Old 19th June 2007, 13:02   #136
finneyp's Avatar
Thanked: 175 Times
Palio & Petra owners: In Aura range of Alloys, if you need a 98 PCD 14" Alloys, they have only one design C1455 shown below, price is Rs.17,450 for a set of 5 pcs.
finneyp is offline   Reply With Quote
Old 19th June 2007, 13:53   #137
typeOnegative's Avatar
Thanked: 20 Times
Thanks a tonne Finney. That seems a reasonable price as well.
typeOnegative is offline   Reply With Quote
Old 19th June 2007, 20:07   #138
binz's Avatar
Thanked: 412 Times
Why dont you just pick up a set of palio alloys,..the ones that come on the GTX,..they are 14" i think/..
Old 19th June 2007, 20:49   #139
Thanked: 20 Times
I think it is very tough to get those. Somebody, I forget who, also mentioned that Fiat is not willing to supply those. The alloys that do duty on the Stile.
Old 20th June 2007, 10:29   #140
finneyp's Avatar
Thanked: 175 Times
TypeO, Just called up Manipal Motors (Tata Fiat dealer), to my surprise, Palio OEM 14" Alloys is available for sale, but it is priced at Rs.4425 per peice, whereas the Aura 14" 98 PCD Alloys is priced at Rs.3490 per peice. A whopping difference of Rs.1000 per peice.
Is it worth it?
Old 20th June 2007, 11:44   #141
moralfibre's Avatar
Thanked: 6,533 Times
Yes it is worth it! Looks better than the Aura design you chose.
Old 20th June 2007, 12:06   #142
finneyp's Avatar
Thanked: 175 Times
Thanks Moral, even I liked the design of OEM Alloys!
Will go for the OEM then!
Old 20th June 2007, 12:40   #143
moralfibre's Avatar
Ask them if they warranty this OEM alloy that you purchase. If they dont then rack their brains to give you a warranty . I would do that if I bought them from Fiat. If you want to throw your stock rims throw them in my direction please alongwith your worn out tyres. A friend needs them here desperately and will pay you a good price too.
Kiran
Old 20th June 2007, 17:22   #144
Thanked: 20 Times
Is it worth it?
Hmm that is good news Finney. I am going to go in for alloys a bit later. Will ping Fiat at that time. The difference is okay to me as the Fiat alloys look better than the Aura ones.
Old 12th August 2007, 09:09   #145
Default Should I go for 185/60 as opposed to recommended 185/65 on 14" rims?
Dear friends
Reading threads on tyres has taught me a lot. I'm exchanging my palio 1.6 stock tyres for Michelin Energy XM1. But size is confusing.
Question: Should I go for 185/60 as opposed to recommended 185/65?
14" diameter = 7" radius or 178mm (7*2.54*10) (I've rounded to nearest mm)
stock radius = 175*.65 + 178 = 113.75 + 178 = 292mm
circumferance = 2*22/7*292 = 1835mm
185/65 radius = 185*.65 + 178 = 120.25 + 178 = 298 mm
circumferance = 1873mm (+38mm)
185/60 radius = 185*.60 + 178 = 108 + 178 = 286mm
circumferance = 1873mm (+38mm) = 1798mm (-37mm from stock)
185/60 has advantage of shorter tyre wall, lesser deformation on curves, leading to better high speed cornering.
As you can see 185/60 is closer to stock than recommended 185/65.
Don't want 195/65 because of mild impact on FE. Palio 1.6 isn't known for fuel efficiency
Comprehensive recommendations here
http://www.team-bhp.com/forum/tyre-a...tml#post497430 (READ FIRST: Choosing The Right Set Of Tyres for your Car)
Experienced members - advise please. Thank you.
AmitNone [hide]
amitsingh08 is offline   Reply With Quote
Old 12th August 2007, 11:59   #146
iraghava's Avatar
Thanked: 156 Times
Amit - The possible options for upsizing in your car are:
185/60 R14
185/65 R14
195/60 R14
So yes, you can use the 185/60's since they'll give you a nice compromise between increased grip & also not have much effect on the FE. The difference in OD between 175/65 & 185/60 is -0.9% only so that is not an issue.
195/65 is not recommended since the OD difference is going to be 4.46% which is much above the permissible limits.
Old 12th August 2007, 14:05   #147
Thanks iraghava, I've confirmed 185/60 with dealer
Old 1st October 2007, 17:37   #148
Exclamation Upsize tyre size for my Fiat Palio 1.6 Sport
Iam looking to upgrade the tyres on my Palio 1.6 Sport (from the stock 175/60 R14, alloys) to either 195/60 R14 or 205/60 R14.
couple of questions -
1. Which is better upsize option?
2. Which tyre is the best option - Bridgestone Potenza G3 or Michellin
3. R these tyres V-rated?
I'm willing to sacrifice a little bit of handling and grip for better ride comfort and tyre life.
FerrariRulez is offline   Reply With Quote
Old 1st October 2007, 20:07   #149
WasavaTyres's Avatar
Thanked: 255 Times
If you plan to retain your existing rims then I suggest you go in for 185/70/R13 tires. Will fit like a breeze.
WasavaTyres is offline   Reply With Quote
Old 1st October 2007, 20:45   #150
greatDrive's Avatar
with 14 inches Alloys/Rims, Palio 1.6 has 2 best options
185/65/ R14 - Most of the people go in for this upgrade.
195/60/R14 - Some people in TBHP are using it for their palios/Petra.
Michellin XM1 is a better option if you get a good deal, Potenza GIII is also good tyres for upgrade if you are looking for better tyre life and are long lasting.
Michellin tyres claims to improve the Car efficiency by 10% and are silent than GIII on roads. GIII makes a lot of noise.
Cheers.
greatDrive is offline   Reply With Quote
Fiat Linea : Tyre & wheel upgrade thread vancity Tyre & Alloy wheel Section 237 10th July 2018 16:26
Hyundai Grand i10 & Xcent : Tyre & wheel upgrade thread jkdas Tyre & Alloy wheel Section 18 8th July 2018 21:32
Fiat Punto : Tyre & wheel upgrade thread furioussphinx Tyre & Alloy wheel Section 664 20th June 2018 10:17
4th gen. Honda City : Tyre & wheel upgrade thread Screwdriva Tyre & Alloy wheel Section 350 9th May 2018 19:30
