Old 3rd September 2012, 10:59   #136
Thanked: 13 Times
Default re: Toyota Innova : Tyre & wheel upgrade thread
Originally Posted by parsh View Post
You have been running on dead tyres The rubber must have hardened even if it may look good. At best 5yrs life would have been good. Suggest you stick to stock size unless warranted for any special use or you want that chunky look.
Caution about Yokos, their sidewall is on softer side than competition and prone to sidewall damage, already have that experience. But I think their driving performance is better, I find their grip and braking on wet surfaces really good, allows me to easily cruise at high speeds without bother. Also, IMO they are more silent.
Additionally, check out newly launched Michelin XM2, their sidewall seems thicker than C-Drive as I checked last, but can't say about other differences.
Finally, i have changed the shoes of my Innova. Went in for Yokohama C drive 225/60/R15. The best price i could get was 7000 / tyre. Lets see how they fare. I am going on a weekend trip to Ooty (from Bangalore)
MaverikMahesh is offline   Reply With Quote
Old 3rd September 2012, 11:11   #137
parsh's Avatar
Thanked: 1,017 Times
Cool. Enjoy the smooth silent grippy ride for miles to come. Just be little extra careful while road-side parking or going thru ditches that the sidewalls are not badly scrapped. Nice price too I guess. I could get 6100 recently for standard 205/65 R15 profile as I had to change a damaged tire.
parsh is offline   Reply With Quote
Old 4th September 2012, 10:00   #138
Thanked: 26 Times
I see that the Yokohama C Drives are quite respected, but the sidewall thing does bother me because potholes are a way of life and there is a limited working around. Are there similar high quality tyres that you guys suggest that have stronger sidewalls?
maverhick is offline   Reply With Quote
Old 4th September 2012, 10:11   #139
parsh's Avatar
Suggest you check out Michelin XM2 launched recently. They are on pricier side but seem to be better than XM1 and C Drives, also their sidewall seems to be pretty thick in comparison.
Old 13th September 2012, 12:12   #140
Thanked: 26 Times
The XM2 is available but in the stock size, not in the upsized version. Any other choices in the upsized version?
Also does anyone here have the figures on what the tyre pressures need to be for the front/rear? What are the stock ones and do they change based on upsizing the tyres?
Old 13th September 2012, 22:37   #141
parsh's Avatar
The options are pretty less, C-Drive, XM1, XM2, Turanza/Potenza. But of the lot, C-Drive performance on wet/dry and grip could be better. Today once more experienced the grip and ultimate control on wet surface of C-Drives at high speeds on Mumbai Pune EWay, and I am once again floored. They just seem too good, alas for the weak tirewall.
Stock size tyre pressure should be 32/33 depending upon loading.
parsh is offline   (2) Thanks Reply With Quote
Old 14th September 2012, 09:19   #142
parsh's Avatar
Sorry forgot Primacy LC, which should be quite comparable to C-Drive.
Old 14th September 2012, 09:44   #143
Thanked: 26 Times
I believe the upsize is available in Primary LC and not the XM2. I'm still thinking if I should upsize or just get a regular stock size XM2.
Have you guys noticed any significant changes in comfort level after the upsize?
Old 14th September 2012, 10:24   #144
parsh's Avatar
Before deciding, consider various aspects:
+ chunkier look & feel
+ larger surface area contact means better grip, better performance and comfort: but should not be too big a difference, people who up-sized may comment. IMO it doesn't make too great a difference and 205X65 profile is good enough on all perspectives on most of terrains.
- loss of FE
- aberration in speed, distance, ODO
Not considering cost factor, otherwise why would you think about up-sizing
Comparison courtesy 1010tires.com:
Name:  1010tires  205 Vs 225.jpg
parsh is offline   (1) Thanks Reply With Quote
Old 15th September 2012, 00:55   #145
Thanked: 157 Times
If you regularly drive below 100-110 kmph and dont corner hard, pls stick to the regular size. If you like ripping the car a bit , pls upsize. There are no significant changes in comfort level after upsizing though ride becomes more sensitive to tire pressure IMHO.
I think that for the Innova, c.drives are the best. They are 25% cheaper than primacy LC so even if you lose one tire through 50k kms, the price compensates. And know that this is one of the most grippiest tires in the wet, very good in the dry and one that is very silent and offers a smooth ride.
I run C.Drives (225/60R15) on the Innova for the past 47k kms and I lost one tire as my wife put the car - tire sidewall first on a one foot high parapet wall corner. It gave out with the noise similar to a bomb blast. Till today, the rest 4 tires do not wobble and have excellent grip. I also changed over to C.Drives in the Baleno I own (It used to run on Michelin XM1's 185/65R14 and the size has remained same) and I can confirm that while Xm1 has sturdier construction, the C.Drive offer better ride, grip and silence.
So what will I buy in the Innova again - its a no brainer for me. The C.drive again
Buffetfan is offline   (2) Thanks Reply With Quote
Old 21st September 2012, 23:14   #146
genesis's Avatar
Thanked: 304 Times
Ran thru my second set of tyres 225 60 R 15 C Drives in 30 k. Severely disappointed with one sidewall cut, multiple punctures etc
Has anyone tried AT tyres on their innova.
Specifically Yoko Geolanders 205 70 R15?
I know it is not the perfect size hence asking
genesis is offline   Reply With Quote
Old 24th September 2012, 11:58   #147
Thanked: 157 Times
AT Tyres will be noisy and will futher stiffen the Innova ride. the 70 profile will increace GC by 10 mm but will make the vehicle top heavy and unstable on hard cornering
Buffetfan is offline   Reply With Quote
Old 25th September 2012, 16:42   #148
kapursaket's Avatar
Thanked: 76 Times
Default Contemplating Tyre Change on My Innova G3 Diesel 2005
A peruse through the vast knowledge base of Team Bhpians has helped me conclude as follows
1) Since I have Steel rims I need to stick to Toyota recomendation of 205/65/R15
2)In light of Indian roads need a tyre with strong side walls, so it has to be a tyre tropicalised for India......Yokohama, Michilien and other imported tyres are ruled out.
3)Need to choose between Bridgestone Turanza ER 60 or Appollo Acceler or Good Year Assurance.
My Innova is clocking 49K and 07years but the Stock Bridgestone are still gleaming with more than even wear and still show off grooves. But surly the change is overdue for safety on highways.
Please help me decide between the above mentioned choices?
kapursaket is offline   Reply With Quote
Old 25th September 2012, 19:05   #149
WasavaTyres's Avatar
Thanked: 255 Times
Smile re: Toyota Innova : Tyre & wheel upgrade thread
Specifically Yoko Geolanders 205 70 R15 ?
I know of a guy whose Innova is shod with these. He uses the vehicle over kuccha / village roads, so is only concerned about ruggedness and increased GC. Yoko has 2 designs in this size now, check pic for reference.
Toyota Innova : Tyre & wheel upgrade thread-yoko_innova.jpg
WasavaTyres is offline   Reply With Quote
Old 25th September 2012, 19:47   #150
parsh's Avatar
Left side is the A/T-S, would be less comfy, better off-terrain, preferred most
Right side is the H/T-S, would be more comfy, lesser(?) off-terrain
Hyundai Grand i10 & Xcent : Tyre & wheel upgrade thread jkdas Tyre & Alloy wheel Section 15 15th June 2018 16:33
Toyota Fortuner : Tyre & wheel upgrade thread Turbanator Tyre & Alloy wheel Section 67 9th June 2018 11:55
Toyota Innova Crysta : Tyre & wheel upgrade thread Sankar Tyre & Alloy wheel Section 22 15th May 2018 12:55
Toyota Corolla : Tyre & wheel upgrade thread Wraith Tyre & Alloy wheel Section 113 2nd May 2017 14:01
