Old 30th May 2015, 22:57   #631
TorqueyTechie's Avatar
Thanked: 1,138 Times
Default Re: Fiat Palio : Tyre & wheel upgrade thread
Thanks SunnyBoi for the reply. I will stick to 185/60. Which one is better? G3 potenza or anything from yoko's?
Sorry for going OT but does anybody happen to know where to source scuff plates and interior led lights for palio? Also is it a simple DIY?
TorqueyTechie is offline   Reply With Quote
Old 18th January 2016, 02:22   #632
swiftnfurious's Avatar
Thanked: 6,580 Times
While checking the tyre sizes, I noticed a 195/60 R14 gives a difference of just 1.11% over the stock 175/65R14. This is better than the difference with 185/65 R14 which is rated at 2.24%.
Isn't this a better option as we get a wider tyre to counter the braking deficiency of the Palio? Found the below post which states 195 can run on OEM Alloy wheels.
http://www.team-bhp.com/forum/tyre-a...ml#post3147570 (Fiat Palio : Tyre & wheel upgrade thread)
195-60-14 will not foul. You can fit them at ease on OEM alloys.
This post should be helpful: http://www.team-bhp.com/forum/tyre-a...ml#post2336141
Originally Posted by planet_rocker View Post
Tyre options in 195-60 R14 (OE Alloys - 5.5J)
Bottle's 1.6 Sports Stile` (Yokohama Advan AD07)
Attachment 539462
Rahul's 1.6 Sports Stile` (Yokohama ES100)
Attachment 539463
My GTX (Hankook Ventus R-S2)
Attachment 539464
Khan_Sultan is using GY Eagle Ventura ...
How did your Hankooks fare? Just want to get a feedback on which can be a good compromise between Noise levels / Cornering / Grip levels on a Symmetric tyre? I am not keen on Uni-directional tyres since I like to rotate the tyres at regular intervals.
Originally Posted by SunnyBoi View Post
185/65 will foul the tyre with the fender. Stick to 185/60-14...
My GTX is running on 185/65R14 and it never fouls with the fenders, using stock alloy wheels.
swiftnfurious is offline   (1) Thanks Reply With Quote
Old 8th February 2016, 08:54   #633
bharatbits's Avatar
Thanked: 66 Times
My friend's Linea is running on stock 175/70 R14. The top end Linea comes in 205/55 R16 which in my opinion looks very good.
But, increasing the width of the tyre from 175 to 205 will sure have a significant impact on FE. He wants to upgrade from 14" to 16" which in my opinion look good too. I could not find any tyres with 175mm width and 16 inches in dia. So, i decided to increase the width slightly to 185mm (so as to have minimal impact on FE) and found 185/85 R 16 tyres in JK Tyres Brute. Would this be a successful upgrade? The top end Linea's overall wheel dia is coming to 24.8 inches and the upgrade i chose is coming to 28.3 inches. Will this lead to the tyres touching the body and on turns when i turn the steering to extreme right or left?
I understand 185/85 R16 tires aspect ratio is quite high and can lead to side wall cuts on gravel roads etc. However, his usage will be limited to the city only or on highways once a quarter. The reason behind the upgrade is purely aesthetics and he is not looking for any improvement in performance. All he wants is to retain the current FE or maybe better it. He can live with the tyre noise as speeds will be under 50kmph in most city runs. He drives very sedately like a 50 year old man.
GC increase is welcome as long as it does not play a spoilsport with the aesthetics.
Look forward to expert recommendations.
bharatbits is offline   Reply With Quote
Old 8th February 2016, 12:53   #634
planet_rocker's Avatar
Thanked: 368 Times
Wonder why I didn't get any notification for a quote!.
Any way, the Hankook Ventus R-S2 s are doing good. No complains. The tyres are not noisy unlike tyres with soft compound. Impressed with the grip level too.
They aren't available now.
planet_rocker is offline   (2) Thanks Reply With Quote
Old 8th February 2016, 15:18   #635
Originally Posted by bharatbits View Post
My friend's Linea is running on stock 175/70 R14. ..
Does he have a Linea classic?
swiftnfurious is offline   Reply With Quote
Old 9th February 2016, 06:59   #636
bharatbits's Avatar
Thanked: 66 Times
Yes, he owns a Linea Classic.
Old 26th March 2017, 10:31   #637
Thanked: 258 Times
Hi guys,
I have been running Michelin XM1/XM2 175/70 R13 tyres on 13 inch alloy wheels for a long time now. Got average life of around 30k kms from every set of tyres and I usually used to change only two tyres at a time moving the old tyres to the back and installing new tyres on the front.
I have recently moved to Himachal Pradesh and the roads aren't as good over here as they were in Chandigarh. Also running has increased and the wheels also don't stay aligned for long due to the car getting driven a lot on bad potholed roads.
I am seeing some toe wear and it is especially bad on the rear tyres as they are older. The suspension has been changed not long ago and even the front tie-rods are new. The toe wear is less severe on the front tyres. So despite them being asymmetrical tyres, I have put the inside side on the outside for now as I don't drive fast in the hills.
I am therefore looking for a solution. Should I be getting alignment done every 2k kms now. Also I was thinking of upsizing both wheels and tyres and moving back to steel rims as they might survive better on bad roads.
So what tyres would you guys recommend as an upsize and also which are more wear resistant due to the harsher road conditions over here.
rdst_1 is offline   Reply With Quote
Old 26th March 2017, 12:56   #638
Thanked: 35 Times
Originally Posted by rdst_1 View Post
Hi guys,
By upsize, I assume you are going for 14". Regarding tyres, the most popular suggestion is 185/65/14 & 185/60/14. Of these two, I suggest the later 185/60/14. GC is not a problem in palio, thus the extra tall side wall height of 65 profile tyres is not of much practical use. Some users have reported tyre brushing with the wheel arches with 65 profile tyres. Have used 60 profile tyres in a relatively heavy Petra diesel and observed ride and handling improve over stock size.
Coming to the tyre build, choose one with hard side walls. I may never in my life buy any Michelin tyre. Had a very bad experience with 4 all new Michelin XM1+ going bad one by one. Michelins are silent is a doubtful claim. After a few hundreds of kilometers, michelins are equally noisy. Bridgestone potenza(if still available) is a right mix of sporty performance and tough build. Noise level is also acceptable.
Hope this helps.
prokinetic is offline   Reply With Quote
Fiat Linea : Tyre & wheel upgrade thread vancity Tyre & Alloy wheel Section 237 10th July 2018 16:26
Hyundai Grand i10 & Xcent : Tyre & wheel upgrade thread jkdas Tyre & Alloy wheel Section 18 8th July 2018 21:32
Fiat Punto : Tyre & wheel upgrade thread furioussphinx Tyre & Alloy wheel Section 664 20th June 2018 10:17
4th gen. Honda City : Tyre & wheel upgrade thread Screwdriva Tyre & Alloy wheel Section 350 9th May 2018 19:30
