Old 13th February 2008, 14:31   #1
Ignazio's Avatar
Default ET / Offset value on Safari rims
Hi all,
I have a question to any of you that have alloy wheel on Safari.
I've been visiting this interesting website: Alloy Wheels,Car Alloy Wheels,Automotive Alloy Wheels,Chrome Alloy Wheels India and I notice that there is a really wide variety of alloy wheels for Safari on both size 15" and 16". All of that are indicated to be ET 0. Any of you can confirm this?
In italy we have almoust nobody producing something similar...
What are the prices of those rims?
Thanks for looking...
Ciao
Ignazio
Ignazio is offline   Reply With Quote
Old 14th March 2008, 14:10   #2
jkdas's Avatar
Thanked: 1,389 Times
Whats ET value?
Aura 16 inch cost 22K ; think for 4 piece.
Old 14th March 2008, 14:19   #3
simply_sunny001's Avatar
Thanked: 15 Times
Ignazio
you seem to be slightly mistaken here.The Alloys that i'm using in my safari are having the ET == 15
and i doubt any suitable rims in 16" with width ranging from 6.5j to 7J can have ET value == 0
they should have ET/offset value in range of 14-18
complete details of my alloys are as follows
PCD: 139.7-160
ET: 15-25
Hub Dia: 93.15-110.8
BH: 4,5,6
Color: Full Face Machined
hope that helps.
simply_sunny001 is offline   Reply With Quote
Old 14th March 2008, 22:31   #4
Rehaan's Avatar
Thanked: 22,586 Times
Whats ET value?
More commonly known to us as Offset.
Hi Ignazio,
You are wise not to trust that website!!
1. Even if those alloys are 0mm offset, there is no guarantee that they are anywhere near the suggested / stock offset of the Safari for that size.
2. Its quite possible that data wasnt available, so the site shows "0".
Originally Posted by simply_sunny001
ET: 15-25
I can understand how your alloys are multi-pcd and multi-bolt holes, but multi-offset ?? j/k
Im guessing you copied this from the brochure/site for that style? Any idea about your alloys offset specifically? and how close is it to the suggested offset?
Ignazio, you could always email a TATA service center / dealer to get the answer. However, there are still no guarantees that they will know what you are talking about or that they will give you the correct answer. (I had tried the same with Fiat a long time ago).
If you feel like a little project, (the correct way to do it would be to unmount the tyre, but you can adjust your calculations accordingly if you have the tyre still on the rim). I have done it this way and it is fairly accurate:
- Take your stock rim an put it on a flat tabletop, with it half off the table, front face of the wheel facing skyward.
- Take a scale/ruler and stick it inside the wheel from below, and measure the distance from the table top to the mounting face inside the wheel in mm.
- That is your offset (+/- a few mm in error -- which is tolerable, since atleast now you have the correct range.)
cya
R
Old 15th March 2008, 16:03   #5
Thanked: 15 Times
absolutely right Rehaan.
the main problem Ignazio had was regarding a 0 offset on a 16" safari rim.
thats something not logical.
so just to get him an idea of the range it should be i copied some data for him.
regarding the exact offset/ET value lets wait if our in house Tyre/Rim experts i.e. KP and Ishaan can throw some light
in the meanwhile lemme also try
Old 15th March 2008, 21:02   #6
Ignazio's Avatar
Hi all,
I think I need to explain a bit,
I do not need to know the exact ET value of my rims, I know it already
I have already rims with ET0 (zero), steel, just want to understand if aftermarket alloys that you can have in India are real ET0. Original rims are positive offset, rims with ET0 been centered wheel, allows you to have a wider car footprint wich helps if you are going offroad with high GC.
Nice anyway that we start this discussion!!!
Ciao ciaocheers:
Ignazio
Old 15th March 2008, 22:08   #7
kpzen's Avatar
Thanked: 1,598 Times
Ignazio.
Just out of curiosity, Can u please post some pics of ET0 rims...
Old 15th March 2008, 22:17   #8
Ignazio's Avatar
Hi
Ignazio.
Here it is a picture of one of the steel rim with ET0 ...
Ciao!cheers:
ET / Offset value on Safari rims-dscn0096.jpg
Old 23rd July 2008, 12:07   #9
Thanked: 384 Times
Default Ideal Offset value for Safari Alloy wheels
Hi ,
I have booked my Tata Safari 2.2 Lx and will get in a day or two. I am planning to put in alloy wheels , I searched through all the threads on Safari RIM sizes etc. Most of the alloys are available in 7.5 inch rim width.
The RIM dealer ( Sproket Koramangla Blore ) told me that they need to cut metal to fit in 7.5 width even if it is with stock tyres.
As per the research on the net I feel that metal cutting may not be required if the rim has +ve offset. Dealer had no idea about the offset part.
So I have following questions for the veterans here.
1. Is there any 16 inch RIM heaving 7 Inch or 6.5 inch width available ( apart from Aura) ?
2. Does any one have experience on 7.5 inch wide RIM with out cutting metal ( ofcourse with Stock Tyres) , What should be the offset of the RIM ?
3. Is fitting Stock Brigestone Dullers HT tubeless on 7.5 inch wide RIM advisable ?
As most of the Safari fans might be knowing now Safari Lx comes with Tubeless Tyres though the salesperson insist that Lx comes with tube tyres
Any recommendations on the knowledgeable dealers in Bangalore who do not insist on cutting the metal but know the product they are selling well.
Amit
amitk26 is offline   Reply With Quote
Old 25th July 2008, 15:22   #10
DerAlte's Avatar
Thanked: 2,876 Times
... The RIM dealer ( Sproket Koramangla Blore ) told me that they need to cut metal to fit in 7.5 width even if it is with stock tyres.
1. Is there any 16 inch RIM heaving 7 Inch or 6.5 inch width available (apart from Aura) ?
The issue is whether the rim width is small enough to hold the tyre inside edge on pressurization - larger the width, more the problem. Cutting metal would increase the problem.
Probably he was referring to modification of the Tailgate mounting to accommodate the positive offset of the alloys. That bracket is designed for steel rims.
Though a bit difficult to find, 6.5J or 7J alloys are available - you just have to keep asking around. Most shopkeepers assume that if you are changing rims you will change tyres also, hence they stock only the popular designs even if those are unsuitable for stock tyres. Try JC Road / Lalbagh Road - some of those guys ask around in their network to get you what you want, so that they can make a sale.
Sprocket, though convenient, is generally a costly source, and their knowledge is generally suspect, be it alloys or ICE. Last choice, and only if you know everything there is to know about what you want to buy.
Old 25th July 2008, 20:11   #11
Thanked: 1,503 Times
It is not really METAL cutting, but you will have to make some cuts on the plastics and perhaps the inner part of your wheelwell to accomodate 7.5.
I'm running 7 and I had to make some alterations, but none of them were major - 15 minute job.
7.5, in my opinion, is an overkill. my 7 inchers protrude out from my wheelwell just about tolerably (though I have a higher offset on account of a deep-ish dish).
Steeroid is offline   Reply With Quote
Old 31st August 2008, 15:18   #12
tsk1979's Avatar
Thanked: 15,645 Times
What is the TATA OEM safari Alloy?
Is it 6.5J 16" or 7J 16"?
Old 31st August 2008, 17:10   #13
trrk's Avatar
Thanked: 12 Times
> Is it 6.5J 16" or 7J 16"?[/quote]
TATA Motors - Safari DICOR
In the site the size is common for all variants and is 6.5J 16
trrk is offline   Reply With Quote
IDV value for a new car - Only 95% of ex-showroom value? kuttapan The Indian Car Scene 9 21st July 2009 15:27
The value for money SX4 now even more value for money-I map navigator free ram_hyundai The Indian Car Scene 20 23rd October 2008 11:23
Offset of Sera?? a4_attitude Tyre & Alloy wheel Section 3 18th April 2006 12:11
Optra Rims PCD and Offset help! iceman-kimi Modifications & Accessories 22 27th September 2005 20:49
