Old 10th October 2008, 11:43   #1
Thanked: 7 Times
Default Tubeless Tires and repairs on a long trip
Does anyone have suggestions on what one should do if one has a flat on a tubeless tire when on a long remote journey. I am not aware if facilities to repair exisit everywhere. Any thoughts and suggestions would be appreciated. Thank you.
ahujapradeep is offline   Reply With Quote
Old 10th October 2008, 12:23   #2
gd1418's Avatar
Thanked: 655 Times
You get a kit for repair of punctures on a tubeless tyre and it is a very easy DIY. A pictorial guide on how to is posted in the Tyres & Wheels section..
gd1418 is offline   (1) Thanks Reply With Quote
Old 10th October 2008, 12:25   #3
hemanthisgreat's Avatar
go through this thread http://www.team-bhp.com/forum/tyre-a...-puncture.html
and also this one http://www.team-bhp.com/forum/tyre-a...flat-tyre.html (Pictorial Guide: How to change a flat tyre!)
hemanthisgreat is offline   (1) Thanks Reply With Quote
Old 10th October 2008, 12:27   #4
Eddy's Avatar
Thanked: 4,680 Times
Hi Pradeep,
This is what you should do
Eddy is offline   (1) Thanks Reply With Quote
Old 10th October 2008, 13:23   #5
Tejas@perioimpl's Avatar
Thanked: 4,925 Times
You need to put in air after fixing the puncture as well...
there's this kit from Costco you can use.
Anyone know of a local kit similar to this?
Emergency road kit from Costco for $52. See anyone can get it from US. It'll be another $50 to ship it here i guess. Take a look at the features:
Features:
1 8-gauge booster cables: 3.66 m (12 ft.)
1 non-inflammable tire sealer/inflator
1 roll of duct tape
1 tow rope with steel locking hooks
1 reflective traffic triangle
1 weatherproof flashlight
1 SOS signal flag
1 multi-tool
1 emergency blanket
1 pair of examination gloves
1 safety vest
1 shop cloth
1 foam knee pad
1 50-pc. first aid kit
1 large carrying case
Contents of First Aid Kit:
1 first aid instruction guide
12 absorbent cotton balls
1 pair of vinyl gloves
3 moist towelettes
3 antiseptic towelettes
1 roll of adhesive tape
20 adhesive strips
6 junior adhesive strips
2 gauze pads:
5.08 cm x 5.08 cm (2 in. x 2 in.)
1 first aid case
Specifications:
Dimensions (L x W x H):
37 cm x 23 cm x 18 cm
(14.5 in. x 9 in. x 7 in.)
Weight: 3.09 kg (6.8 lb.)
Tejas@perioimpl is offline   (1) Thanks Reply With Quote
Old 10th October 2008, 17:14   #6
Shashank.A's Avatar
There is a small compressor or Chinese make that can be bought for Rs.400. You can plug it up in lighter's socket. Inflates the tyre from a flat position is about 10 minutes.
Shashank.A is offline   Reply With Quote
Old 17th November 2008, 12:22   #7
Did anybody has review on this? I want to buy one in Pune if its really worth of it.
omishra is offline   Reply With Quote
Old 17th November 2008, 12:53   #8
Shashank.A's Avatar
Its an equipment that you barely use. I have it for 7-8 months now, however have used it only 2-3 times, it works well for me though.
Old 17th November 2008, 13:09   #9
phamilyman's Avatar
Thanked: 3,452 Times
Cigarette Lighter Attachment - BikeNomads
Works just fine. About 1.75 years, used very rarely, and stripped of its useless plastic casing and going quite strong. But like once in 2 months usage types.
Old 17th November 2008, 13:17   #10
Sudipto-S-Team's Avatar
Thanked: 258 Times
I don't think spending Rs 5000 for the list below is worth it. You can organise this kit on your own for much less. And this list has more frilly things that will never be used in real life, than things needed in real life situations.
All new cars, incidentally, come with a OE first aid kit. In a real emergency that first aid, or any first aid, kit is hopelessly inadequate in any case. Sometimes even hospitals are inadequate.
Features:
1 roll of duct tape
1 SOS signal flag
1 multi-tool
1 emergency blanket
1 safety vest
1 shop cloth
1 foam knee pad
3 moist towelettes
20 adhesive strips
2 gauze pads:
1 first aid case
Specifications:
Sudipto-S-Team is offline   Reply With Quote
Old 17th November 2008, 13:35   #11
Ya i know. i just listed the contents of the kit so people can take pointers to make their own.
Tejas@perioimpl is offline   Reply With Quote
Bike Tubeless tires - Truth or Myth? aniketi Motorbikes 10 26th February 2010 10:22
My Palio 1.2 finally adorns Alloys & Tubeless tires! finneyp Tyre & Alloy wheel Section 55 9th February 2010 12:52
Query : Tubeless tires / Normal Tires nicejits Tyre & Alloy wheel Section 12 10th June 2009 09:59
Tubeless tires - information about punctures? willy Tyre & Alloy wheel Section 1 7th June 2006 12:34
Tube inside tubeless tires... Samurai Tyre & Alloy wheel Section 1 25th February 2005 16:32
