Old 3rd April 2008, 14:11   #1
vishnuvijay's Avatar
Default Tyre losing air pressure & fast!
one of my Kumho Ecsta AST KU25 tubeless trye is loosing air pressure very fast. i corrected the air pressure to 30 psi and 2 days later i found it to be 11 psi. filled in air again, the guy at the ioc pump said there is no leakage.
went on a trip (300 km (first day) + 300 km (second day) ) checking air pressure in between and found it not to be decreasing. came back home and the next day ( again 2 days passed since i last filled it) found that a good amount of air has escaped.
is it a puncture or is there something else wrong.
vishnuvijay is offline   Reply With Quote
Old 3rd April 2008, 14:17   #2
bblost's Avatar
Thanked: 6,977 Times
check for young kids, old disgruntled men, ex lovers around your car.
Old 3rd April 2008, 14:22   #3
condor's Avatar
Thanked: 4,898 Times
Possibly a flat tyre. Get it fixed.
Old 3rd April 2008, 14:25   #4
headers's Avatar
Thanked: 464 Times
Could be that the tubeless valve is leaking.. or you could have a small puncture.. fill air to 5 psi more than normal and drive to a tubeless repair shop to get them check.. I'd suspect the valve..
Old 3rd April 2008, 14:27   #5
kpzen's Avatar
Thanked: 1,655 Times
I agree with headers. I also suspect a leaking valve.
Old 3rd April 2008, 14:28   #6
iraghava's Avatar
Thanked: 156 Times
Should in all probability be a puncture in the tread. Valve is also a possibility but less so since this can be detected by the pump attendant quite easily.
Old 3rd April 2008, 14:31   #7
bottle's Avatar
Thanked: 138 Times
i had this problem with a faulty vavle on a new tyre.. get it checked
when they put the tyre under water you would get a bubble now and then.. so it was slowly leaking air
bottle is offline   Reply With Quote
Old 3rd April 2008, 14:32   #8
Jaggu's Avatar
Thanked: 8,684 Times
Check valve, also check the edges of the valve where it rests on the rim. Then move on to inspect the tyre for any nail/iron piece etc.
Old 3rd April 2008, 14:48   #9
Thanked: 146 Times
when i fitted the tubeless had the same issue with a type. it was losing pressure on a regular basis. but it was on a scale of 3~5 psi in a week. When checked it was a faulty valve.
After replacing that had no issue so far.
Would suggest a quick visit to the tyre store. Faulty valve or puncture - it will be fixed and you will have some peace of mind.
HappyWheels is offline   Reply With Quote
Old 3rd April 2008, 15:35   #10
spadival's Avatar
Thanked: 16 Times
You'll probably see a 2 inch nail embedded in the tyre. I had 3 nails embedded in my tyre before it started losing air!!
spadival is offline   Reply With Quote
Old 3rd April 2008, 17:15   #11
thank you guys for replying.
the guy at the ioc pump said there is no valve leak. i din't check for any nails. anyways i'll get it checked at a good tyre shop this weekend when i go home.
Old 3rd April 2008, 19:27   #12
tsk1979's Avatar
Thanked: 16,421 Times
I had a similar problem when the car had potenza.
Got it checked at the pump and even at the tire repair shop.
Immersing in water also did not show bubbles and I was in a fix. Then while checking the guy accidently bent the valve towards the right, and we saw bubbles near the valve stem. This used to happen only when the valve stem was bent in a particular direction.
changed the valve and the problem went away.
The leak was not from the top of the valve(what pump guys check), but near the stem, where the valve goes into the tire.
Old 3rd April 2008, 20:44   #13
Thanked: 146 Times
... The leak was not from the top of the valve(what pump guys check), but near the stem, where the valve goes into the tire.
Exactly the same problem that I faced! The base was having a leak!
Old 3rd April 2008, 21:22   #14
headers's Avatar
Thanked: 464 Times
Boss..i'd doubt a pump attendant diagnosing a valve leak! We are not in your esteemed company you see
How did the pump guy check the valve leak?
This is exactly the weak point.. I've had the same in my Indica. And only good / experienced tyre guys will find the problem!
The tubeless tyre valves have to be seated properly on the rim, else this leak will happen. Also corrosion in the area can tear the valve seats.
Just my 1 paisa!!
Old 3rd April 2008, 21:48   #15
tsk1979's Avatar
@headers, if the leak is from the top of the valve it is detectable as the pump attendents often put saliva on it after filling in air(I know its sounds gross, but thats how I have seen it being done).
But when the leak is from the bottom stem ... You need an expert.
The 'Actual' Tyre Pressure : Is Atmospheric Pressure Counted? sr_1445 Technical Stuff 2 16th January 2014 11:05
Losing air pressure on my optra stock steel rims mdesai_1981 Tyre & Alloy wheel Section 0 8th September 2008 00:55
How fast....How fast? sri Street Experiences 10 16th July 2007 18:58
Losing the air between RIM and tyre, is this possible? Laxminarayan Street Experiences 14 17th January 2007 17:11
