Old 8th September 2008, 18:43   #1
k_ajay's Avatar
Thanked: 488 Times
Default Indica Vista : Tyre & wheel upgrade thread
Members,
I wanted to ask the experts here if the Vista has been right sized with its 175/65 R14 or if it is undersized?
I am highly considering to purchase the Vista before the end of November [just waiting to get my home loan through first and also see if hyundai i20 might debut by then] and wanted to see what upsizing I need to do, so I should include those costs against my total purchase consideration.
Me and my colleague [and tbhp member Sreenivas] feel the 14" inchers look ok but that the wheelwell can safely accomodate 15" wheels. What I do want to confirm, is if it will be safe to put in a 195/60 R15 or is it just best to put in a 195/55 R15? I am thinking that the 19/60 R1 tyres might scrape on full load.
I may be wrong but I fear that 175 width woudn't be enough for highway runs [over 300kms]. FYI I had a 185/60 R13 [goodyear + aura alloys] on my previous Indica DLS, and they gave a good grip and didn't scare me on an emerygency drive from Chennai to Mysore, a year and half back.
Also, how good are the Yokohama S drive tyres? I am looking for good overall grip [dry & wet] and comfort as most important critetia, along with least noise levels.
I am being quoted Rs.4300/- per tyre for the Yokohama S drive [without any bargains].
Welcome all your suggestions
[i know this post must have to be in the 'tyre & alloy' section, but for some reason, I'm unable to post there. Hence, put it here since it's for Vista. Please move the thread if required]
k_ajay is offline   Reply With Quote
Old 8th September 2008, 19:04   #2
condor's Avatar
Thanked: 4,902 Times
I think the 175/65 R14's are ok, and like you said, you can go up a couple of sizes, but the 195's may scrape. I myself want to try 185/60 R14's.
The 175/65 R14's have been doing duty on the Indigo's also.
Old 8th September 2008, 19:14   #3
sidd_city's Avatar
Thanked: 11 Times
Have the deliveries of the car already started?
sidd_city is offline   Reply With Quote
Old 8th September 2008, 19:17   #4
k_ajay's Avatar
Thanked: 488 Times
Post
Condor, thanks for your response.
Are you saying 195 width might scrape or that 195 width on 15 inch tyres might scrape?
I doubt 195 will scrape on 14 inchers but I cannot say the same for 195s on 15" wheels. But I wish I can go for 195 on 15" wheels, since the Vista is now larger and wider, I feel 195s will provide good stability. Not sure about comfort and silent ride on 195/55s.
Old 8th September 2008, 20:27   #5
Akshay1234's Avatar
Thanked: 7,242 Times
i think 195/50 r15 would be the right upsize. you can get s-drives in that size. they will give you good grip and decent comfort levels.
Old 8th September 2008, 21:46   #6
condor's Avatar
k_ajay : Are you saying 195 width might scrape or that 195 width on 15 inch tyres might scrape?
If you do 195's, you will go for lower profile, so that the overall dia does not deviate too much from stock. But it's going to be much more wider, so will possibly scrape.
With the Vista, 15's would definitely look good. That's what I felt when I saw the car.
Generally, it is safe to do up-size by one step, from the stock size.
Old 9th September 2008, 00:59   #7
nitrous's Avatar
Thanked: 285 Times
If the stock size is 175/65/R14, then the optimum balance between ride and handling would be 185/60/R14.
If you need bling, then if available 185/55/R15 (very rare)
or 195/50/15 (quite common)
Old 9th September 2008, 09:24   #8
kpzen's Avatar
Thanked: 1,655 Times
Tire options in 185/60-14
BF Goodrich G sport
Michelin PP
Yokohama ES100
Anna !!
What are the tire options in 185/55-15 and 195/50-15??
Old 9th September 2008, 11:40   #9
Thanked: 103,507 Times
The Indica Vista is not a very powerful hatch. Keeping that in consideration, a 185 patch is the most you should opt for. Anymore will slow the car down as well as compromise its agility. However, if you are inclined toward 15 inchers, then a 195 it is.
Old 10th September 2008, 21:02   #10
k_ajay's Avatar
Thanked: 488 Times
Post
Thanks everyone for your response.
I'm not too keen it has to be a 195, but I was thinking that since the vista is larger than the previous Indica, I thought an upgrade to 195 [I had 185/60 R13 on my previous car] would be ideal [to aid more stability and grip on dry & wet conditions].
Since I don't want to lose the good ride, can you all comment on if 185/60 R15 would be ideal for the Vista?
Also, would it be SAFE to upscale to 195/60 R15? Or would it be too much and scrape a lot?
FYI stock tyre on vista is 175/65 R14. Criteria is I don't lose the good ride quality totally [which is why I got thinking of a 60 profile sidewall].
ak
Old 10th September 2008, 21:05   #11
Akshay1234's Avatar
60 profile on 15" tyres will be too much. i suggest you stick to, at most 195/55 r15 though even that has a slight chance of scraping.
Old 15th September 2008, 12:49   #12
nitrous's Avatar
Thanked: 285 Times
Anna !!
185/55/R15 is present in the Maxxis MA-Z1 catalogue that I have.But, I don't think Indian importer carries that size.
For 195/50/15, here's a link:
http://www.team-bhp.com/forum/tyre-a...tml#post975897
Old 25th January 2009, 06:20   #13
Thanked: 58 Times
Sorry for bringing this one back alive but I've been looking around for the right tire upsize for the indica vista. So, I decide to make up a list of all the wheel sizes the vista can take. While making the list I put the maximum limit for an upsize at 4%. That's because I felt that the vista with its gigantic wheel wells can take that much.
After that I looked through the online catalogues of Michelin, Goodyear and Bridgestone and made a shortlist of all the tires that fit the bill with a size 15" and above.
This is what I came up with.
Items marked with a star may cause scraping because of their size.
First column is the tire size, second column is the percentage difference from the original and the last is the final diameter.
Btw, what is the PCD, offset and rim width on the stock wheels of the vista?? Can anyone who already owns the vista answer question please???
175/80 R12 +0.34 585
175/85 R12 +3.26 602
185/75 R12 -0.17 582
185/80 R12 +3.09 601
195/75 R12 +2.40 597
205/70 R12 +1.54 592
175/75 R13 +1.72 593
185/70 R13 +1.03 589 BRIDGESTONE Potenza GIII BRIDGESTONE Turanza ER60 BRIDGESTONE TuranzaER300 GOODYEAR GT3 GOODYEAR Ducaro GDi MICHELIN XM1
195/65 R13 +0.17 584
195/70 R13 +3.43 603
205/65 R13 +2.40 597
175/65 R14 0.00 583 BRIDGESTONE Potenza GIII BRIDGESTONE Turanza ER60 BRIDGESTONE S322 BRIDGESTONE Potenza RE88 GOODYEAR GPS2 GOODYEAR Assurance GOODYEAR Eagle NCT 5 MICHELIN XM1+
185/65 R14 +2.23 596 BRIDGESTONE Potenza GIII BRIDGESTONE B250 GOODYEAR GT3 GOODYEAR Ducaro GDi GOODYEAR Eagle Ventura GOODYEAR Assurance GOODYEAR Eagle NCT 5 MICHELIN XM1+
195/60 R14 +1.20 590 BRIDGESTONE Potenza GIII BRIDGESTONE Turanza ER60 GOODYEAR Eagle Ventura GOODYEAR Assurance GOODYEAR Eagle NCT 5 MICHELIN Pilot Preceda 1 MICHELIN XM1+
205/55 R14 -0.34 581
205/60 R14 +3.26 602 BRIDGESTONE Potenza GIII
175/60 R15 +1.37 591
185/55 R15 +0.34 585 GOODYEAR Eagle NCT 5
185/60 R15 +3.43 603
195/55 R15 +2.23 596 BRIDGESTONE Potenza GIII GOODYEAR Eagle NCT 5 GOODYEAR Eagle F1 GS-D3
205/50 R15 +0.51 586 BRIDGESTONE Potenza GIII MICHELIN Pilot Preceda 2
175/50 R16 -0.34 581
175/55 R16 +2.74 599
185/50 R16 +1.37 591
195/45 R16 -0.17 582
195/50 R16 +3.09 601 GOODYEAR Eagle Ventura
205/45 R16 +1.37 591 GOODYEAR Eagle Ventura GOODYEAR Eagle NCT 5 GOODYEAR Eagle F1 GS-D3
175/45 R17 +1.03 589
185/40 R17 -0.51 580
185/45 R17 +2.57 598
195/40 R17 +0.86 588
205/40 R17 +2.23 596 GOODYEAR Eagle F1 GS-D3
175/35 R18 -0.51 580
175/40 R18 +2.40 597
185/35 R18 +0.69 587
185/40 R18 +3.77 605
195/35 R18 +1.89 594
205/30 R18 -0.51 580
205/35 R18 +3.09 601
175/30 R19 +0.86 588
175/35 R19 +3.77 605
185/30 R19 +1.89 594
195/30 R19 +2.92 600
205/30 R19 +3.95 606
BRIDGESTONE Potenza GIII 205/50 R15 85V 195/55 R15 84V 205/60 R14 89H 195/60 R14 86H 185/65 R14 86H 175/65 R14 82H 185/70 R13 86H
BRIDGESTONE Turanza ER60 195/60 R14 86H 175/65 R14 82H 185/70 R13 86H
BRIDGESTONE S322 175/65 R14 82H 175/65 R14 82T
BRIDGESTONE B250 185/65 R14 86H
BRIDGESTONE TuranzaER300 185/70 R13 86H
BRIDGESTONE Potenza RE88 185/65 R14 86H
GOODYEAR GPS2 175/65 R14 ---
GOODYEAR GT3 185/65 R14 --- 185/70 R13 ---
GOODYEAR Ducaro GDi 185/65 R14 --- 185/70 R13 ---
GOODYEAR Eagle Ventura 205/45 R16 --- 195/50 R16 --- 195/60 R14 --- 185/65 R14 ---
GOODYEAR Assurance 195/60 R14 86H 185/65 R14 86H 175/65 R14 82H
GOODYEAR Eagle NCT 5 205/45 R16 --- 195/55 R15 --- 185/55 R15 --- 195/60 R14 --- 185/65 R14 --- 175/65 R14 ---
GOODYEAR Eagle F1 GS-D3 205/40 R17 --- 205/45 R16 --- 195/55 R15 ---
MICHELIN XM1 185/70 R13 86H
MICHELIN Pilot Preceda 1 195/60 R14 86V
MICHELIN Pilot Preceda 2 205/50 R15 86V
MICHELIN XM1+ 195/60 R14 86H 185/65 R14 86H 175/65 R14 82H
Are there any other notable tires from other brands which I should look at?? How do the tyres listed above perform?? And what might be their prices?? I need to find a balance between the price and the performance because I'm a little short on the vitamin M. I have little practical knowledge of tires and I could use some pointers from more experienced members.. Thanks in advance.
nukeblitz is offline   Reply With Quote
Old 29th January 2009, 16:56   #14
BloodHound's Avatar
The PCD of the rim of Vista measures a default of 108.
BloodHound is offline   Reply With Quote
Old 1st March 2009, 18:36   #15
CtrlAltDel's Avatar
Thanked: 24 Times
i have a basic question here:
would any 14" Alloy wheel accommodate both 175/65 R14 and 185/60 R14 tyres or do I require different alloys for them?
I was thinking of going for Alloys for my Vista first (for the 175 tyres) and then upgrade to 185 tyres later. can i use the same alloys in this case?
if not, i better wait and upgrade to alloys and 185 tyres together (wallet permitting)
CtrlAltDel is offline   Reply With Quote
Hyundai Grand i10 & Xcent : Tyre & wheel upgrade thread jkdas Tyre & Alloy wheel Section 18 8th July 2018 21:32
4th gen. Honda City : Tyre & wheel upgrade thread Screwdriva Tyre & Alloy wheel Section 350 9th May 2018 19:30
Fiat Palio : Tyre & wheel upgrade thread shahmotors Tyre & Alloy wheel Section 637 26th March 2017 12:56
Help Required Indica Vista Safire or Indica Vista TDI Logical Hatchbacks 63 30th October 2011 08:57
