Tyre & Alloy wheel Section Everything to do with footwear for your car!
Thread Tools
Old 23rd April 2008, 22:42   #1 (permalink)
Infractions: 0/1 (7)
Default Annoying problem while braking..
Recently i had a delhi-shahranpur tour on my chevy optra, i faced some issues which sounded new to me..
a) High tyre noice while driving at high speed is too high, didn't noticed it too much before - Any solutions, apart from changing the tyres ?
b) Their was strange wobel sound from backside i.e. back tyres while braking from high speed, which certainly reduces comfortability level while braking - Is it something to do with proper alignment ??
I usually drive at high speeds, so i need to sort out these particular issues so as to make myself comfortable at braking during high speeds.
Old 23rd April 2008, 23:33   #2 (permalink)
kpzen's Avatar
Ashish
What tyres do u have in your Optra?
How many kms have they done?
__________________
Prajesh - << will be offline till August >>
A true friend is someone who says nice things behind your back...
Old 23rd April 2008, 23:44   #3 (permalink)
Gangsta's Avatar
Try changing tyres like front to the back or left to the right. I was getting similar problem in my Elantra. Now its been fixed by doing this itself.
__________________
Hyundai Elantra CRDi
Hyundai Accent 1.6L GLS
Maruti Suzuki Wagon R
Maruti 800
What's Next?... Yamaha R15 :-)
Gangsta is offline   Reply With Quote
Old 23rd April 2008, 23:49   #4 (permalink)
1100D's Avatar
Does the wobble/vibration while braking from high speed also get transferred to the steering wheel. If yes, you need to replace the brake rotors/disks.
Tyre noise can also be due to stones being attached to the grooves, please check. Otherwise its a characteristic of the tyre (either by design or by usage) needing replacement.
__________________
________________________
Every Ferrari is always a Fiat
1100D is offline   Reply With Quote
Old 24th April 2008, 00:17   #5 (permalink)
rks
rks's Avatar
Tyre noise could be normal for the tyres that your run. If you feel it is abnormal, check your tyre pressures. Tyres can get noisy if pressures are too low. Apart from this, the only solution is a tyre change.
Apart from the suggestions so far, check alignment+wheel balancing. Get your brakes serviced. Are you using after-market alloys? These could cause vibrations while braking from high speed, if the specs are not OK. Check your wheels for any damage/bends (especially if they are stock steel rims). This could cause vibrations while braking.
Check your tyres for damage/tread wear/flat spots and replace if necessary.
Old 24th April 2008, 09:14   #6 (permalink)
Ashish
Prajesh,
I am running on Bridgestone. Not sure the series name.
So far they have done around 20K km as they got changed by my cousin to whom car was lended in that particular period, Rent was free tyres
Will give a try to tyre rotation this weekend. Which tyres your elantra is having.
Old 24th April 2008, 09:19   #7 (permalink)
No, it doesn't but the strange sound looks like something like... thud..thud... thud....
hmm.. will check the grooves and let you know. However, i am planning for tyre rotation.
Old 24th April 2008, 09:26   #8 (permalink)
Gangsta's Avatar
Prajesh,
GoodYear.. Stock Size
__________________
Maruti 800
Old 24th April 2008, 09:27   #9 (permalink)
I usually maintain a tyre pressure of 34-PSI at front and 32-PSI in rear, i hope it is correct for chevy optra. Earlier i use to keep 32-PSI in front and 30-PSI in rear, which resulted in low pickup and heavy moving. Upgrading the tyre pressure helped in avoiding such problem.
I am on stock rims, i am too even somehow inclined towards getting the alignments and balancing re-done which was initially done in showroom at the time of service around 4K kms back.
Rear tyres were checked for the damages and punctures on last weekend only, as this week's tour was in cards from last month. Tyres were fine without any damage or flat spot.
Old 24th April 2008, 09:28   #10 (permalink)
How many kms have they covered, did the problem arose again ?
Old 24th April 2008, 09:59   #11 (permalink)
Gangsta's Avatar
It was very much recent, like 2 week back i was getting this problem then after that i havnt faced this problem. Car is rock steady above 170 kmph too. This set of tyres had done just 9k KM.
Also, check the car's alignement and wheel balancing and before doing it ask them to rotate the tyres accordingly.
__________________
Maruti 800
Old 28th April 2008, 09:49   #12 (permalink)
Got the rear wheel alignment and tyre rotation yesterday, problem seems to be solved Rear wheel alignment was too much out, according to the tyre guy!!
Though the guy has asked to get the drum checked as an precautionary measure.
Thread Tools
Braking- of a Zen kaushik_s Technical Stuff 5 17th May 2007 17:08
Engine Braking a_micky Technical Stuff 1 26th February 2007 23:03
Radio Disturbance when Braking - Help please manaa45 Ask the Gurus 6 27th January 2007 13:19
Vibrations under hard braking RJK Technical Stuff 15 21st July 2005 13:42
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
