Old 23rd December 2008, 11:21   #31
Eddy's Avatar
Thanked: 5,067 Times
Originally Posted by Nikhilb2008 View Post
There is one near Girgaon skoda showroom. Near to Galaxy hotel.
The phone number is as below.
0124 - 2329111.
This one is walking distance from my office. Is it good ? I am asking because my swift might need some expert work. Its just started pulling towards the left :(
Eddy is online now   Reply With Quote
Old 23rd December 2008, 11:25   #32
suman's Avatar
Thanked: 257 Times
Originally Posted by suman View Post
Just because its located at Atul Kataria chowk doesn't mean the owner's name will also be Kataria
Are you sure it isn't Deepak Batra?
Originally Posted by DCEite View Post
And all this while i was thinking that the chowk as named after that tyre dealer.
Just spoke to GD & he confirms that it is indeed Kataria
I was thinking that its owned by Deepak Batra who owns the accessories shop next to it.
Old 23rd December 2008, 11:25   #33
Nikhilb2008's Avatar
Thanked: 6,591 Times
It uses Hunter machines. If the technician is good, it should be fine.
Since GD said that the other branches are decent, I think it should be quite good.
Why dont you be the guinea pig?
Old 23rd December 2008, 12:03   #34
RedMM340's Avatar
Thanked: 24 Times
Originally Posted by gd1418 View Post
Bridgestone dealer in the Sikanderpur Market. He has the Hunter 3D machine.
There is one more in Old Gurgaon, near Atul kataria Chowk, opp Payal cinema, next to Karim's. I don't know the shop's name but the owner is Deepak kataria and can give his number if you require. He too has the Hunter machine
Got my Forester aligned at this Bridgestone dealer in the Sikanderpur market. Very big bridgestone dealer that you can see on the main Sikandarpur bypass road.
The work done was absolutely top notch. I had the tires balanced, rotated, and a 3D alignment done. The technician was very good and had a good attitude. All work was done properly and there was good attention to detail.
I would highly recommend this shop.
By way of comparison, I had visited the tyre shoppe in Noida, and I would definitely not recommend them to anybody. Poor attention to detail, and the shop is so busy that they just do not give you any individual attention or care. Tires were mounted in the wrong rotation direction, etc.
Also have had work done at Manjeet auto opposite sector 14 market in Gurgaon, but would not recommend them. The alignment tech has an extrememly bad attitude, and almost got a slap on the face from me when he did my alignment. Needless to say I will not go back to this shop.
RedMM340 is offline   Reply With Quote
Old 23rd December 2008, 12:08   #35
suman's Avatar
Thanked: 257 Times
Can you share the wheel balancing charges, do they also charge you on a per wheel basis for alloys? What was the charge for alignment?
TIA
Old 23rd December 2008, 12:21   #36
RedMM340's Avatar
Thanked: 24 Times
TIA
100 per wheel for balancing
500 for alignment
Was well worth the price, as the work quality was very high. And I am a tough customer to please. I actually go under the vehicle and look at what the technician is doing, and confirm the alignment is o.k. on the computer screen.
Old 23rd December 2008, 12:26   #37
suman's Avatar
Thanked: 257 Times
500 for alignment
Thanks, quite expensive but worth it for peace of mind I guess. Checking the computer is something most of us would do, I do follow the technician closely as well.
Old 23rd December 2008, 13:36   #38
Eddy's Avatar
Is sikanderpur the market next to Global Business Park ? Near the Metro construction ?
Old 23rd December 2008, 13:53   #39
suman's Avatar
Thanked: 257 Times
Yah, go past GBP & keep following the main road - where it curves right, look out for the shop on your left. Located before the host of Sanitary & Plumbing fittings shops.
Old 23rd December 2008, 14:14   #40
phamilyman's Avatar
Thanked: 3,526 Times
By the time I got to speak to Guruji, I got a decent cheapo job done at MA Tyres - 250 total alignment, balancing included for OEM wheels.
They first balanced each wheel - even the stepney had issues, rotated X, and then they put these four infrared thingies on the tyres to align it, and did some minor natak.
Its way cheaper than what Competent wanted me to spend - Rs 1000 :-)
You could check it out for smaller jobs - its about 100m shorter of the one guruji said. For big thingies, guruji's advice wonlee.
Old 24th December 2008, 16:59   #41
Eddy's Avatar
Just back from a alignment, rotation and balancing job from T-Mart, Next to Galaxy hotel and Skoda showroom in Gurgaon.
They have done a decent job. The steering position had to be corrected a little.
Rates:
Alignment: 150
Balancing: 40 Rs per tire including the weights. This for stock rims (Swift).
Will scan the "result" sheet of the alignment and put up here for reference
Total: 310 bucks and 20 mins. Satisfied myself with a test drive on the expressway.
Thanks guys for the help !!
Old 31st December 2008, 16:49   #42
sugam's Avatar
Thanked: 46 Times
Default Indica trouble
Hi all
I need some advice. Thought maybe you guys could help me.
I have an Indica Xeta GLS (Power Steering).
I recently was driving in Delhi at about 60Km/Hr and my front right wheel went over a huge pot hole and after that jerk, I realised that to keep my car going straight, I had to keep my steering turned about 10 degrees to the left.
No more problems apart from this. And this is the first time this has happened to me. Before the incident, my steering used to be normal.
I was wondering if this problem could be related to wheel alignment?
Please enlighten me.
Thanks a ton.
Sugam.
sugam is offline   Reply With Quote
Old 31st December 2008, 19:09   #43
Originally Posted by sugam View Post
Hi all
Thanks a ton.
Sugam.
Yes. That is definitely a wheel alignment problem.
Old 1st January 2009, 11:47   #44
m4ugr8's Avatar
Thanked: 123 Times
I need a good tyre balancing and rotating guy in South Delhi, Anybody has info on this, The charges etc??
m4ugr8 is offline   Reply With Quote
Old 3rd January 2009, 22:10   #45
sugam's Avatar
Thanked: 46 Times
Thanks a lot! It was actually a wheel alignment problem...
I got it done here in West Delhi (Tilak Nagar) for 100 Rs.
Works great now!
Thanks again!
Wheel Alignment & Balancing Surprise Tyre & Alloy wheel Section 174 20th February 2018 12:23
Wheel alignment or wheel balancing?? leodelg Tyre & Alloy wheel Section 27 22nd June 2011 00:44
Breakdown Assistance for 1 year, Wheel Alignment & Wheel Balancing just for Rs 199 Mitsun Soni The Indian Car Scene 11 8th March 2011 11:02
Newbie questions - wheel balancing, wheel alignment. johy Technical Stuff 8 6th December 2006 10:39
