Old 11th September 2013, 11:45   #616
Thanked: 95 Times
Default re: Fiat Palio : Tyre & wheel upgrade thread
Originally Posted by praful View Post
Palio junta, what's the tyre pressure you are keeping?
Manual recommends 1.9 bar (27.5psi) for low load and 2.2 bar (31.9psi) for full load.
Just upsized my tyres to 185/60-14, wondering if I should stick to 30psi as a middle road between two pressures.
I use 30psi and find it very comfortable. If the car is going on the highway with 4 adults, I use 32 psi.
zoombiee is offline   (1) Thanks Reply With Quote
Old 11th September 2013, 17:55   #617
SunnyBoi's Avatar
Thanked: 2,832 Times
Credit goes to Nikhil since he posted this somewhere.
Run your car at 32psi for 2 months, 30psi for 2 months and 28psi for 2 months. Somewhere during these 6 months, you will find a sweet spot. Stick to it.
SunnyBoi is offline   (3) Thanks Reply With Quote
Old 17th November 2013, 12:18   #618
Thanked: 35 Times
Are the BS Potenza G3 still available in the market? They are listed on their site but not seen in the shops. Looking for 185/60/14 profile.
prokinetic is offline   Reply With Quote
Old 25th November 2013, 16:15   #619
Nikhilb2008's Avatar
Thanked: 6,670 Times
G3 hasnt been produced for more than a year now. Even if you do find something it will be old stock for sure.
Nikhilb2008 is offline   (1) Thanks Reply With Quote
Old 25th November 2013, 19:08   #620
Thanked: 35 Times
Thanks Nikhil. My need is a hard robust tyre with sporty handling. I can live with high noise. G3 is something which meets the requirement. Is there any similar alternative from some other brand? I dont want XM2. Size needed is 185/60/14. Your suggestions are welcome. Thanks.
Old 28th November 2013, 10:32   #621
Not many options unfortunately. You may have some luck with Bridgestone MY02.
Old 1st December 2013, 19:20   #622
Thanked: 94 Times
I changed my Ritz's tyres(Michelin XM2) around 2 weeks back and I saw BS Potenza G3. The DoT was 3713 and the cost of G3 for 180/70/R14 was either 4600 or 4900(can't remember but sure that either of these 2 rates were given). But the dealer did tell me that the company has again started manufacturing these tyres after a year. The dealer name is T-Mart, Sohna Road, Gurgaon. Hope it helps!!!
headbanger is offline   Reply With Quote
Old 14th December 2013, 22:41   #623
Thanks! It does! this is news to me!
Old 15th December 2013, 21:30   #624
Thanked: 70 Times
Any recommendation of what tyre pressure should I keep for new xm2s I installed for my petra
rikhav is offline   Reply With Quote
Old 16th December 2013, 21:31   #625
You can keep 30 PSI. You can experiment with plus or minus 1 or 2 PSI.
Old 7th February 2014, 16:08   #626
Thanked: 11 Times
Hi
I just got Palio Stile 1.6. I need to change tyres since the stock tyres had hardened though just run 25000 kms since 2007.
My priorities in order are
1. Better sidewall and overall more robust since road conditions in our area is from good to not so good and bad.
2. Better wet grip and breaking
3. Reasonable ride and handling quality
4. Reasonable noise
5. Fuel efficiency, I am not worried.
Use will be on highway and town also.
Any good model From Bridgestone, Michelin, Yokohoma or Goodyear.
Heard about some Earth launched by may be by one of the above company can't recall.
Read last few pages but information was not sufficient for me to decide. Waiting for suggestions.
Regards Sanjay
HydroFuel is offline   Reply With Quote
Old 7th February 2014, 18:26   #627
motionfreak's Avatar
Thanked: 54 Times
185/60 R14 gives the best ride+handling compromise.
Yokohama launched the Earth1 tyres
http://www.changemytyre.com/Tyres/Ca...D=34&CityID=13
motionfreak is offline   Reply With Quote
Old 7th February 2014, 19:20   #628
Thanked: 11 Times
Hi
Oh forgot to mention that I would prefer 185/65 R 14 over 185/60 R 14 for better ride quality though it would give more odometer error than latter. On this forum also I have seen people going for the same instead of 60 profile.
However suggestions are welcome.
Also if it give good service for 30000 km it's sufficient for me.
Anybody used Earth here, please share the experience.
Thanks and regards
Sanjay
Old 30th May 2015, 00:59   #629
TorqueyTechie's Avatar
Thanked: 1,138 Times
Folks,
Planning to change the tires on my stile. Want to upgrade from the stock ones. Any suggestions on what would be a good upgrade? I am looking at better ride quality and less road noise. I am looking at 185/65 and considering yokohoma but one of my friend suggested G3 potenza from bridgestone. Which one is better? Also if I am going for 185/65 I would need o change the stock alloys to 14" right?
TorqueyTechie is offline   Reply With Quote
Old 30th May 2015, 05:50   #630
SunnyBoi's Avatar
185/65 will foul the tyre with the fender. Stick to 185/60-14.
If you have stock alloys your car already has 14inch alloys.
SunnyBoi is offline   (1) Thanks Reply With Quote
Fiat Linea : Tyre & wheel upgrade thread vancity Tyre & Alloy wheel Section 237 10th July 2018 16:26
Hyundai Grand i10 & Xcent : Tyre & wheel upgrade thread jkdas Tyre & Alloy wheel Section 18 8th July 2018 21:32
Fiat Punto : Tyre & wheel upgrade thread furioussphinx Tyre & Alloy wheel Section 664 20th June 2018 10:17
4th gen. Honda City : Tyre & wheel upgrade thread Screwdriva Tyre & Alloy wheel Section 350 9th May 2018 19:30
