Tyre & Alloy wheel Section Everything to do with footwear for your car!
Thread Tools
Old 21st May 2008, 04:58   #1 (permalink)
Tool's Avatar
Default Need Serious Help..Michelin PP2 or BF Goodrich Or Yoko but what Yoko ??
hey everyone..
i need some serious help guys..pleaseee
Rains are around the corner.. and i need new tires.
Currently running 185/60 R14 Yoko Avs-Es 100's .Have run them for approx 22,000 Km and also the rains are coming.. so its time to change.
I generally never use any set of tires past 22-25,000 Km either.
Now here is my problem.. Yokohama ES100's are no longer available. And not to mention i want better grip.
Would love to get the Yoko S-drives in my size but i have no clue as to their availabilty in my size. Any Idea Guru's ??
Bridgestone G-III's according to me are getting very old !!. Although a lot my friends love the tire and i know they drive HARD .
Also they are built using old technology. Want something New from bridgestone now. The RE001's look delicious but they certainly wont be available here in India.
Only plus is the G-III's are available in my size.
Now about Michelin PP2's.. have heard nothing but praises about them. Also from what i gather they are very good in the rain as well.
Most tempted to go for these guys..Also Available in my size.
But like i said im confused..lol lol
Have no clue about BF goodrich. But they do look good.
Although they are Also Available in my size.
how would they rate against the G-III's and the S-drive's and for that matter even the Michelin PP2's?
Would really appreciate if you guys could help me out make up my mind.How would these tires rate against each other ?
Also can i also ask for approx pricing on the tires as well ? Not that cost is a factor.
Have been quoted around 4K for the G-III's in my size.
Thank you lots for all the help in advance guys
__________________
Why Drink And Drive When You Can Smoke And Fly ??.
Front Wheel Drive Is The Work Of Satan !!!
Tool is offline   Reply With Quote
Old 21st May 2008, 09:19   #2 (permalink)
akshay1234's Avatar
do you want to stick to the same size?
like you said es100s are no longer available.
the potenzas are too old and their ride is crap.
you dont get pp2s in that size. you will get pp1s in 195/60 r14.
the bfgs g-sport should be available in 195/60 r14 and those are suuposedly direct competition for pp2s and s-drives.
s-drives arent available in 14".
IMO the bfg g-sport would be the best best out of the lot.
akshay1234 is offline   Reply With Quote
Old 21st May 2008, 10:11   #3 (permalink)
kpzen's Avatar
Michelin PP is class apart when it comes to performance in the wet...!!!
S drives don't come in 14"..
__________________
Prajesh
If you think your teacher is tough, wait till you get a boss.
Old 21st May 2008, 12:27   #4 (permalink)
djay99's Avatar
PP2's are available in 185/60-14.
__________________
DJ
Getz Prime CRDi VGT (TS 175KMPH)
Chevy Spark LT (TS 160KMPH)
djay99 is offline   Reply With Quote
Old 21st May 2008, 12:29   #5 (permalink)
djay99's Avatar
If you are looking for 185/60-14 or 195/60-14, Michelin PP's are best.
__________________
DJ
Old 21st May 2008, 13:26   #6 (permalink)
iraghava's Avatar
Let me first clear up a few doubts here:
You get PP2's in 185/60 R14 Akshay & he's looking for those, not 195's.
S-Drives are indeed available in 14", 185/55 R14. The thing is 60 profile & above are in ES100 while 55 & below are in S-Drives. That's the differentiating factor rather than rim size.
Now coming to your queries, the options you have available are:
Michelin PP2
Yokohama ES100
BFGoodrich G-Force Sport
Bridgestone Potenza GIII
Out of these I would forget about GIII's, they are passe. Out of the remaining the best tyre in the wet would be the PP2's, followed by the S-Drives which are equal to the BFG's. And Akshay the BFG's are aimed at the S-Drives not the PP's. No company will introduce two rival products into the same market from their own brands (BFG is owned by Michelin).
So, my preference would be PP2 & then either S-Drives or BFG's. Price of PP2 is around 3.8-4k per tyre while S-Drives & BFG would be around 3.5k.
__________________
There is a very fine line between "Hobby" and "Mental Illness".
Old 21st May 2008, 16:25   #7 (permalink)
razor4077's Avatar
Had a chance to test the PP2s in the wet recently, and they surpassed my expectations. Even in slushy conditions, when the other cars were tiptoeing around the roads I was able to coast without losing a beat. Going around slushy and wet corners were a breeze too.
I have not used any of the other tyres you mentioned, so I cannot comment on them. From personal experience I would wholeheartedly recommend the PP2s.
razor4077 is offline   Reply With Quote
Old 21st May 2008, 16:45   #8 (permalink)
hydrashok's Avatar
I've not used PP2, but the PPs on my Palio (205/50 R15) were a blast in the wet. It rains for close to 6 months out here, and I'd never had to tip-toe around just because the roads were wet, with the PPs. The PP2s must be even better. Performance in the dry was just great! Though they are performance tyres, the PPs gave a pretty comfortable ride too. My only beef with them is that they wear out pretty fast.
I run S-Drives on my Swift (205/50 R16) and I'd say the S-Drives are as good, or even better overall, in comparison to PPs (not PP2s). I had opportunity to do some pretty decent speeds on the highway, and uh, some pretty indecent speeds on very good and wide side-roads in Trivandrum recently (I was rushing to make time, and pretty much forgot that the car is being run-in). The S-Drives grip the road very well, and cornering is very very confidence-inspiring. The tyre noise is much lesser than the PPs on the highway, both on good roads and not-so-good roads. Right now if I were offered a choice between S-Drives and PPs, I'd pick S-Drives. I bet the S-Drives are 10 to 15% cheaper in comparison too!
I haven't used PP2s at all, so I can't comment on them. I'm sure Michelin must have improved on the PPs a lot when they brought out PP2s.
__________________
Coming soon: Balls of STEEL!
Old 21st May 2008, 16:54   #9 (permalink)
Somebody told me , S.drives are all micro silica based.
And i read some where silica based tyres are far superior in wet...
itzzme is offline   Reply With Quote
Old 21st May 2008, 17:06   #10 (permalink)
n_aditya's Avatar
How come the Advan Neova's chewing gum tires are not mentioned? Arent they manufactured by Yoko?
__________________
RIP Tootie !!! Missing you terribly.
Old 21st May 2008, 17:45   #11 (permalink)
BAKIYA_2K12's Avatar
if you want the best go for pp2 i am using it for past four months it will give you the best performance in wet and dry conditions
BAKIYA_2K12 is offline   Reply With Quote
Old 21st May 2008, 17:46   #12 (permalink)
crazydiablo's Avatar
The only demotivating factor agains the neova's is their price. They are a lot more expensive than PP2.
crazydiablo is offline   Reply With Quote
Old 21st May 2008, 17:52   #13 (permalink)
payam's Avatar
They are manufactured by Yoko but they are not available in 14' sizes .
actually below 15'.
payam is offline   Reply With Quote
Old 21st May 2008, 18:10   #14 (permalink)
kpzen's Avatar
but i didn't consider S drives since they are not available in 185/60 and 195/60.
PS: Somebody told u??
actually below 15'.
They are now available in 195/60-14.
__________________
Prajesh
Old 21st May 2008, 18:45   #15 (permalink)
akshay1234's Avatar
my bad about the pps. though 60 profile was pp.
and i wrote pp2s by mistake. meant to only write s-drives.
thnx for the info tyre bhagwaan.
Thread Tools
Yoko or Michelin tyres in bangalore pshyamsundar Tyre & Alloy wheel Section 10 1st August 2008 10:41
Yoko es 100 woes, need a new set naman Tyre & Alloy wheel Section 36 7th March 2008 13:45
Any Problem in putting Yoko 205 Tyres in Swift VDI? Rockzer Tyre & Alloy wheel Section 7 3rd March 2008 10:24
Tyres for Hyundai Verna - Edit: Review of Yoko C.Drive Sam Kapasi Tyre & Alloy wheel Section 120 2nd July 2007 14:41
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447
