Old 3rd June 2008, 10:02   #301
Thanked: 36 Times
Aura has 5 models in 98PCD, with so-so looks and Neo has a few I like. Any idea who stocks these makes with wide choice?
zaks is offline   Reply With Quote
Old 3rd June 2008, 11:34   #302
TomRider's Avatar
Checked neowheels.com. They have a lot of 98PCD wheels and look good too.
Find a dealer and try calling them up!
Neo Wheels India
TomRider is offline   Reply With Quote
Old 8th June 2008, 23:59   #303
Default Palio tyre upgrade
The FIAT Palio Stile 1.1 comes stock with either Goodyear GPS2 or Bridgestone S248, in size 165/80 R 13.
Is an upgrade to a wider tyre, 185/70 R 13, recommended? I could get this size in both, Michelin XM1s and Yokohama A.drive's.
Cornering ability and road grip will be improved with a wider tyre; however will I experience a drop in FE, and if so, by how much.
Also, will ride comfort be improved?
All in all, do you guys advice upgrading?
P.S. I wish to stick to 13"
luvjascha is offline   Reply With Quote
Old 9th June 2008, 00:35   #304
How much would XM1s and A.drive's cost me in size 185/70 R13.
Old 9th June 2008, 00:51   #305
iraghava's Avatar
Thanked: 156 Times
Regarding your PM, there are no Michelin or Yokohama options available in 165/80 R13.
Old 9th June 2008, 01:03   #306
Very well then. I know that XM1s and A.drive's are available in 185/70 R 13, and my question is, if I should upgrade to this size.
Road grip and cornering ability would certainly improve, but how about FE and ride comfort.
Old 9th June 2008, 02:32   #307
iraghava's Avatar
Thanked: 156 Times
I think I've given you clear answers about the same previously over PM a couple of times. I cleared my outbox so don't have a copy now.
Old 9th June 2008, 02:42   #308
Ishan, I feel tempted to upgrade, for two reasons -
1. I'd be getting some of the best tyres, i.e. XM1 and A.drive
2. Improved cornering and road grip ability.
If the drop in FE is significant (don't know what effect the upgrade would have on ride comfort), would I be doing more harm than good, if I went in for wider tyres? (185/70 R13).
Or should I stick to the stock tyres.
Will be interested in your suggestions.
Old 9th June 2008, 02:49   #309
iraghava's Avatar
Thanked: 156 Times
185's on the 1.1 wouldn't be my choice for multiple reasons to be frank. It's already underpowered & wider tyres will do it no favours with regards to accelaration & FE.
Old 9th June 2008, 03:00   #310
So, you're suggestion is to stick to the stock tyres then, correct?
Old 10th June 2008, 10:57   #311
80 series tyres are no-no. You should switch to 185/70 R13
MICHELIN and YOKO should cost you anywhere between 3K to 3.2K.
When you will swith from tubed BRIDGESTONE or GY to Tubeless MICHELIN OR YOKO, there will be no FE drop.
itzzme is offline   Reply With Quote
Old 10th June 2008, 11:16   #312
bottle's Avatar
Thanked: 138 Times
I have a palio 1.2 and it seems to be pretty ok with the 165/80 profile tyres and ride seems to be better than my 1.6 with the 14inchers. I too would suggest sticking to the same profile since the 1.1 is even more underpowered compared to the 1.2 and may have an adverse effect. Do talk to some other 1.1 owners who have upgraded their tyres though.
bottle is offline   Reply With Quote
Old 10th June 2008, 17:43   #313
The S248 and GPS2 that come as stock tyres are tubeless, not tube type.
Old 10th June 2008, 20:48   #314
finneyp's Avatar
Thanked: 175 Times
luvjascha, Patchyboy owns a Stile 1.1 and has upsized his tires to 185/65 R14 (Michelin XM1), and he is quite happy with his car's performance post upsize.
Do check with him for more info.
finneyp is offline   Reply With Quote
Old 11th June 2008, 10:45   #315
168/80 R13 has a lot of understeer feel..
Fiat Linea : Tyre & wheel upgrade thread vancity Tyre & Alloy wheel Section 237 10th July 2018 16:26
Hyundai Grand i10 & Xcent : Tyre & wheel upgrade thread jkdas Tyre & Alloy wheel Section 18 8th July 2018 21:32
Fiat Punto : Tyre & wheel upgrade thread furioussphinx Tyre & Alloy wheel Section 664 20th June 2018 10:17
4th gen. Honda City : Tyre & wheel upgrade thread Screwdriva Tyre & Alloy wheel Section 350 9th May 2018 19:30
