Tyre & Alloy wheel Section Everything to do with footwear for your car
Thread Tools
Old 15th September 2008, 19:01   #1 (permalink)
inder_s1's Avatar
Default Swift + Yokohoma S drives 205/50 = What psi?
guyz, Want to know what psi is good for 205/50 profile tires? I am running Yokohoma S-drives at the mentioned profile.
Currently, it's 32 psi
NOTE: Mods, pls move it to appropriate section if any.
inder_s1 is offline   Reply With Quote
Old 15th September 2008, 19:07   #2 (permalink)
audiophile's Avatar
Im using a 195/50 in S-drives with a 30 psi. works wonderful.
I feel that 32 psi will give you a more bumpy ride.
Well actually the psi depends on how many people sitting in the car.
If is 2 ppl, then 30 psi is fine.
for 4 ppl, then 32 psi is fine.
audiophile is offline   Reply With Quote
Old 15th September 2008, 19:08   #3 (permalink)
rjstyles69's Avatar
I have been running 33 PSI since my last trip. Gives you a bouncy ride but since the S-drives are soft compound you don't feel it that much. 32psi is ideal and I drive a baleno.
__________________
rjstyles
You never really learn to SWEAR until you learn to DRIVE.
Old 15th September 2008, 19:35   #4 (permalink)
Is it a DDiS ? Why did you opt for 205/50 instead of 205/55 ?
Since mine is diesel Im running 32/30 currently.
Iv used 30/28 before and 28/28 also. With Bangalore's condition of Roads after the rains Iv decided not to keep it so low.
__________________
No fate but what we make!
Old 15th September 2008, 19:39   #5 (permalink)
ramie2400's Avatar
my getz S-Drives 195/50/15 i keep anything between 28-30psi,
__________________
___________
Old 15th September 2008, 19:42   #6 (permalink)
I just realised you havent mentioned the rims.
205/50/16 would be correct.
If its 205/50/15 then incorrect upsize but not a huge issue
__________________
Old 15th September 2008, 19:46   #7 (permalink)
inder_s1's Avatar
Thanks for the info guyz,
Souljah,
It's a Vxi, I have 15" Lenso alloys .. prob is the dealer said 205/50 is ok .. so 32 is good enough then? Why reduce the pressure for the rear tires? Does 32/30 mean 32 for front and 30 for rear?
Old 15th September 2008, 19:49   #8 (permalink)
Dont worry Inder, not a biggie.
Higher pressure upfront only due to additional weight of the DDiS engines. In the petrol it isnt necessary. Again this is a personal habit, many others are running uniform pressure all around. Its your personal comfort after trials.
__________________
Old 15th September 2008, 20:08   #9 (permalink)
audiophile's Avatar
Im using a 195/50 profile with S-drives. 30 psi is what i use with no issues.
32 psi however will be a bumpy ride.
It also depends on the number of people in the car.
If its 2 then 30 psi is ok and if its 4 people then 32 should be fine.
Old 15th September 2008, 20:14   #10 (permalink)
hydrashok's Avatar
I keep mine at 31psi. 205/50-R16 Yoko S-Drives
__________________
Alpine 9887 | TRU Tech STEEL S44 & S500 | Image Dynamics XS65 & CTX6 | Image Dynamics IDQ12 D2V2 | Connection Audison
Thread Tools
Left drag - Swift 205/50/16 7J rim anandkumargb Technical Stuff 15 26th August 2009 11:01
Getting to grips with the Yokohoma S drives vivekji05 Tyre & Alloy wheel Section 45 15th July 2009 02:10
Urgent question about 225/60 r15 Yokohoma C-drives on my Innova akshay1234 Tyre & Alloy wheel Section 9 19th November 2008 12:48
Petra with OZ racing Alloys & 205/50/R15 Yokohoma S drive greatDrive Tyre & Alloy wheel Section 45 20th November 2007 14:09
anyone using 205/45R17 for Swift?? sleepy Tyre & Alloy wheel Section 22 27th January 2007 16:28
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599
