Old 5th November 2008, 22:54   #1
WasavaTyres's Avatar
Thanked: 239 Times
Exclamation Help needed to source alloys for Petra
Hi everyone. If anyone has knowledge / access regarding any dealer holding stocks for 14" 98 PCD wheels please help me out. I would prefer dealers in Delhi / Mumbai 'coz of familiarity issues. HR does not have them neither do Aura and Neo. An importer I spoke to in Delhi suggested very casually that I pick up 100 PCD 4 Hole set and 'grind kar lo bilkul thoda sa
Any help on this would be highly appreciated.
WasavaTyres is offline   Reply With Quote
Old 5th November 2008, 23:11   #2
noidaboy's Avatar
Thanked: 260 Times
You can fit in 100pcd ,HELLSPAWN has been using them for 7-8000kms now w/o any problem.Check his garage if you like.
noidaboy is offline   Reply With Quote
Old 6th November 2008, 01:17   #3
anantnehru's Avatar
98 PCD is very rare - in the sense that, like you found out, very few manufacturers make rims for that PCD.
Using 100PCD should be your last option, 2 friends of mine had alot of problems when they used the same on their Palios. Dont know about the above experience though.
Im going to be paying my alloy guy a visit sometime soon, shall find out from him - think he mentioned something about 98PCD last time I was there. What design are you looking at? As in, like machine black, hypersilver, chrome etc etc? Just so I have a better idea as to what to look out for.
anantnehru is offline   Reply With Quote
Old 6th November 2008, 09:45   #4
deepgautam_qa's Avatar
I also own a Petra and thinking of changing to alloys. The biggest problem encountered is that of 98 PCD. Adventure alloys (by Fiat) are available in 14" size (INR 28000 - as quoted by Dynamic Automobiles Noida). You can go for that option.
Cheers!!!
deepgautam_qa is offline   Reply With Quote
Old 6th November 2008, 09:50   #5
Thanked: 239 Times
Thanks anant, not much emphasis on design or finish. It's more of a convinience factor to do away with constantly getting steel rims bent. Will manage with whatever design you can offer.
Old 6th November 2008, 10:10   #6
finneyp's Avatar
Thanked: 160 Times
Aura has couple of designs in 98 PCD 14" alloys!
Pls contact the Aura distributor at your place, he will source it for you!
For my Palio, I had bought Aura 98 PCD 14" alloys, check the pics in my Garage.
finneyp is online now   Reply With Quote
Old 6th November 2008, 10:39   #7
Thanked: 16 Times
Aura has 2 good designs (rest aren't available anymore) in 98 pcd.
They're good alloys and very much reliable than the cheap imported kinds.
There're many who have successfully installed 100 pcd alloys on FiAT cars. But my personal experience was very bad and will not recommend that.
Old 6th November 2008, 20:43   #8
Thanked: 239 Times
Thanks for the help guys. I guess Aura Distributors down south have some old stock with them. I deal with Aura directly and the distributor here has steadfastly refused that any wheels are available.
Old 7th November 2008, 01:04   #9
anantnehru's Avatar
No problemo, just give me a few days.
Need to source an ECU for Chevy Captiva - Pointers needed Cesc Technical Stuff 1 19th September 2011 16:28
Suggestion needed for tubeless tyres and alloys - Petra 1.6 sreenivass Tyre & Alloy wheel Section 23 9th May 2009 23:30
Petra with OZ racing Alloys & 205/50/R15 Yokohoma S drive greatDrive Tyre & Alloy wheel Section 45 20th November 2007 14:09
Turbo charger/Alloys/Tye Upgade for Petra 1.9D shivag Modifications & Accessories 6 26th August 2006 00:12
Alloys for Petra sivadas Tyre & Alloy wheel Section 7 19th February 2006 22:15
