Old 23rd July 2008, 14:04   #1
ashthedivx's Avatar
Thanked: 22 Times
Default Tyre upgrade for Optra !!
Hey Fellas,
It's time for a Tyre upgrade of Optra. I assume it comes with Tubeless 185/65 R14. I would like to upgrade it till 195 or 205 whichever is best without touching inners !!
My Requirements:
> Silent as much possible i.e. minimum tyre noise. Current one is pathetic.
> On-Road Comfort (No up sizing to 15 )
> Will be shelving off Optra in 2010, so tyres should go good enough for another 40K or so Kms
> Best Value for money
OT: My rear shockers are due for replacement. What do you guys suggest - Tyre change before shockers change or after shockers change ??
Old 23rd July 2008, 17:04   #2
iraghava's Avatar
Thanked: 156 Times
Are the rear shocks also causing alignment issues Ashish?
Old 23rd July 2008, 17:51   #3
mobike008's Avatar
Thanked: 8,319 Times
I think Michelins MVX8 will suit your utmost important requirement ( on road comfort and less noise). However, they ain't cheap
Old 24th July 2008, 09:41   #4
ashthedivx's Avatar
Thanked: 22 Times
Yes they are causing the issue, moreover they have changed the shape of rear tyres a bit too
Old 24th July 2008, 09:44   #5
ashthedivx's Avatar
Thanked: 22 Times
How much are they for ?
Old 24th July 2008, 15:43   #6
iraghava's Avatar
Thanked: 156 Times
Well in that case nothing doing, first the suspension work gets done & then the tyres. Doing the tyres first will mean that the new set will get damaged too.
P.S. MXV8's are not available in the size you want.
Old 26th September 2008, 12:52   #7
ashthedivx's Avatar
Thanked: 22 Times
Well... bumping the old thread. Yup i finally managed to get time and got the rear shockers changed.
Now it's finally time to upgrade/upsize the tyres. Some shortlisted ones are
Michllien XM1+ --- 195/60-14, 205/60-14 or 195/65-14, 205/65-14
Yokohama A Drive --- ???
Yokohama ES100 --- 195/60-14, 205/60-14 or 195/65-14, 205/65-14
Requirements again as the stated one..
Old 26th September 2008, 14:11   #8
iraghava's Avatar
Thanked: 156 Times
Energy XM1/XM1+ - 195/60 R14, 205/60 & 195/65 not available.
A.Drive - 195/65 R14, 195/60 R14 - A.Drive, ES100, Advan neova ()
Old 26th September 2008, 14:21   #9
ashthedivx's Avatar
Thanked: 22 Times
Which one to go finally ??
Chevy Optra : Tyre & wheel upgrade thread throttleking Tyre & Alloy wheel Section 33 4th December 2014 18:03
Should I upgrade tyres for Optra Magnum dockap Tyre & Alloy wheel Section 28 14th November 2013 15:47
Want to upgrade the alloys of my Optra SRV carrazy Tyre & Alloy wheel Section 2 1st March 2010 13:59
Optra Ice Upgrade BUSA In-Car Entertainment 70 18th May 2007 16:54
Optra v/s Optra Design Edition GreenHex The Indian Car Scene 17 29th October 2004 02:47
