| Tyre & Alloy wheel Section Everything to do with footwear for your car |
| | Thread Tools |
| | #31 (permalink) |
| Senior - BHPian | iraghava thanks a lot for this thread though i knew the process but was not sure...this has made me clear about it....great Job![]()
__________________ " Everyone wants to park their car/bike in the shade(of a tree) but none wants to grow one!, SAVE TREES/GROW TREES" |
| | #32 (permalink) | |
| BHPian | Quote:
![]() Cheers, Rajan
__________________ ___________ No message. Here to learn... | |
| | #35 (permalink) |
| BHPian Join Date: Jun 2006 Location: bangalore
| iraghava, that is precisely my point. Not many people are aware of the different kind of bolts/nuts which can be used. Usually, if you get after-market alloys, a good tyre shop puts these on. Believe me these guys, I helped were lucky that I had the key in my car and that fit for them. (I had to go in another friend's car to the resort where my car was parked & I had to drive 4+4km back and forth to get them the key, but I realized how difficult it was for them )! And they were lucky to run into my friend who knew one of them, so he asked me. Last edited by lancer_rit : 28th September 2008 at 21:05. |
| | #37 (permalink) |
| Senior - BHPian | If a tyre is removed and put back, it doesn't affect the alignment, but balancing is a must. let me be more explicit - when I said tyre I mean the rubber and not the rim. A tyre is removed for a purpose and not just like that; say for mending a puncture etc. If that's the case then balancing is a must. Alignment does not get affected even by removing the wheel and putting it back.
__________________ Royal Enfield Bullet 1962 All Black 1998 Safari 4x4 All Black 2004 Scorpio GLx Last edited by gd1418 : 28th September 2008 at 21:27. |
| | #38 (permalink) |
| Senior - BHPian | Thanks Ishaan for the step by step tyre changing guide. Tell me if you know (or if anyone else does) why do the European's have this silly & ridiculous system of putting the wheels on the car ? The lug nuts need to be juggled while holding the tyre & voila you get to fix one thread into the drum / disc nstead of the Jap way of doing things, simply slide the tyre into the already fixed threaded lugs !????????This is one MAJOR grouse I have with European cars.....GGGGGGRRRRRRRRRRRRR ![]() Is there a way of going to the more sensible way of changing a tyre ??? Plus having a Slip disc (in the vertebrae) does not help very much :-(
__________________ Everybody is entitled...... to an opinion !! Last edited by Ricky_63 : 28th September 2008 at 21:33. |
| | #40 (permalink) | |
| Distinguished - BHPian ![]() | Quote:
Yup, same problem here, I have a slipped disc too. Hence, only do the change if there is no other option.
__________________ Reminds me of my safari in Africa.Somebody forgot the corkscrew and for several days we had to live on nothing but food and water. | |
| | #41 (permalink) | |
| BHPian | Quote:
Bolted joints are one of the most common elements in construction and machine design. They consist of cap screws or studs that capture and join other parts, and are secured with the mating of screw threads. In this method the bolt is tightened to a calculated clamp load, usually by applying a measured torque load. The joint will be designed such that the clamp load is never overcome by the forces acting on the joint (and therefore the joined parts see no relative motion). The Japanese wheel / axle joints are also know as Stud joints: The Japanese stud joint does not have a designed clamp load but relies on the shear strength of the bolt shaft. This may include clevis linkages, joints that can move, and joints that rely on locking mechanism (like lock washers, thread adhesives, and lock nuts). Check this for more details: Bolted joint - Wikipedia, the free encyclopedia Cheers, Rajan
__________________ ___________ No message. Here to learn... Last edited by PatchyBoy : 28th September 2008 at 23:07. | |
| | #42 (permalink) | ||||
Not to mention, that my cars do about 40k kms a year on average & we do not employ drivers most of the time apart for the occasions when my mother needs to travel out of station. About the Slime etc., I've never been convinced of their functionality (even more so ever since the introduction of tubeless tyres) and so have never used them. Have you used them? What's the experience been like? Quote:
Lohith/Srijit/Ricky - Thanks!
__________________ Reminds me of my safari in Africa.Somebody forgot the corkscrew and for several days we had to live on nothing but food and water. | ||||
| | #43 (permalink) |
| BHPian | Please do a "how to replace headlight bulbs and adjust the beams". It's necessary to know for everyone traveling on the highways. Changing battery is not so critical to know because you buy a battery from a shop and they will do it in any case. But it's nice to know, because if the dealer is far away and doesn't want to send the battery to you, you might need to do it yourself. Wheel balancing/alignment is a machine oriented mechanic's job that cannot be done on your own. I think jump-starting a car is easy and important to know.
__________________ You gotta know when to hold em, know when to fold em, Know when to walk away and know when to run. |
| | #44 (permalink) |
| Senior - BHPian Join Date: Jun 2007 Location: Chennai
| Diagonally tightening the nuts: this is to ensure that the wheel is properly flush, otherwise it might settle at a slight angle. I don't think it is so important for removing, but no reason not to! Somebody mentioned WD40. My immediate reaction was that to lubricate one's wheel nuts is not a good idea! Any more on this? |
| | #45 (permalink) | |
| Senior - BHPian Join Date: Sep 2007 Location: New Delhi
| Quote:
I too am 'new' to these, but I have had Slime in my Scorpio's tyres about 15 months now. One day, I saw a biggish nail in the right front tyre. I did nothing about it for nearly 2 months. Regular check of air pressure showed zero loss. Then one day I jacked up the car, pulled out the nail and manually gave the wheel a spin. This is very important as these preventatives ONLY work in dynamic condition and will often FAIL in static condition. On pulling out the nail a sssshhhhh sound began, and after the wheel had made about 6 or 8 revolutions, the sound abruptly stopped. The Slime had done its job! Total pressure drop was about 1 psi, measured, as always, with the 'pen' type gauge I carry. Most interestingly, the air loss from the tyres has been unbelievably low over these 15 months or so, after adding Slime. As I had done the procedure during summer (June), I had to add about 2 to 3 psi when winter had set in (Mid-November). From 32 psi (which is what I maintain) the pressure in all tyres had come down to 29~30 psi. Recently (in Sept) I had to add about 2 psi to each tyre. That is the sum total of air filling that has had to be done in 15 months. Currently, I can say I am more than satisfied with the Slime treatment. I consider the Rs.5000/- as well spent, for sliming the tyres. Other claimed benefits are that it keeps wheels running much cooler as these preventatives are esentially ethylene glycol based, ie. they are very good thermal conductors. It is claimed that correctly inflated (as opposed to under inflated) and cool running wheels are likely to last 25% more than 'untreated' wheels. I am in no position to comment on this aspect yet, and will probably never be as my annual running is about 8000 kms, mostly highway (about 40%) and (bad) mountain roads (about 60%). The tyres will probably be due for renewal on account of ageing rather than wear! More info can be googled, and some sites are given here: Improve car performance, Car performance enhancements, Engine performance improvements, car performance products, car care products, engine performance products, engine performance enhancements, OWS, OWS India, OWS products, OWS products India, Tecta Ride-On ® | Tire Protection System Flat Free Tire Sealant - Prevent Flat Tires With Our Revolutionary Tire Sealant | |
| Thread Tools | |
Similar Threads | ||||
| How to buy Team-BHP Stickers : A pictorial guide | Administrator | Announcements | 0 | 14th February 2009 00:33 |
| How to change wiper blades: A pictorial guide | johy | Technical Stuff | 8 | 17th July 2007 16:03 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
