Tyre & Alloy wheel Section Everything to do with footwear for your car!
Thread Tools
Old 29th April 2008, 17:14   #1 (permalink)
Default Help me upsize my zen
Hi All,
Iam planning to upsize the car tyre profile, My priorities: Saftey, braking, handling.
Car details:
Zen MPFI 2003 model.
Currently on stock tyres and rims.
Based on the information available in the threads, i have 3 profiles in mind
155/65R13
165/60R13
165/65R13
Please let me know which profile shall be ideal for my car and please answer the below questions
- the correct profile upgrade
- pros and cons
- manufacturer to buy from (i live in bangalore)
- if customizing of suspension required, where to get it done from
- the right set of alloys, manufacturer to buy from
Appreciate all the help
idly is offline   Reply With Quote
Old 29th April 2008, 21:08   #2 (permalink)
zenopio's Avatar
if for 14 inc go for 195/45/r14
13 inch go for 165/60/r13
zenopio is offline   Reply With Quote
Old 29th April 2008, 21:17   #3 (permalink)
theodore_ftw's Avatar
If you are upsizing your tyres then you may want to raise your car by adding spacers inside the shock absorbers. The Zen is anyways notorious for having its underbody touch any speed breakers at high loads so it may be a good idea to raise it anyways.
I am using 165/65R13 Bridgestones which required me to raise my Zen (2002). But then i also have Alloys on which portrude outside the car.
__________________
You tried, and you failed, so the lesson is, never try.- Homer J. Simpson
theodore_ftw is offline   Reply With Quote
Thread Tools
the right upsize speedsatya Tyre & Alloy wheel Section 170 13th June 2008 20:01
Ohc upsize SYJ Tyre & Alloy wheel Section 28 22nd January 2008 18:37
tyre upsize for my zen 2003.help me guru yasw_anth Tyre & Alloy wheel Section 7 6th November 2007 12:58
Qualis upsize paras211 Tyre & Alloy wheel Section 13 9th June 2007 13:25
Tyre upsize srinath34 Tyre & Alloy wheel Section 5 10th April 2006 08:52
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
