Old 25th April 2008, 17:36   #241
planet_rocker's Avatar
Thanked: 368 Times
aura has 98 PCD alloys (C1455 / C3455 for eg.) IMO - but you will have to keep in mind the offset.
best bet will be the fiat OE alloys
planet_rocker is offline   Reply With Quote
Old 25th April 2008, 17:55   #242
Ricky_63's Avatar
Thanked: 394 Times
One can use 100 pcd alloys on the Palio. I have seen them used on Premier Padminis as well as on Palios. These cars have been running without any issues. Check this optiion out & you have many options available to you.
You can run a 205/55/15 though the OD difference is 2.02% (within permissible limits) Or you can go with 205/50/15, OD difference 1.37%
Old 25th April 2008, 18:02   #243
dhaval's Avatar
I think even in Neo wheels you will get 98 PCD alloys. Just find it out with your local tire dealer. But i dont think anybody on the forum will suggest you to go for Aura or Neo. And as others have said, the best thing is to go for the Palio Stile Sports 1.6 alloys with the 185/60 tires on it. Or else just wait to hear what Ishan has to say
dhaval is offline   Reply With Quote
Old 25th April 2008, 18:23   #244
Thanked: 36 Times
Any idea how much would these cost because what if I just buy only the alloys from the fiat dealer and tyres outside? But what are the risks of fitting a 100PCD alloy, would it endanger the warranty?
zaks is offline   Reply With Quote
Old 25th April 2008, 18:38   #245
dhaval's Avatar
Seriously dude I absolutely have no idea as to what will be the exact cost. Instead why dont you yourself ask the dealer about the Palio Stile Sports alloys price and post it here??
Yes buy the tires from outside. Again the costs would be brand specific, expect the prices to be in the range of 3.5k-4k for each tire.
I have not heard/ seen anybody using 100 PCD alloys on Palios.
Old 25th April 2008, 18:49   #246
theMAG's Avatar
Thanked: 1,573 Times
Moderator's note: All Palio/Stile tyre queries merged. Please continue further discussion about the same in this thread.
Old 28th April 2008, 01:50   #247
hellspawn's Avatar
Infractions: 0/1 (10)
I have seen a lot of palios running on 100pcd rims without any problems.Even i'm using 100pcd alloys with 195/55R15 yoko s-drives.
205/55 R15 and 205/50 R15 are incorrect sizes for the palio.
The perfect size for a palio in 15" is 195/50R15.you can also opt for 195/55R15 (odo error is more but you also get better ride comfort).
hellspawn is offline   Reply With Quote
Old 28th April 2008, 11:05   #248
.anshuman's Avatar
Thanked: 9,159 Times
For which car?
195/55-16 can't be fitted in a Palio
For palio obviously,this tyre can be fitted,check it out again.
Old 28th April 2008, 11:18   #249
kpzen's Avatar
Thanked: 1,655 Times
Default 195/55-16
Anshuman.
Are u sure about this?
First of all its a wrong upsize for Palio. Secondly it won't fit in the wheels wells of Palio.
kpzen is online now   Reply With Quote
Old 28th April 2008, 11:23   #250
.anshuman's Avatar
Anshuman.
i am sorry,just checked out the comes with 13 inchers i thought they were 14 inchers.
Old 29th April 2008, 21:00   #251
Thanked: 36 Times
I thinking of 185/70 R14, because I want good grip as well as ride comfort. Will this be fine?
Old 29th April 2008, 21:49   #252
kpzen's Avatar
you mean 185/70-13. right??
Old 30th April 2008, 07:35   #253
Thanked: 36 Times
No, 185/70-14, why, is anything wrong?
Old 30th April 2008, 09:14   #254
kpzen's Avatar
185/70-14 is a wrong upsize for Palio.
The correct upsizes are
13"
-185/70-13
14"
-175/65-14
-185/60-14
-195/60-14
Old 30th April 2008, 11:27   #255
Thanked: 36 Times
13"
-185/70-13
14"
-175/65-14
-185/60-14
-195/60-14
Can you tell me why it is a wrong upsize, because moving to 14" will add 25.4 mm and having 185/70 will bring actually bring down the sidewall thickness by 2.5 mm fro the original 165/80.
Fiat Linea : Tyre & wheel upgrade thread vancity Tyre & Alloy wheel Section 237 10th July 2018 16:26
Hyundai Grand i10 & Xcent : Tyre & wheel upgrade thread jkdas Tyre & Alloy wheel Section 18 8th July 2018 21:32
Fiat Punto : Tyre & wheel upgrade thread furioussphinx Tyre & Alloy wheel Section 664 20th June 2018 10:17
4th gen. Honda City : Tyre & wheel upgrade thread Screwdriva Tyre & Alloy wheel Section 350 9th May 2018 19:30
