Tyre & Alloy wheel Section Everything to do with footwear for your car!
Thread Tools
Old 2nd May 2008, 10:54   #1 (permalink)
Default Urgent help with my Lancer's tires
I own a lancer with tires that may have run almost 5k kms (ceat accelere). Around 3 months back i went for wheel balancing and alignment and noticed a steering wobble immediately after that, the reason given to me was that one of the tires has an uneven surface which will even out in some 5k kms. But i never felt that happening, the steering used to be wobbling especially at slow speeds and need to be held onto to prevent it from wobbling. I went back to the same guy and got the wheels rotated back but to no avail though the wobbling reduced than before (he also told me at the same time that my steering tie-ends or what ever need to be replaced). recently i got the car serviced and was told that it is a tire problem and not the steering one but was asked by the service centre guy to get the faulty tire/ tires to be repaced as it will harm the steering column in the longer run (but ironicaly he could not spot which one is the faulty tire with uneven surface)
Please let me know what to do? Does it makes sense to get all the tires replaced when they are relatively new and can still be worked aroud for some time? Please advice how to get the faulty tire spotted so that i can get it replacedrather than spending to replace all 5 sets
Thanks!!!!!
__________________
Lancer doesn't turn heads....coz it is mile ahead of u even before u can admire
LANCER3 is offline   Reply With Quote
Old 2nd May 2008, 21:11   #2 (permalink)
autopsyche's Avatar
You might have a bad tire (warped or bubbled)... and when you got the balancing done the bad tire might have been on the rear and then got installed in the front which increased the wobbling effect. Get the balancing checked once more and get to know which tire is the culprit and change that one. Could be the rim too and not the tire so just double check when getting the balancing done.
__________________
"I drive a Mitsubishi 3000GT, and I live a 1/4 tank at a time... For those 50kms or less, I'm free."
autopsyche is offline   Reply With Quote
Old 2nd May 2008, 22:55   #3 (permalink)
kpzen's Avatar
Ceat Aceleres or Apollo Aceleres ???
Mods: Please shift the thread to tyre section.
__________________
Prajesh - << will be offline till August >>
A true friend is someone who says nice things behind your back...
Old 7th May 2008, 20:13   #4 (permalink)
I think its ceat not sure about the accelere part. Just been too stuck to have a look at it since many days
Arush, thanks for the reply. Will get that checked this weekend (if i get time).
Arush if i intend to get all the tires replaced to what extent of size can i upgrade without any changes on shockers, springs or something else
Thanks Guys for the help!!
__________________
Old 16th July 2008, 18:13   #5 (permalink)
Default Lancer Tyre Upgrade Help
Hello,
I have Lancer GLXi - 1999 Model. Currently I have all michelen tyres which are completely worn out. I am planning to buy new and reliable tyres.
Existing Tyre Size Details :
185/60 R14 8217.
Can any one suggest good and reliable tyres.
Thanks for your help.
Rajesh.
Note from Team-BHP Support : Thread merged. Please use the search feature before creating a new thread on a topic that might already exist. Please continue your discussion in an existing thread. This will keep all the relevant information in one place and make it easier for readers in the future.
Last edited by Jaggu : 16th July 2008 at 18:25. Reason: Search before opening a new thread please.
tavakari is offline   Reply With Quote
Thread Tools
Query : Tubeless tires / Normal Tires nicejits Tyre & Alloy wheel Section 8 15th January 2008 01:56
need help in buying tires v_s_natarajan The Indian Car Scene!! 3 3rd December 2007 16:16
help!!-price for my lancer's new footwear redsfx Tyre & Alloy wheel Section 1 31st May 2007 18:03
What is it with wheels and tires? Selective Tyre & Alloy wheel Section 7 25th June 2005 00:24
new tires:FE up or FEdown???? speedsatya Technical Stuff 7 13th April 2005 01:48
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
