Old 9th August 2008, 13:19   #16
narayan's Avatar
Thanked: 1,353 Times
whats rolling of arches mean ?
narayan is offline   Reply With Quote
Old 9th August 2008, 13:24   #17
KSM-Vtec's Avatar
Thanked: 440 Times
it means rolling up the inner surface of the arch which is flat originally. The edge of inner surface of the arch is also sharp and hence damages the tyre when it touches it for various reasons.
KSM-Vtec is offline   Reply With Quote
Old 9th August 2008, 15:44   #18
planet_rocker's Avatar
Thanked: 368 Times
Originally Posted by KSM-Vtec View Post
I have chked the gap. springs are ok. The vertical distance of the wheel from the arch is the same. but the horizontal is not.
you mean alignment problem?
does the OHC vtec have independant rear suspension? is that tyre wearing out uniformly?
planet_rocker is offline   Reply With Quote
Old 9th August 2008, 17:46   #19
Shan2nu's Avatar
Thanked: 89 Times
It sound as if the rear left suspension has shifted a bit, meaning the wheel hub is not at the center of the wheel arch.
Shan2nu
Old 10th August 2008, 15:38   #20
KSM-Vtec's Avatar
Thanked: 440 Times
Please dont get confused.. There is NOTHING wrong with the wheel or its hub. The metal wheel arch(the body of the car) is a little inside. Will get it hammered/pulled out soon.
Shan2nu
Old 11th August 2008, 12:49   #21
KSM-Vtec's Avatar
Thanked: 440 Times
PROBLEM SOLVED ! ! !
Ok here is the outcome of my weekend at the garage. The metal of the wheel arch was pushed out using a wheel jack by the welder(no damage to the paint). Then after testing the ride with a lot of load, speed and sharp turning the problem dint appear to be there anymore. So now i can do my 2k trip down south with my family and not be worried about the problem i was facing.
Thanks a lot guys. A special thanks to Nitroxx for his ideas/inputs.
Old 12th August 2008, 07:27   #22
Rehaan's Avatar
Thanked: 25,038 Times
...The metal of the wheel arch was pushed out using a wheel jack by the welder(no damage to the paint).....
Sounds like a version of fender rolling. They have cool little contraptions to do this nicely >
cya
R
DeEnergia - Power factor correction device freakmuzik Gadgets, Computers & Software 25 10th November 2015 00:31
Honda Jazz @ Discount.... Beginning of Price Correction ! rutvij The Indian Car Scene 81 15th July 2011 13:15
Tappet noise correction - leave the car overnight? Jeep Technical Stuff 3 25th September 2009 22:54
Scratch correction? RX135 Shifting gears 21 9th November 2005 18:02
