamination (different layers in the tyre carcas seperate due to high heat generation and internal shear forces) and tyre failure. It may feel like a tyre burst (ie sudden loss of pressure) to some drivers.
Alfa_Kilo is offline   Reply With Quote
Thread Tools
Frequent Punctures in Tubed Tyres muruganbs Tyre & Alloy wheel Section 14 6th February 2008 17:55
Query : Tubeless tires / Normal Tires nicejits Tyre & Alloy wheel Section 8 15th January 2008 01:56
Frequent short journeys are bad for car - yes or no? sbasak Technical Stuff 36 14th March 2007 17:24
Frequent Model Upgrades indian21r The Indian Car Scene!! 8 7th March 2007 19:33
A Disappointing 60th for Ferrari 1Day The International Automotive Scene 6 31st January 2007 19:09
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
