Old 25th March 2009, 21:23   #31
Originally Posted by sen2009 View Post
Spoke to some people at Tata Service Centre.
Have spoken to some tyre dealers. They are yet to get back to me with price quotes for a set of 5 such tyres and the buy back they would offer on my stock tyres.
I'll post the results and seek opinion as soon as I have them.
Hi sen 2009
Be careful while buying Pereilli.
I had them on my Indica. The side walls of all 5 tyres cracked prematurely and I am quite carefull about driving, tyre pressure, ect.
Which rims do you intend to buy?
7J are not available with any Indian manufacturers. Only imported ones. If you are fine with them its alright otherwise that will be important to decde the tyres you buy.
255 is a bit wide for 6.5J so I refrained from these. Infact even the 235 Micheline on Aura rims fouled with the front fender which I had to trim a little.
Yes the FE will decrease a bit but nothing to realy bother about. Exact figures are difficult to derive as a lot depends on driving habits and driveabilty.
Whichever tyres, you will enjoy every bit of driving a Safari. Congrats.
Ravi Kashyap is offline   Reply With Quote
Old 27th March 2009, 14:36   #32
iraghava's Avatar
Thanked: 153 Times
Effect on FE should be a maximum reduction of about .5-1 kmpl.
Old 1st April 2009, 17:21   #33
james's Avatar
Thanked: 467 Times
OT: what is the recomended tyre pressure for 255/65 r16 geolanders? ive got them on the scorpio. I get different values from all the tyre guys here.. This is basically for city use on ok-bad roads.
Thanks!
james is offline   Reply With Quote
Old 2nd April 2009, 00:41   #34
iraghava's Avatar
Thanked: 153 Times
Try stock values and if you find the ride too bouncy then try by lowering 2 psi and then in 1 psi steps until you find the right compromise.
Old 2nd April 2009, 08:17   #35
tsk1979's Avatar
Thanked: 15,644 Times
I don't think that air pressure in your tires should be lower than manufacturer recommended values!
Old 2nd April 2009, 13:50   #36
iraghava's Avatar
Thanked: 153 Times
And I don't think it should be higher, makes for a terrible ride.
Old 2nd April 2009, 14:00   #37
tsk1979's Avatar
Having tire pressure lower than manufacturer recommended(cold tire pressure) increases the risk of high speed blowouts, as standing wave can form. This is especially true for tires where sidewall flex is more.
ConsumerReportsTireSafety.pdf
Old 2nd April 2009, 14:01   #38
iraghava's Avatar
Thanked: 153 Times
I prefer a less bouncy ride so keep it lower especially since I always upsize tyres on my cars. Haven't had a problem in the past 10 odd years and 3 lac+ kms. But of course, I go down a psi or two, nothing excessive.
Old 30th September 2009, 20:53   #39
Shubhendra's Avatar
Thanked: 1,178 Times
Default Small Query
All,
I have a small query. I have booked Safari Lx and i am opting for Alloy wheels with OE tyres. My question is can i use use 7J alloy with OE bridgestone H/T. Or i will have to go for 6.5J Alloy to accomodate OE Tyres.
Shubhendra Singh
Shubhendra is online now   Reply With Quote
Old 1st October 2009, 19:21   #40
ScorpMan's Avatar
Thanked: 121 Times
Shubhendra, You can go for 7J alloys without any worries.
ScorpMan is online now   Reply With Quote
Old 28th July 2010, 16:39   #41
josepeter's Avatar
Thanked: 547 Times
Bump : Thinking of going for Yoko Geolandar 255/65/16 on 7 inch rims. Would like to hear from anyone who has this combo on the VTT.
josepeter is offline   Reply With Quote
"PERFECT" Tyre Upsize for Alto Vxi SLK Tyre & Alloy wheel Section 13 9th November 2017 12:49
Tyre upsize for indica tsk1979 Tyre & Alloy wheel Section 67 19th June 2011 20:18
The right tyre upsize speedsatya Tyre & Alloy wheel Section 245 13th December 2009 18:28
Tyre upsize srinath34 Tyre & Alloy wheel Section 5 10th April 2006 08:52
tyre upsize for 500SEL W126 viper Tyre & Alloy wheel Section 25 28th October 2005 09:25
