Old 11th April 2012, 12:40   #121
condor's Avatar
Thanked: 4,412 Times
Default re: Toyota Innova : Tyre & wheel upgrade thread
Should be fine, if there is no damages. I think there is sufficient tread left, and these are only 2009.
condor is offline   (1) Thanks Reply With Quote
Old 11th April 2012, 12:44   #122
Eddy's Avatar
Thanked: 4,774 Times
Re-check after another 10k. Look just fine to me.
Eddy is offline   (1) Thanks Reply With Quote
Old 11th April 2012, 13:14   #123
suhaas307's Avatar
Thanked: 6,623 Times
Originally Posted by bblost View Post
My friends 2009 Innova running on stock goodyears has completed ~49k kms.
Tires have "May 2009" as manufactured date.
Are these tires good for another 10-20k kms?
Attachment 914313
Attachment 914314
Are those the 1st set?
That is not bad at all, for a 49k old set. Some good and careful driving practices, I assume. I think it would be good for another 20k (or 10-15k if there is a lot of highway driving), unless the tyre-wall shows signs of ageing or damage. (cracks/bulges..)
My Santro has done 45k and has never seen the highway. The tread on it doesn't look as good as this. Also because my car is nine years old now.
suhaas307 is offline   (1) Thanks Reply With Quote
Old 11th April 2012, 13:15   #124
vikram_d's Avatar
Thanked: 937 Times
They sre definitely good for another 10k at least.
Old 12th April 2012, 23:54   #125
smartcat's Avatar
Thanked: 12,282 Times
The tread depth seems to be OK - so there won't be any serious grip or braking issues.
But @49K Kms, the sidewalls would have lots most of its strength. He stands risking a ripped sidewall on highway runs - he has to especially watch out for flying stones etc.
smartcat is offline   Reply With Quote
Old 13th April 2012, 10:49   #126
Thanked: 551 Times
Off Topic: Are you serious to continue to use those tyres? Rubber would have hardened by now in these 9 years & sidewall would have developed small cracks. Please change tyres at the earliest or before monsoon this year.
sukiwa is offline   Reply With Quote
Old 13th April 2012, 11:30   #127
suhaas307's Avatar
OT
On it, Sir. I've been short of funds and that's what has been keeping me away from swapping the old tyres with new ones. You're right. It has hardened and has developed small cracks.
I appreciate the concern.
suhaas307 is offline   Reply With Quote
Old 9th June 2012, 14:43   #128
Thanked: 157 Times
Originally Posted by sam003 View Post
I went to one dealer here who has both brands with him, he was claiming that C drive is more noisy then MXV8. As per him MXV8 is much much better then C drive. Is that So Team ?
After owing the tires for some time now, do you agree with the dealer on the noise - my C.Drives have aged pretty well with NO NOISE though after bursting one tire, two of the remaining 4 look ready for a change in the next 5-10k kms
Buffetfan is offline   Reply With Quote
Old 9th June 2012, 20:05   #129
Thanked: 58 Times
Not really as I have driven C-Drive almost 65K km. But to be frank Innova itself sound bit loud, so its not possible to hear tyre noise.
sam003 is offline   Reply With Quote
Old 22nd July 2012, 13:38   #130
parsh's Avatar
Thanked: 975 Times
With one tyre damage, I am left with 3 from set of 4 Yoko C tyres having run 20k.
I would definitely need to buy 1 Yoko C. But that would create imbalance of 3 with 20k and 1 with 0. I am thinking, I should buy 2 tyres and put for regular use to balance out and keep 1 of the remaining 3 as spare. My existing spare is anyway run out due to aging being one from time of delivery in 2005, but which has been hardly used so had kept it as it is. Another option would have been to get about 20k run Yoko C but which seems like a distant possibility to find it. Your thoughts pls?
parsh is offline   Reply With Quote
Old 23rd July 2012, 03:24   #131
Thanked: 157 Times
My suggestion is to purchase two and put them on the rear axle, where they will wear out faster owing to the fact that the Innova is rear wheel drive. Also, always put the newer tires in rear no matter what the car is.
Finally, this is the reason I always purchase 5 tires - even if one gives out, we can carry on with other similarly aged 4 pieces and use some old jugaad as spare.
Buffetfan is offline   (1) Thanks Reply With Quote
Old 23rd July 2012, 08:44   #132
parsh's Avatar
Thanked: 975 Times
Nice suggestions. Thanks for confirming.
I did not purchase 5 at the time of change because the spare was good enough to be a spare only, has been rarely used as such till date, but it has aged with age, the 5th Yoko would have been just sitting idle aging itself without any use. Now I think one of the Yokos is aged with use which can be put to spare use while 2 new ones will do duty on rear.
Old 23rd July 2012, 18:41   #133
Thanked: 157 Times
Hi - I do a 5 tire rotation every 10 k (5 k is better though) that ensures every tire wears out same. Buying 5 tires upfront just ensures that we have 4 of the same model in case the model is not produced anymore
Old 30th August 2012, 12:30   #134
Thanked: 13 Times
Hi Tyre aficionados,
I plan to change the tyres on my 2005 Innova. I have done 50,000 kms (only) and the stock tyres (Bridgestone) have help up pretty well till now. But i know that they are due to be replaced and i want to do this next week.
I have been reading a lot of reviews in this space, and i find a consensus on Yoko C drive.
Should i go for the regular size (I generally use the Innova when going out of Bangalore - on the highways) 205/65/R15 or 225/60/R15. If i choose, 225/60/R15 do i need to change the rim?
How does Bridgestone compare with Yoko? Is it worth comparing?
What is the cost for each of the above options in Bangalore and where do you recommend me to buy (Bangalore)
MaverikMahesh is offline   Reply With Quote
Old 30th August 2012, 13:35   #135
parsh's Avatar
Thanked: 975 Times
You have been running on dead tyres The rubber must have hardened even if it may look good. At best 5yrs life would have been good. Suggest you stick to stock size unless warranted for any special use or you want that chunky look.
Caution about Yokos, their sidewall is on softer side than competition and prone to sidewall damage, already have that experience. But I think their driving performance is better, I find their grip and braking on wet surfaces really good, allows me to easily cruise at high speeds without bother. Also, IMO they are more silent.
Additionally, check out newly launched Michelin XM2, their sidewall seems thicker than C-Drive as I checked last, but can't say about other differences.
Toyota Innova Crysta : Tyre & wheel upgrade thread Sankar Tyre & Alloy wheel Section 16 30th December 2017 11:44
Toyota Fortuner : Tyre & wheel upgrade thread Turbanator Tyre & Alloy wheel Section 65 24th November 2017 14:03
Toyota Corolla : Tyre & wheel upgrade thread Wraith Tyre & Alloy wheel Section 113 2nd May 2017 14:01
Hyundai Grand i10 & Xcent : Tyre & wheel upgrade thread jkdas Tyre & Alloy wheel Section 10 29th August 2016 17:08
