Old 9th October 2010, 09:39   #121
AWD
Thanked: 218 Times
It would be great if someone could put up the DIY tech. for a mushroom patch/inside out puncture repair. Have heard its better than the regular puncture repair from outside & prolongs tyre life.
AWD is offline   Reply With Quote
Old 20th October 2010, 13:51   #122
Thanked: 69 Times
Originally Posted by slicvic View Post
Around 50 kms a day. Got an air inflator in the car so thats not a problem. No permanent damage to the tyre in case i delay it for a week right?
could you please give the details of the tyre infalator you are presently using in you car? also is your car running on alloys???
mh09ad5578 is offline   Reply With Quote
Old 21st October 2010, 01:33   #123
iraghava's Avatar
Thanked: 156 Times
AWD - The mushroom patch is safer but it is unfortunately not a DIY job since it involves removing the tyre from the rim and then repairing it. Which can only be done if one has access to a tyre changer or a trusty pair of big hammers
Wouldn't recommend DIY'ing that.
Old 21st October 2010, 09:04   #124
AWD
Thanked: 218 Times
Yeah forgot the tyre removal process! Still could you give the steps involved after tyre has been removed, this will help over-seeing the process while its carried out by tyre mech.
Also, what are the charges for mushroom patch?
Old 22nd October 2010, 16:02   #125
slicvic's Avatar
Thanked: 369 Times
I got the infaltor from dubai, not really sure if it is available here.
You connect the inflator to the dc power source in the car (aka Cigarette lighter socket), then inflate the tyre.
Yes i'm using alloys. The inflator will work on tubeless tyres whether they are on alloys or regular wheels.
slicvic is offline   Reply With Quote
Old 25th October 2010, 22:00   #126
Thanked: 69 Times
thanx for the info, could you post a pic of tht inflater?i wanted to know about alloys coz i was told that using a punctured tubeless tyre would damage the tyre within a very short period of time. i travel in rural areas, thats why have not upgraded to tubeless. But i think your combination of an inbuilt inflater and tubeless tyre would be pretty good to use in such conditions.
Old 9th December 2010, 17:07   #127
fine69's Avatar
Thanked: 877 Times
Default re: DIY Guide: How to temporarily repair a Tubeless tyre puncture!
eBay India: Car & Bike Auto Tubeless Tyre Puncture Kit (item 110619756524 end time 02-Jan-2011 15:56:15 IST)
Can anybody suggest is its a good idea to buy tubeless tyre puncture repair kit off ebay?
fine69 is offline   Reply With Quote
Old 12th January 2011, 14:20   #128
arin_12's Avatar
Thanked: 20 Times
Recently while I was went for servicing of my vehicle I found that there is a nail sitting inside the tyre. The service man asked me if I wanted to remove. But I said no
I wanted to try my first hand with the Kit which I bought recently. It was just Rs.180 and it contain a cement tube also.
Now please can some one suggest me when to apply the Cement and how ?
arin_12 is offline   Reply With Quote
Old 5th February 2011, 12:53   #129
Thanked: 199 Times
Thanks. That was a really useful demonstrative guide for tubeless tyre puncture repair. However I have a question I see two puncture strips in the pic is it because there were two punctures? (it is only from a curiosity angle)
Dieseldunk is offline   Reply With Quote
Old 7th March 2011, 16:37   #130
mmxylorider's Avatar
Thanked: 184 Times
Finally purchased the repair kit last weekend and put it to immediate use. FR tire had a screw causing a slow leak. With the right tools handy, and tire turned out to provide maximum accessibility, it took me 10 mins to get it fixed and another 5 mins to top the air using the portable compressor.
@iraghava - Thanks for the pictorial guide.
There is a nail in the RL tire, but the head seems to have sheared off. Due to non-turning wheels, it's difficult to position the tire to provide a good access as well as the required leverage to extract the nail/push the filler.
I thought I'd take off the tire, repair and put it back. BUT - the wheel cover is not coming off easily and there is no way get a cloth in and pull it out. Before I take it to a professional I like to try suggestions from this forum. Thanks!
mmxylorider is offline   Reply With Quote
Old 9th May 2011, 16:07   #131
MurtazaGhiya's Avatar
Thanked: 35 Times
Hey mmxylorider, can you please help me in getting a kit in Pune. Address from where you got yours from? Cost? PM me the details.
The roadside tyrewala's are charging Rs. 80 per punture . Last time I got my bike's puncture's removed, it costed me 400 bucks. I would have rather bought a kit with that amount
Also, how do you figure out if there is a leak somewhere, I mean there is no nail but there is a hole somewhere. Also, did you remove the tyre to fix the puncture?
MurtazaGhiya is offline   Reply With Quote
Old 10th May 2011, 10:10   #132
Thanked: 184 Times
I got mine from Nana peth. There is a tire store that also sells these kits. There are two varieties - one in a pouch, Rs 250 and another comes in the plastic wrapping , Rs 150.
I do not recollect the name of the store but it comes on your right as you enter Nana peth from Mirza Galib Road.
While you are there, I will recommend picking up a few valve stems. Steel wrapped ones are Rs 25 which the puncture guys charge Rs 200+.
If there is a leak, not plugged to some extent by a nail, it will be difficult to identify where it is. Best bet is to take it to a puncture guy and get it repaired. A local guy offered to repair a puncture with my kit with only labor from his side at Rs 40 per puncture.
mmxylorider is offline   (1) Thanks Reply With Quote
Old 23rd May 2011, 13:06   #133
Thanked: 23 Times
I also have also got same reply from a shop in Bhawanipur (not Bhanu Bhai) and said that it is better to use Foot pump. I have bought it though have not used it yet.
Rup_Chatterjee is offline   Reply With Quote
Old 17th June 2011, 13:35   #134
This is a great guide. Thanks iraghava.
For someone who ends spending on atleast one puncture repair per month, i find this very useful and will help in saving some money. I am also interested in buying the 12V compressor for inflating tires. Any suggestions on where I can buy the repair kit and compressor in Hyderabad? I am concerned that there are duplicate products in the market and so would like a referral please.
Cheers!
cs.giri is offline   Reply With Quote
Old 17th June 2011, 14:56   #135
Thanked: 420 Times
Well Last month I drove from Bangalore -Shirdi (day1) , Shirdi - Bombay (Day 2) then 3 days in Bombay and back to Bangalore.
In Shirdi while leaving i noticed that the rear right tire had a screw , I left it as it is as pulling out will cause a leak and drove to Bombay and speed was above 120 on NH-3 and ghat road on ghoti was bumpy . Could not get time in Bombay for next 2 days and drove in the city and got the puncture repaired 3ed day after driving some 700 KM.
So don't think that it gets damaged so easily , I regretted not carrying a serv puncture repair kit because the repair guy charged me 120Rs.
amitk26 is offline   (1) Thanks Reply With Quote
Symptoms of tyre puncture in tubeless tyres joy_swift Technical Stuff 60 28th April 2018 18:33
Sidewall puncture in tubeless tyre naveendhyani Tyre & Alloy wheel Section 108 26th April 2018 19:33
Hydraulic Jack, 12V Compressor, Tool Kit & Tubeless Tyre Puncture Repair Kit @ 2300Rs prateek99 Modifications & Accessories 52 22nd June 2016 01:40
Temporarily repairing a puncture with Fevibond! anilntny Tyre & Alloy wheel Section 14 22nd July 2015 07:58
500Km with a Tubeless Tyre puncture - Had no Clue! d_himan Tyre & Alloy wheel Section 31 8th October 2013 17:44
