Old 30th August 2008, 14:28   #1
sans33's Avatar
Question wrong fitting of tyre
This morning I noticed some difference in tread pattern of front and rear tyres on my Baleno.On close inspection,I observed that,while three tyres are fitted correct,with outside marked on outer side,one is fitted opposite way.These are Michelin XM and have covered app. 6000 kms.
Now what should I do? Keep them as they are,or get it fitted correctly, which as I know is not good as changing rotation in radial tyre makes it weak.
sans33 is offline   Reply With Quote
Old 30th August 2008, 19:33   #2
sans33's Avatar
No solution so far.Where are our tyre specialists?
Come on,I need to know ill effects of such fitment.
Old 30th August 2008, 20:20   #3
rider60's Avatar
Thanked: 47 Times
get if fit in the right direction and if still find any wobbling or braking issues then go for a replacement.
and by the way are the xm1 s not bidirectional?
rider60 is offline   Reply With Quote
Old 30th August 2008, 22:23   #4
Nikhilb2008's Avatar
Thanked: 6,654 Times
Even if they are bi-directional, they can be asymmetrical
Asymmetrical basically means you need to make sure the outside and inside of the tyre are fitted properly. They have clear markings on the tyres.
Unidirectional tyres(like the Yoko S drivers, Advan NEova, etc) can be fitted on the rim in any direction(inside and outside of the tyre doesnt matter) but the tyre has to rotate in the direction indicated.
Old 31st August 2008, 10:01   #5
gd1418's Avatar
Thanked: 656 Times
Do a 5 tyre rotation. Bring in the stepney and put this wrongly fitted tyre in the stepney.
Wrong tyre tube size magiceye Tyre & Alloy wheel Section 10 3rd January 2015 09:03
Fitting Gas - Advantages & Disadvantages Surprise Modifications & Accessories 43 20th August 2009 10:10
Fitting K&N Conical Filter. MexXxentric Modifications & Accessories 10 14th June 2006 12:37
Fitting a sub-woofer ajmat In-Car Entertainment 27 3rd June 2005 11:04
Accord Woofer and Amp fitting Sahil In-Car Entertainment 5 26th May 2004 13:06
