Old 15th December 2008, 14:15   #46
Kevciti's Avatar
Thanked: 16 Times
Well that particular tyre had a bigger cut kind of like the one on your tyre only bigger, I guess since it was the front tyre which took the maximum impact so the repair guy couldnt do much about it. So had to chuck it. Even the lip of the alloy got bent a bit but no major damage.
Originally Posted by Raccoon View Post
Didn't exacty get that... cut the mouth?? You mean he removed the valve, so that you could put a tube in? In that case, you should be able to put in a new valve, and the tyre should be good for use as a tubeless again!
Kevciti is offline   Reply With Quote
Yokohama ES-100 195/60/14 - Prices in Pune wanderlustindia Tyre & Alloy wheel Section 53 22nd December 2012 21:03
Tyre woes - Rs10,800 per Yokohama tyre?! shayne Modifications & Accessories 12 2nd August 2011 05:20
Tyre Pressure for Yokohama 205/50/15 on baleno alcam Tyre & Alloy wheel Section 4 28th December 2007 00:38
