Old 13th July 2008, 13:02   #16
iraghava's Avatar
Thanked: 156 Times
KP should be able to help you with the wheel info but he's a bit busy right now. I think he'll reply to your query pretty soon though.
Old 13th July 2008, 17:14   #17
Thanked: 32 Times
I suggest you buy Alloys too when you do Tyre upgrade. Fitting upgraded tyre on stock RIMS and if stock tyre was tubed type and upgraded tyre is tubeless is not advisible at all. Please make sure you make good plan and take a decision
Ravi.
ravibhat is offline   Reply With Quote
Old 13th July 2008, 17:55   #18
WasavaTyres's Avatar
Thanked: 255 Times
Karthik I don't know the numbers punched on the rims. But both are 14" 5.5 J 100 PCD wheels.
WasavaTyres is offline   Reply With Quote
Old 14th July 2008, 22:07   #19
aks_karthik's Avatar
Thanked: 232 Times
As per my knowledge GetZ Crdi has only 5J rims.
But Verna Crdi has 5.5J rims.
that is the problem.whether Verna Crdi 5.5J rims will fit in GetZ Crdi.
100 PCD,14 inches are same.But don't know about offset.
Please enlighten.
aks_karthik is offline   Reply With Quote
Old 18th July 2008, 20:34   #20
Thanked: 232 Times
Spoke with Hyundai Mechanic he told Verna rims is unable to fit in GetZ Crdi.
He didn't know about PCD or offset.
Please advice whether i can use Verna crdi sx abs 5.5J rims in GetZ Crdi and use 195/14/60 Michelin XM1+ tyres.
If have any known guys who is well versed in rims and tyres.Please ask him and reply me.
Old 18th July 2008, 20:35   #21
Thanked: 232 Times
whether GetZ Crdi also has 5.5J rims.r u sure.Please check and let me know .
Old 19th July 2008, 02:23   #22
viper_711's Avatar
Thanked: 55 Times
KArthik,
Have you checked the car manual for the wheel size? It should be mentioned there. Anyway, if it is a 5J wheel - a 195 upsize may not be feasible.
viper_711 is offline   Reply With Quote
Old 19th July 2008, 10:21   #23
Thanked: 232 Times
Originally Posted by viper_711 View Post
KArthik,
No car/Manual in the dealer's place.so unable to find the rim size
no way to check the rim size.
GetZ Crdi Proud Owners,Please reply whether your car stock rim size is 5 or 5.5J?
Old 19th July 2008, 10:56   #24
lohithrao's Avatar
Thanked: 163 Times
I would anyday for Bridgestone Turanza, have it on my OHC for more then a year have done about 15k kms....this tyre has seen worst of roads...mostly driven on hiway....FANSTASTIC !
lohithrao is offline   Reply With Quote
Help choose - Innova petrol or diesel? manishk13 SUVs, MUVs & 4x4s 67 10th May 2015 12:30
Hyundai owners help me choose a remote locking system... neverclever Modifications & Accessories 12 28th July 2008 20:51
Help me choose an alloy wheel design... mahi0375 Tyre & Alloy wheel Section 24 10th January 2008 00:48
Help me choose between Accent CRDi and Honda City GXi/VTEC vravish Sedans 15 22nd February 2006 01:04
Help Me choose between a Baleno & NHC shobhit15 Sedans 47 9th August 2005 09:40
