Old 24th October 2008, 15:30   #1
Nikhilb2008's Avatar
Thanked: 6,591 Times
Default Need help w.r.t tyres for 1988 Jaguar Sovereign
A person came to our shop and was looking for tyres for his Jag which he is redoing.
It's a 1988 Jaguar sovereign. The current tyres are Dunlop Sport 100TD.
On the tyre, this is written. "This is a TD Tyre, fit only to a TD rim".
The size mentioned is "TD 220/65 VR 390".
What does that mean? I think it's a crossply tyre as the following is also written on the tyre.
"Tread 5 plies
1 rayon, 2 steel and 2 nylon
Sidewall 1 ply
1 rayon".
The tyres are pretty much destroyed. Owner wants to replace them but doesnt know what size to get.
Old 24th October 2008, 15:34   #2
reignofchaos's Avatar
Thanked: 1,298 Times
Measure with a ruler and tape and check the dimensions . Not so hard is it?
Old 24th October 2008, 15:55   #3
suren181's Avatar
I wonder if this info would be of help, but for what it's worth
Dunlop TD Tyres
suren181 is offline   Reply With Quote
Old 24th October 2008, 16:25   #4
iraghava's Avatar
Thanked: 156 Times
Nikhil - I'm quoting the explanation below:
Fab! You've bought a BMW 525TD. Tires look a bit shoddy so you go to replace them. What the....? TD230/55ZR390? What the hell does that mean? Well my friend, you've bought a car with metric tires. Not that there's any real difference, but certain manufacturers experiment with different things. For a while, (mid 1990s) the 525TD came with arguably experimental 390x180 alloy wheels. These buggers required huge and non-conformal tires. I'll break down that classification into chunks you can understand with your new-found knowledge:
TD - ignore that. 230 = cross section 230mm. 55 = 55% sidewall height. Z=very high speed rating. R390=390mm diameter wheels. These are the equivalent of about a 15.5" wheel. There's a nice standard size for you. And you, my friend, have bought in to the long-raging debate about those tires. They are an odd size, 180x390. Very few manufacturers make them now and if you've been shopping around for them, you'll have had the odd heart-stopper at the high price. The advice from the BMWcar magazine forum is to change the wheels to standard sized 16" so there's more choice of tires. 215-55R16 for example. The technical reason for the 390s apparently is that they should run flat in the event of a puncture but that started a whole debate on their forum and serious doubts were expressed. You've been warned...
Let me know if you need any more help with these.
Old 24th October 2008, 16:54   #5
Thanks so much Ishan and suren. Not much thanks to you sumo
Hmmm.... so, no tyre available in that size in India? The car has the original rims and they look very nice. I would hate telling the owner that he has to put some stupid 16" rim
Any of these old metric tyres available in India?
Old 24th October 2008, 18:11   #6
iraghava's Avatar
Thanked: 156 Times
I would say finding a tyre of that size here would be almost impossible since they're hard to come by even in Europe. Then again if you do find something the age is also a factor etc. etc.
Best & the most trouble-free way is to put on a set of new 16" wheels & tyres. Maybe you can do a search of British tyre sites to see current prices of such tyres & point out to the owner that buying & importing them would turn out to be prohibitively expensive.
Old 24th October 2008, 21:03   #7
greenhorn's Avatar
Thanked: 1,516 Times
any chance for a retread ?
Elgitread
Old 24th October 2008, 21:55   #8
gd1418's Avatar
Thanked: 656 Times
Eeeks...retreaded tyres on a Jag sovereign??
The story of the Standard 2000. 1985-1988 v12 The Indian Car Scene 187 14th April 2018 20:51
1988 Honda CBR 250 pgsagar Motorbikes 10 25th December 2012 09:28
Got my Dzire Sovereign Blue VXI on 4th June 2008 sharma_sanjeevi Test-Drives & Initial Ownership Reports 40 5th February 2011 20:48
HELP Required: 1988 Mahindra Jeep 540DP 2WD Gordon 4x4 Technical 2 14th July 2009 18:34
For Sale: 1988 Mercedes 280SEL karlosdeville Shifting gears 5 29th August 2006 14:45
