Old 3rd May 2011, 12:10   #496
praful's Avatar
Thanked: 442 Times
Default re: Fiat Palio : Tyre & wheel upgrade thread
Originally Posted by khan_sultan View Post
I am running on Maxxis on my S10 for quite some time now. Am perfectly happy with their performance and have found their wet braking to be very good.
I think that they will last long also.
Do you have the MA-V1 or the MA-Z1 Victra ?
praful is offline   Reply With Quote
Old 3rd May 2011, 12:54   #497
planet_rocker's Avatar
Thanked: 368 Times
Wow KS! i guess you need to update your garage details.
Do you have a pic to share?
planet_rocker is offline   Reply With Quote
Old 3rd May 2011, 14:34   #498
bottle's Avatar
Thanked: 138 Times
A better pic of the advans, mods please delete this and merge it with p_r's post if possible
Fiat Palio : Tyre & wheel upgrade thread-dscn1787.jpg
bottle is offline   Reply With Quote
Old 4th May 2011, 19:42   #499
Thanked: 368 Times
praful - as per the website, the Victra is not available in 195-60 R14 - so i guess KS is using the MA-V1
when i was looking for new tyres, a DBHPian recommended Maxxis. so i guess they should be good.
here is a review on Team BHP: http://www.team-bhp.com/forum/tyre-a...xis-tires.html (How good are Maxxis tires)
Old 23rd May 2011, 11:46   #500
Thanked: 368 Times
@ Bottle / Rahul / Khan saab - How much air do you fill in the front / rear tyres (195-60-14)?
The tyre dealer filled 32 in front / rear and i have been filling up with 32. but the ride is a tad bit hard.
Old 24th May 2011, 06:10   #501
bottle's Avatar
Thanked: 138 Times
28 maybe 29 in front
Old 24th May 2011, 11:17   #502
Thanked: 368 Times
i used to fill 29 in the 175/65-14 tubetype tyres - wouldn't this 195s require more air?
Old 31st May 2011, 11:59   #503
bottle's Avatar
Thanked: 138 Times
not sure, but ride gets really bad with 32psi
Old 31st May 2011, 12:13   #504
Thanked: 368 Times
i was weak in physics - someone later cleared that pressure PSi has no link to size of tyre / volume
the front left tyre was leaking air - there was a leak near the valve - got a new valve and reduced pressure to 30 in all. will reduce it further to 29 at the end of this week.
Thanks Ravin
Old 2nd June 2011, 19:11   #505
rudrah's Avatar
Thanked: 29 Times
Originally Posted by viper_711 View Post
I use 185/65 on my Stile 1.6 and ground clearance has definitely improved! I have noticed it over my regular route and can vouch its better - side wall increase needs to be compensated by slightly higher tyre pressure as stock pressure recommendation makes the car handle a bit less responsive.
The Palio Stile already has a extra suspension height beefed up and i guess the 185/65 profile would add more to it. Not a good idea for Palio Stile models. 185/60 would be the perfect upsize.
Buffetfan, i recollected what you suggested in previous post But maybe the 185/65 would work great in Honda but may not on Palio Stile.
P.S. I'm no expert in this.
rudrah is offline   Reply With Quote
Old 3rd June 2011, 10:45   #506
viper_711's Avatar
Thanked: 55 Times
@Rudrah: You're right that the Stile has a slightly raised suspension (also a bit softer) as compared to the older model. This in fact used to give the wheel arches an empty look (a bit like the Indica on 13" rims). The 185/65 makes the wheel well look proportionate IMO.
The other reason to upsize to 185/65 was that with 90% city driving (that too in BLR city!), ride comfort was more important than handling. The added side wall thickness has definitely helped here! For the rare spirited highway run, a slight over-inflation of tyres helps in improving handling.
How's your car doing on 185/60? What are the differences you feel?
cheers
viper_711 is offline   Reply With Quote
Old 3rd June 2011, 13:13   #507
rudrah's Avatar
Thanked: 29 Times
cheers
Ok I get your point. Is it possible for you to put up a pic of it which would be helpful for me and others to understand how the 185/65 looks in the Stile 1.6 as compared to 185/60.
Well I still havent upgraded my tyres but should be doing in this week as the rains will soon be hitting Mumbai
Will update very soon!
Old 3rd June 2011, 13:28   #508
Thanked: 368 Times
Guys, please note the variations - stock 175-65-14 to:
planet_rocker is offline   (1) Thanks Reply With Quote
Old 3rd June 2011, 13:44   #509
viper_711's Avatar
Thanked: 55 Times
@ Rudrah: One image on my Gallery shows the car with 185/65 tyres. Unfortunately I do not have images with the stock tyre for you to compare.
Let me know if you need to see more pics.
cheers
btw, about your signature - I used to feel the same till the Fiesta came into my life!!
Old 3rd June 2011, 14:53   #510
rudrah's Avatar
Thanked: 29 Times
cheers
At the moment, I'm unable to find your Gallery pics.
If you are talking about the fiesta 1.6 Sports then right. Its the perfect competitor to the Palio 1.6
I loved the way it gave me the punch at the push of the Accelerator! Very much fun to drive
Fiat Linea : Tyre & wheel upgrade thread vancity Tyre & Alloy wheel Section 237 10th July 2018 16:26
Hyundai Grand i10 & Xcent : Tyre & wheel upgrade thread jkdas Tyre & Alloy wheel Section 18 8th July 2018 21:32
Fiat Punto : Tyre & wheel upgrade thread furioussphinx Tyre & Alloy wheel Section 664 20th June 2018 10:17
4th gen. Honda City : Tyre & wheel upgrade thread Screwdriva Tyre & Alloy wheel Section 350 9th May 2018 19:30
