Tyre & Alloy wheel Section Everything to do with footwear for your car!
Thread Tools
Old 24th February 2008, 13:55   #1 (permalink)
Infractions: 0/1 (5)
Exclamation Elantra GLS replaced with 195/65 R15 - Any safety issues?
I recently changed my Elantra tyres to good year 195/65 R15 , the original tyre was 195/60 R15.
I was unware of this change and when i came back home i noticed this change, i immediately called the tyre dealer and enquired and he said there won't be any problem with this new 195/65 R15.
I am worried for my safety and safety of my family while driving with this non-standard tyre.
Please enlighten me if this will have any safety issues?
Mukesh
muke31 is offline   Reply With Quote
Old 25th February 2008, 02:46   #2 (permalink)
hellspawn's Avatar
the tire may foul with the wheel well on full lock or when 2 or more people are seated behind.
i would suggest you get the stock size.
__________________
Kenwood KDC-X8529,IPaul 4.300,Image Dynamics CTX65cs,IDQ15
If you try,and succeed at first,
try not to look astonished.
hellspawn is online now   Reply With Quote
Old 25th February 2008, 04:36   #3 (permalink)
zenopio's Avatar
dude their will be no problem other then wheels touching the body as hell spawn said and their might be some speedo error also
zenopio is offline   Reply With Quote
Old 25th February 2008, 04:47   #4 (permalink)
zenopio's Avatar
TYRESAVE: Tyre Size Calculator
Old 25th February 2008, 09:44   #5 (permalink)
I checked for the wheel touching the body with full load and i couldn't notice any sign of tyre scratching the body even while turning also..?
I am worried on how ABS and TCS funcitions?
will there be change in Fuel efficiency ? decrease or increase?
Old 25th February 2008, 13:00   #6 (permalink)
trrk's Avatar
The difference in circumference is 3.09%. That means if your odo shows you have run 100kms, the actual distance covered is 103.09 kms. So add 3% to the distance while calculating fuel efficiency and it should be fine. Otherwise it would show a decline.
__________________
Rajesh
-Marina LS, Oct 05, 44223 (44771) kms, 13.94 kpl
-City CVT, Sep 07, 15423 kms, 13.23 kpl
trrk is online now   Reply With Quote
Old 25th February 2008, 13:16   #7 (permalink)
WasavaTyres's Avatar
Infractions: 0/1 (4)
Apart from the odo error there would be no diffrence whatsoever in performance or safety for you car. And no,ABS & TCS will not be compromised on either.
__________________
Man made booze........
God made grass.........
Who do u trust ??
WasavaTyres is offline   Reply With Quote
Old 25th February 2008, 13:40   #8 (permalink)
Actually fuel efficiency will go down as rolling resistance in this case will higher as the profile is higher.
There will be impoved comfort but reduced handling and safety.
itzzme is offline   Reply With Quote
Old 27th February 2008, 12:21   #9 (permalink)
Exclamation
This is just for my knowledge. What makes you say that safety would be compromised ??
__________________
Who do u trust ??
Old 27th February 2008, 12:53   #10 (permalink)
power_slave77's Avatar
Which brand of tyres are these. The best thing to do is sell them to the dealer or to some person and fit the OE ones. You have increased the side wall height by 5 mm. It will give you better ride, but will surely spoil the handling of the car.
power_slave77 is offline   Reply With Quote
Old 27th February 2008, 13:08   #11 (permalink)
Sahil's Avatar
Your best bet is to seat 5 large sized people in the car and throw in some luggage into the boot. If the tyres dont scrape the wheel arches on speed breakers then your all set.
__________________
______________
__________
______
__
_
Old 27th February 2008, 13:57   #12 (permalink)
In the same width higher profile tyre, the tyre foot print is narrower, which leads to compromises on grip and braking..
Old 4th March 2008, 13:30   #13 (permalink)
dinu2506's Avatar
I don't believe the footprint would be narrower. It remains 195mm, the sidewall height will change, AFAIK
dinu2506 is offline   Reply With Quote
Old 4th March 2008, 13:53   #14 (permalink)
Wink
Ditto, by any stretch of imagination the footprint would remain at 195 mm regardless of it being a 60/65 profile tire. You're wrong there my friend
__________________
Who do u trust ??
Old 7th March 2008, 00:25   #15 (permalink)
Veelubai's Avatar
OT-Which brand are those tyres[195/65]
Veelubai is offline   Reply With Quote
Thread Tools
Replacing Tyres 195/60 R15 With 215/75 R15 in Ford Fusion singhisking Modifications & Accessories 13 11th December 2007 20:22
Price of Michelin MXV8 195/60 R15 in trivandrum or cochin jithudigitised Tyre & Alloy wheel Section 6 26th October 2007 23:17
Wanted Tubeless tyres:195/55/R15 in Bangalore greatDrive Shifting gears 1 17th September 2007 07:52
Apollo-Aceler or Goodyear-GT3 (195/60/R15) for Swift-Diesel kk28 Tyre & Alloy wheel Section 7 12th July 2007 22:17
ALMOST New 195/50/R15 for SALE manveet Shifting gears 2 15th December 2006 14:02
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
