Old 15th September 2008, 14:53   #406
TomRider's Avatar
Originally Posted by great_guns View Post
Which measurement is the 175 or 185 that you quote here? The 14" is the diameter of the wheel, right? I assume the 175 is the width of the tyres. Am I right?
Could you please also answer my question of the comparative effects on grip/mileage/turning radius/braking for the three tyres (stock, 13" alloys, 14" alloys)?
Thanks,
-Ganesh
185/65R14 or 175/70R14. If u have any plan to compromise on the ride quality, go for 195/55R15.
TomRider is offline   Reply With Quote
Old 15th September 2008, 21:04   #407
chetan's Avatar
i have a query since the spare wheel doesnt come with an alloy will the 185/60 R14 fit ? and what should the correct Tyre pressure be , i currently i keep 29 on the stock tyres on my 1.6 .
chetan is offline   Reply With Quote
Old 15th September 2008, 21:28   #408
bottle's Avatar
Thanked: 138 Times
Using 185/60 tyres and it fits fine on the spare rim. if you use 195 profile the tyre sticks out a bit and you might have trouble loading luggage
bottle is offline   Reply With Quote
Old 18th September 2008, 22:52   #409
Default Need Advice for Palio 1.2 ( R13 Tyres ) Replacement
Hi All,
After reding this thread, I kind of decided on following options. Please advice which one is better from your perspective / past experience.
I have Palio 1.2 2001 Model ( I think original model just after the launch may be in first 200 Palios sold in India ).
I am due to change it's all 4 tyres in next 1 month after 44K Estimated Running. I love the Palio the way it handles now performance wise but lately the ride quality has become rough & noisy. It's OEM S248 165/80/R13 tyres.
So My Expectation from new set of Tyres is
1) Maintain the same "Handling / Cornering / Braking / Steering Response AKA Performance as of now OR Very close to it. If it improves that's even better "
Also
2) Make the Ride quality more QUITE & Smooth compare to as of now.
3) Going for Tubeless Radial ( and hence S248 is out of question ).
In short I want to maintain "at least" same as point 1 BUT get Improvement on point 2 "Ride Quality" .
The Constraints I would like to keep is
i) Keep the same 13" Radious.
ii) Not looking for Alloys as It's late for that. ( Hmm some of thinking abt upsizing to Alloy 14" is still going in my mind but the financial numbers need clarity for this decision ).
Accordingly following options came out for me.
Option-A) Bridgstone Potenza G3 185/70/R13
Option-B) Michellin XM 185/70/R13.
Questions
1) How the generic upsizing to 185/70/R13 ( from 165/80/R13) will impact on my car in terms of points 1&2.
2) Which one from Option A or B
3) Do you suggest any other alternative for R13 tyre Tubeless Radial
4) IF I go for R14 Upsizing
4-a) The impact on Performace & Ride Quality ( I think performance will degrade a little due to higher CG but Ride will be much smoother due to reduction in ground noise )
4-b) What would be it's cost ( alloy wheels replacement .. second hand is fine too )
4-c) Is it worth it ? ( Please look this from my perspective parameters as given in my Signature )
Thanks in advance for your response.
*SZ*
SeventhZense is offline   Reply With Quote
Old 25th September 2008, 23:46   #410
Originally Posted by SeventhZense View Post
Hi All,
Hmm Seems like our Palio Fans lost thier interest or busy in Driving
I have another question
5) For Tubeless tyre, Alloy Wheel is necessary ? or we can do with our OEM Wheel ( The Article on Team-BHP says you can but Safety may compromise a little. )
Old 11th October 2008, 11:47   #411
ajayr's Avatar
Thanked: 19 Times
I have a Palio Stile 1.1 SLX running stock tyres 165/80 R13. Which is the correct upsize?
Michelin Energy XM1+ 185/60R14
or
Michelin Energy XM1+ 185/65R14
I am planning to fit Aura E01455 14'' 98 PCD alloys.
Thanks!
-Ajay.
ajayr is offline   Reply With Quote
Old 11th October 2008, 13:45   #412
finneyp's Avatar
Thanked: 175 Times
Ajay, for Palio Stile 1.1, the correct upsize would be: 185/65 R14.
finneyp is offline   Reply With Quote
Old 11th October 2008, 16:44   #413
Thanked: 36 Times
Hi All,
Also
Questions
*SZ*
To answer your questions, maintaining the same size as stock would give you the same ride quality. Upgrading (wider tyres) just the tyres would probably improve the ride quality but upsizing (larger dia) would change the ride quality depending on you choice of size.
If just upgrading then you can go ahead and do it, with broader tyres it improves the handling and braking and your ride quality will remain the same or improve.
If upsizing then if you choose 14" rims then with lager dia you get improved handling and cornering but your ride quality might suffer a little bit or remain the same. With 14", I don' think 185/70 would be the correct size as it might brush the wheel wells on full load. The correct size being 185/65 or 185/60, the former giving better ride of the two.
The new alloys cost in the range of 4k-6k per wheel, don't know about used ones.
zaks is offline   Reply With Quote
Old 13th October 2008, 17:28   #414
ajayr's Avatar
Thanked: 19 Times
Thanks Finney, I have upsized
Alloys: Aura 98 PCD set of 5: Rs. 19,500
Tyres: Michelin Energy XM1+ 185/65 R14: Rs. 3,450 per tyre
Dealer: Super Tyre Tec, JC Rd, Bangalore.
Old 13th October 2008, 19:44   #415
bottle's Avatar
Thanked: 138 Times
Questions
*SZ*
No use doing any upgrades on the 1.2, It does really well on the stock sized tyres so stay with that. Going to 14inch wheels affects the ride quality (bad) and wider tyres might make the steering harder.
Just look to get new tyres of the same size 165/80 R13 , so far I think thats the perfect size for a palio.
Currently using goodyear gps2 for fronts and bridgestone something or the other for rear and rides pretty good with hardly any noise
either goodyears or michelins should work fine for you
Old 13th October 2008, 19:56   #416
finneyp's Avatar
Thanked: 175 Times
I have upsized
Congrats Ajay! Am sure you'll be enjoying the comfy ride on Michelin XM1+!
Can we have some pics?
Old 18th October 2008, 16:37   #417
ajayr's Avatar
Thanked: 19 Times
Yes indeed, the new tyres are very silent and I believe the braking distance has also reduced. Some pics.
Fiat Palio : Tyre & wheel upgrade thread-pic2.jpg
Old 20th October 2008, 10:39   #418
naveen.kk's Avatar
Thanked: 29 Times
Good looking alloys...
I have 205 50 R15 Yokohama tyres for my S10, ride quality is little bumpy, but handling is great. Break feel more trust worthy
naveen.kk is offline   Reply With Quote
Old 21st October 2008, 15:10   #419
Thanked: 105 Times
I put Michelin XM1+ 175/70R13 tubeless in my 2001 Palio 1.2 ELX. And the changes are so noticable that I can not imagin. Earlier one was stock Bridgston R13 tubed. Road noise reduced to 90% and the best part is the lighter steering. I thought steering wheel will become more heavier due to broader tyre but it was totally opposite.
pawan_pullarwar is offline   Reply With Quote
Old 21st October 2008, 15:45   #420
finneyp's Avatar
Thanked: 175 Times
Pawan, Enjoy your Palio on Michelin XM1+!
Ajayr, Aura alloys look very nice! Congrats!
Nice to see a new design in 98 PCD!
Fiat Linea : Tyre & wheel upgrade thread vancity Tyre & Alloy wheel Section 237 10th July 2018 16:26
Hyundai Grand i10 & Xcent : Tyre & wheel upgrade thread jkdas Tyre & Alloy wheel Section 18 8th July 2018 21:32
Fiat Punto : Tyre & wheel upgrade thread furioussphinx Tyre & Alloy wheel Section 664 20th June 2018 10:17
4th gen. Honda City : Tyre & wheel upgrade thread Screwdriva Tyre & Alloy wheel Section 350 9th May 2018 19:30
