Old 14th November 2008, 12:31   #16
Originally Posted by RedMM340 View Post
The Forester owner's manual lists wheel alignment specs:
Toe, Front 0 +/- 3mm
Toe, Rear 2 +/- 3mm
Camber Front -0deg25' +/-45'
Camber Rear -0deg50' +/-45'
All non-turbo Foresters from '03 to '07 have the same spec. The Turbo models just have and addition -5' camber for the rear wheels.
All major tire manufacturers are good, so just get a tire that meets your needs better. My current tires are Yokohama ATs that are noisy on the highway, but good for rough, potholed, damaged roads.
The Michelins are comfortable and quiet, or you can get more sporty rubber compounds for cornering. I prefer to get a tire with at least 2 ply sidewalls for puncture resistance.
Thanks RedMM. I am getting them changed next week.
thejuk is offline   Reply With Quote
Old 14th November 2008, 12:38   #17
Thanked: 544 Times
Slightly off topic, has any of you used KN filter on the Forester? Does it help low end performance a bit?
Guna is online now   Reply With Quote
Old 14th November 2008, 22:36   #18
RedMM340's Avatar
Thanked: 24 Times
I am running a standard filter and plan to continue to do so.
A universal filter might be a bad idea according to some. Apparently the snorkus assembly is design to reduce some resonance frequencies. Replacing with a tube and conical filter may cause some stalling and rough running at certain rpms.
RedMM340 is offline   Reply With Quote
Old 14th November 2008, 23:01   #19
RedMM340's Avatar
Thanked: 24 Times
Originally Posted by mura View Post
FYI - All Subaru 2004-2006 WRX/STi suspension bits fit the Forester.
By fitting the WRX struts and springs you can improve ride and lower the car by 1.5 inches.
See : How to turn better than an STI for cheap! - Subaru Forester Owners Forum
Mura,
Thanks for the link. I am preparing a nice shopping list for my next visit to California! #1 on my list is some sticky tires. I just came back from my second trip to Shimla, and the Forester handled the curves very well. The main limiting factor was the Yokohama All terrain tires. While nice for off-road, they are just terrible for smooth curvy roads.
Despite these lousy tires, I was able to outrun just about any other car on the curves.
Originally Posted by Alfa_Kilo View Post
ABS and TCS systems compare wheel rotation with linear acceleration to determine wheel slip/lockup. The tyre dia is very important for this to work properly. If the tyres are too small, then the system will allow too much slip, and oversize tyres will fool the system too cut in too early.
If ABS was only dependent on wheel sensors, it would fail to detect cases where all four wheels lock up.
Alfa,
With all due respect, I think you are mistaken on this issue about tire size. Tire size is irrelevant regarding ABS operation. The following articles have made no mention about tire size.
ABS (Antilock braking system) technology
Anti-lock braking system - Wikipedia, the free encyclopedia
I have run my MBZ 400E on tires as small as 23.5 inch diameter to 25.5 inch diameter at different time periods and never had a problem with ABS.
Originally Posted by headers View Post
Wow, Gaurav, thats really neat. Now what Mods are you planning on the Forester
Headers,
I have quite a long list, including a turbo, brakes, suspension, etc. The limiting factor is money (as usual) and how much stuff I can bring in suitcases.
Old 18th May 2010, 11:55   #20
WRXXX's Avatar
Thanked: 292 Times
Question Forester owners : Using a 225/60 R15 or a 205/65 R15 tire on stock 15inch alloys ?
Dear forester owners,
I was thinking of playing around with tires on my forester for on-road usage, currently car has Bridgestone 694 A/T tires which I want to preserve for my wildlife centric trips.
But the WRX demon sitting inside me sometimes asks for more of road fun too
I am doing this for improved handling for faster cornering.
Idea 1:
I can go for a set of 16/17inch spare alloys to fit the road tires
(thinking of 225/50 R17) I am finding it a bit expensive to do so right away. (although, suggestions are greatly welcome on economic
alternatives)
Idea 2:
I am thinking of putting 205/65 R15 or 225/60 R15 at the risk of lowering the ground clearance. I think 6X15J is a bit narrow for the 225 tires.
Questions:
- Any suggestions on this whole thing ?
- Has anybody tried this before ?
- Does this affect the overall gearing a lot (or does it make it unusable) ?
- Is the reduced CG worth the trouble ? Will I loose peace of mind ?
Any advices, suggestions are really appreciated.
WRXXX is offline   Reply With Quote
Old 20th May 2010, 23:36   #21
iraghava's Avatar
Thanked: 156 Times
6J is indeed too narrow for 225-section tyres. There won't be much change in Overall Diameter of the two sizes (and as a result gearing) or GC if you opt for 225/60 in any case.
Old 21st May 2010, 00:55   #22
nitrous's Avatar
Thanked: 285 Times
For tarmac/asphalt specific set of tyres, you can even run a smaller OD than stock.
You won't lose too much, but the lowered Centre of Gravity and gearing will be 2-3x more fun.
Old 23rd May 2010, 16:35   #23
Thanked: 157 Times
Slightly off topic-a lot of people inlcuding me have 225 / 60 R 15 tires on the stock innova alloys that are 6J*15. The tires do buldge out a bit but the section width is within the tolerance specified for 225/60 tires.
Buffetfan is offline   Reply With Quote
Old 30th May 2010, 16:36   #24
iraghava's Avatar
Thanked: 156 Times
I believe stock Innova alloys are 6.5J in width.
Old 31st May 2010, 17:49   #25
Thanked: 157 Times
6J is still my guess :-
See
http://www.team-bhp.com/forum/tyre-a...bangalore.html (Used OE alloys for innova in Bangalore)
and also have a Toyota site reference
Toyota - Innova
Michelin Tyre Woes: Fact or Fiction? (Michelin users please vote) greenhorn Tyre & Alloy wheel Section 163 12th September 2014 19:53
New Civic 1.8V AT. Questions questions... ImmortalZ Sedans 6 12th June 2008 09:49
Spotted Subaru Forester & "Chevy Forester" in Hyderabad midlifecrisis The Indian Car Scene 14 26th October 2007 12:29
Buying Palio - Need specific guidance on key questions from users/experts sachinchavan Hatchbacks 25 19th May 2006 17:41
For all you Subaru Forester Fans GTO The International Automotive Scene 10 6th March 2004 15:00
