Old 31st May 2013, 13:29   #601
finneyp's Avatar
Thanked: 175 Times
Default re: Fiat Palio : Tyre & wheel upgrade thread
Originally Posted by rikhav View Post
Yeah, am looking for comfort for sure since car is driven mainly in city
But would like to have that extra grip and good braking for that few occasions
Yes, XM2 will give you all these, go for it...
finneyp is offline   (2) Thanks Reply With Quote
Old 31st May 2013, 13:43   #602
Thanked: 70 Times
Thanks finneyp
One more query I had was whether to for 185 60 14 or 185 65 14. If the higher profile only results in speedo error I am ok with it. Handling wise I don't think my car attains speeds where slightly higher profile will make any difference
rikhav is offline   Reply With Quote
Old 31st May 2013, 13:53   #603
KarthikK's Avatar
Thanked: 3,498 Times
Is there anyone who has used 195/60R14 size on a Palio stile? We were looking for a tyre upgrade for my friend's Palio 1.6, and had zeroed in on 185/60R14 when we found that XM2+ has this 195/60R14 size too. Its a slightly awkward size as I understand.
I would like to know if it touches the insides of the wheel well on full steering lock. The alloys (aftermarket) are of 6J size and will be able to take the 20mm increase to 195mm, but I am more concerned about the wider size touching the insides of the wheel well. First hand experience/ insights will be really helpful.
65% profile will give you slightly more air space in the tyre and hence more cushioning effect. The effect may not be that noticeable between 60 and 65% though. You can't go wrong with either.
KarthikK is offline   (1) Thanks Reply With Quote
Old 12th June 2013, 14:45   #604
lucifer919's Avatar
Thanked: 307 Times
I'm currently running 195/50/15 in my car on 7J wheels. they don't touch anywhere on the insides so the 195/60/14 you have selected should have no issues.
lucifer919 is offline   (1) Thanks Reply With Quote
Old 12th June 2013, 18:17   #605
planet_rocker's Avatar
Thanked: 368 Times
195-60-14 will not foul. You can fit them at ease on OEM alloys
This post should be helpful: http://www.team-bhp.com/forum/tyre-a...ml#post2336141
planet_rocker is offline   (1) Thanks Reply With Quote
Old 22nd August 2013, 18:08   #606
praful's Avatar
Thanked: 442 Times
Alright I know I'm gonna get beaten up for this
Asking a tyre query yet again (but hopefully this time will change the tyres )
Stock tyre - 175/65-14
Tyres to choose from 185/60-14 OR 185/65-14
One has a -0.94 variation over stock & the other has +2.24 variation
I know the 65 profile will cushion bad roads better and all, but have been reading up about folks having a lighter steering at higher speeds due to higher profile.
On the other hand will a 0.94% change (reduction in overall diameter) REALLY make the ride that harsh and more susceptible to wheel damage ??
praful is offline   Reply With Quote
Old 22nd August 2013, 18:35   #607
SunnyBoi's Avatar
Thanked: 2,832 Times
^ Get 185/65-14. I'm on 195/55-15 and really miss the comfy ride :(
SunnyBoi is offline   Reply With Quote
Old 22nd August 2013, 20:01   #608
praful's Avatar
Thanked: 442 Times
Will 0.1in or 0.25cm drop in sidewall height really make that much of difference ??
With your tyre profile you drop 0.3inches, which is still a more that what I'm looking at.
Old 22nd August 2013, 20:43   #609
SunnyBoi's Avatar
I replied in haste.
0.1inch may not matter. I wanted to imply that I run almost same increase in tyre size (+2.1) as with 65 profile and don't face any issues with wheel rubbing anywhere and thus would take the extra profile for additional comfort.
Old 23rd August 2013, 07:31   #610
praful's Avatar
Thanked: 442 Times
I replied in haste.
How about changes in steering response above 100? I have read about people complaining that the steering became lighter at higher speeds with the 65 profile!?
Old 25th August 2013, 21:05   #611
lloydofcochin's Avatar
Thanked: 180 Times
Hi T-bhpians,
Have a doubt about an upgrade for my Palio SDX.
I'm currently running 185/70/R13 Yoko A-Drives on my Car.
I'm planning to put on 14" Punto rims and have bought a set. The tires I'm looking at is 185/65/R14 - Michelin XM2 (Heard that the grip is good and the sidewall is strong, The Car is mostly going to be used in Kerala and for the condition of the roads the tires should be tough)
So my query is that whether I should get Punto Wheel bolts or is the existing ones compatible?
And secondly will there be any compatibility issues with the Punto rims on the Palio wheel hub?
TIA
Lloyd
lloydofcochin is offline   Reply With Quote
Old 25th August 2013, 21:19   #612
SunnyBoi's Avatar
Bolts are compatible; no need of changing and wheels are compatible as well. I'm using Punto Alloys on my Palio.
SunnyBoi is offline   (1) Thanks Reply With Quote
Old 25th August 2013, 22:31   #613
Thanked: 180 Times
Thank You SunnyBoi. Then I'll just order a set of Palio Bolts since 2 of them are getting jammed and is tough to remove.
And any idea on where to source a wheel spanner for the Palio? Mine has gone bad
Old 25th August 2013, 22:40   #614
SunnyBoi's Avatar
If you're ordering new wheel bolts, make sure you get the shorter version, i.e., the one which comes standard on Palios with steel rims. GTX with alloys have longer bolts that will jam the wheels with steel rims.
Wheel spanner, Just get a L rod and a 19 socket from either Eastman/Ambika/Taparia!
Old 11th September 2013, 00:23   #615
praful's Avatar
Thanked: 442 Times
Palio junta, what's the tyre pressure you are keeping?
Manual recommends 1.9 bar (27.5psi) for low load and 2.2 bar (31.9psi) for full load.
Just upsized my tyres to 185/60-14, wondering if I should stick to 30psi as a middle road between two pressures.
Fiat Linea : Tyre & wheel upgrade thread vancity Tyre & Alloy wheel Section 237 10th July 2018 16:26
Hyundai Grand i10 & Xcent : Tyre & wheel upgrade thread jkdas Tyre & Alloy wheel Section 18 8th July 2018 21:32
Fiat Punto : Tyre & wheel upgrade thread furioussphinx Tyre & Alloy wheel Section 664 20th June 2018 10:17
4th gen. Honda City : Tyre & wheel upgrade thread Screwdriva Tyre & Alloy wheel Section 350 9th May 2018 19:30
