Old 11th November 2008, 18:26   #16
Nikhilb2008's Avatar
Thanked: 6,615 Times
Originally Posted by Lukeskywalker View Post
Nikhil, I think you have correctly answered the original question, I don't think it was a matter to save a few bucks, it was a query on correct balancing techniques.
How much does the expertise of the man performing balancing count? Is it solely dependant on the hitech machines that you have?
Balancing depends more on the machine. something like 90% machine, 10% technician.
All the technician does is mount the wheel on the shaft, input the dimensions and run it. Then just attach the weights. Nothing more. The machine is the most important factor here.
Old 12th November 2008, 23:11   #17
Path_Finder's Avatar
Thanks for the clarifications – it will also be good to explain wheel alignment and how it is different from balancing.
Path_Finder is offline   Reply With Quote
Old 19th November 2008, 04:55   #18
aah78's Avatar
Thanked: 1,749 Times
Arrow of a balanced and sound mind.
Basic layman's difference between wheel alignment and wheel balancing - the former affects the wheel (hubs, if I may), the latter affects the alloy / steel rim, on which your tyre is mounted.
While performing a wheel alignment, the toe and camber (funky names for angles) are adjusted so that the car's wheels are as parallel to each other as possilble, and make an angle as close to 90deg with the road as possible. Suspension settings are taken into account.
If you see a truck or taxi on Indian roads, you'll notice a lot of them appear to have the body pointing in a slightly off-angle, compared to the wheel, and yet they're managing to move straight somehow - such a vehicle is desperately yearning for a wheel alignment.
Nikhilb2008 and others have laid out great information.
irags - we await your picturesque writeup.
To add some a few more cents worth from my side:
Even though your new alloy wheel is nice and round it's not a perfect product. There is some imperfection in the alloying process, which leads to the weight imbalance.
Same goes for your tyre. Due to the different materials used in the manufacture of a single tyre, the weight imbalance is expected.
Wheel balancing is performed to balance out these imperfections so that the tyre and wheel combo can rotate without vibrating.
You see a car on the road with it's wheel bouncing unnaturally or vibrating like a dying spinning-top, you know the fellow needs to spend some money on getting his wheel balanced.
Using old / new weights isn't the issue here because it's only in very rare cases that a wheel without a tire mounted on it is balanced.
The tyre is aligned with the wheel in such a way that the heaviest points of each face away from each other. Weights are then added to points to negate the imbalance.
Nowadays a new technique called Road Force Balance is becoming popular. A balancing machine having this road force technology basically has a surface along which the tyre & wheel combo is run, to simulate a real world road surface. The effects of minor variations in the surface are checked by bouncing the combo, and weights are added to balance this effect.
I spoke to a tyre expert today, and he said that the Road Force system helps in balancing certain after-market rims, which are difficult to balance as they have a less stricter quality norms compared to an OEM / well known manufacturer like BBS.
aah78 is offline   Reply With Quote
Old 23rd November 2008, 15:20   #19
Default a few questions:
I'm planning to change the rims of my month old Fiesta (~ 500kms) to Alloys. After going through several threads on this topic, it appears i dont need to do wheel alignment (WA) but surely need to go for Wheel balancing(WB).
So questions:
1) is my understanding that i DONT need wheel alignment once i add alloys to my new car correct?
2) any recommendation on where i can get this job done in mumbai, esp in/around andheri(E).
3) rough idea of the costs involved for WA &WB
Thanks!
libocta is offline   Reply With Quote
Old 24th November 2008, 10:27   #20
Thanked: 103,418 Times
I'd still get the wheel alignment done. Most alloy dealers will do it for free anyways when you buy a new set of wheels from them.
Go to Saifee Tyres in Santacruz. Very honest & straight forward in dealing; I have got pretty much all my alloys from him. Speak to Jeetubhai on 2649.3819 / 2649.0573
Old 24th November 2008, 11:11   #21
WasavaTyres's Avatar
Thanked: 255 Times
Smile
So questions:
By mounting alloys on your car there is no way you can avoid wheel alignment. Wheel alignment settings are done using components of your car's suspension (tie rod ends and camber / caster bolts). As for the neccesity of wheel balancing aah78 has done a very explanatory job for the same
Costs would vary from dealer to dealer. No standardisation of prices there.
WasavaTyres is offline   Reply With Quote
Old 24th November 2008, 14:32   #22
Hey Wasava,
Here is your earlier post:
http://www.team-bhp.com/forum/tyre-a...tml#post334221 (Wheel alignment query.)
Then you seemed to feel that alignment is not needed if changing the rims to alloys.
So why a different opinion now?
This is only for my understanding
Old 24th November 2008, 15:42   #23
GSP9700 Road Force Measurement System
Check out this machine. It is simply awesome. A little expensive for Indian usage though. Hardly anybody buys this. In India, people dont care abt quality. They only want FREE!!!!!!!!!!!!
I want Free alignment and balancing!! If dealers invest a ton of money in these machines, it is their right to charge the customer. Unfortunately the Indian market isnt mature enough yet. Price is given preference over quality.
Anyway coming back to the Road Force measurement.
This is mainly used to correct dragging problems even if the tyre is perfectly balanced and the wheels are properly aligned.
Wheel alignment or wheel balancing?? leodelg Tyre & Alloy wheel Section 27 22nd June 2011 00:44
Breakdown Assistance for 1 year, Wheel Alignment & Wheel Balancing just for Rs 199 Mitsun Soni The Indian Car Scene 11 8th March 2011 11:02
Newbie questions - wheel balancing, wheel alignment. johy Technical Stuff 8 6th December 2006 10:39
Are wheel Balancing Weights normal on a new showroom car? Rishi Technical Stuff 4 11th May 2005 10:40
