Old 8th September 2008, 00:55   #1
mdesai_1981's Avatar
Arrow Losing air pressure on my optra stock steel rims
hi guys,
i have a chvrolet optra 1.6 with OE stock steel rims with good year nct 5(185/65-r14).
now my problem is this that the tyres tend to loose pressure in about a months time whenever i fill nitrogen! is it true that we get e solution which kind of seals the tyres to the rim and dont let the air pass through. As my uncle in USA has a mercedez ML350 and he says they do a process called as beeding of the tyres so that they dont loose pressure so easily . even if they dont fill nitrogen!
now guys do we get something similiar solution which will help me? or if u people have some other solution to this problem.
ok number 1: i have done a leak check.(everything seems to be fine!)
number 2: the rims are perfectly true as i just got them true through a guy who does it on the machine.(as i thought it might have bent).
Also how can i check whether my rims are 100%true? and any good place for wheel alignment in andheri-west area in mumbai?
mumbai guys please help me find one!
mdesai_1981 is offline   Reply With Quote
Tyre losing air pressure & fast! vishnuvijay Tyre & Alloy wheel Section 147 22nd April 2016 16:31
Tubeless tyres on Steel rims RJK Tyre & Alloy wheel Section 185 18th June 2014 16:01
What to do with stock steel rims? RX135 Tyre & Alloy wheel Section 17 1st February 2008 22:00
