Old 23rd March 2011, 13:27   #151
Default Re: Alloy wheel and tyre upgrade for the ANHC?
Originally Posted by donarun View Post
The size you mentioned wont fit in, the correct upsize is 195/60 R15 or 205/55 R15.
Thanks for the info. I would go for this size then 205/55 R15.
Which tyres should i go for?
Piyush_Vroom is offline   Reply With Quote
Old 26th March 2011, 07:03   #152
donarun's Avatar
Thanked: 17 Times
I think you have the Yoko S drives available at that size. They are known to have amazing grip but tend to get noisy after few thousand kms on them.
donarun is offline   Reply With Quote
Old 3rd May 2011, 18:53   #153
donarun's Avatar
Thanked: 17 Times
For OE tyres (175/65 R15) the tyre pressure mentioned by Honda is 32pse for the fronts and 30psi for the rears. Tyre gurus, what would be the ideal tyre pressure if the tyres are upsized to 195/60 R15 ? Would the same pressure levels (32,30) hold good ?
Old 3rd May 2011, 20:49   #154
I dont want to go for Yokos. ow is BridgeStone My-01?
Old 9th June 2011, 03:47   #155
satish_tns's Avatar
Thanked: 112 Times
Hi all.. Can anyone please tell me what is the offset of the ANHC stock 15'' steel rim (not the alloy) ?
(I want to know the offset value and not the pcd which is 100). Is the offset of the ANHC stock 15'' steel rim 42 by any chance?
satish_tns is online now   Reply With Quote
Old 12th July 2011, 13:20   #156
Found these on the net, can someone tell me if these are original Honda or some other brand ? Any chance they're available in Mumbai ? Are these 15s or 16s ? Thanks guys.
overboost! is offline   Reply With Quote
Old 12th July 2011, 13:57   #157
RemingtonSteele's Avatar
Thanked: 170 Times
These are original Honda Mugen accessory.
Its available in South-East asia + Australia but not available in India.
These are 15 inch alloy wheel.
In India they have other Dual Tone 7 spoke "V" 15 inch alloy, can be used for Jazz and ANHC.
RemingtonSteele is offline   (1) Thanks Reply With Quote
Old 18th October 2011, 12:02   #158
ecenandu's Avatar
Thanked: 1,791 Times
Need to change the stock tyres of my dad's ANHC. Clocked 45,000 Kms till now.Which brand should I suggest, if comfort is the top priority.
ecenandu is offline   Reply With Quote
Old 19th October 2011, 10:59   #159
ecenandu's Avatar
Any Suggestion. My Cousin's Linea also needed a shoe change.
Old 20th October 2011, 08:17   #160
ecenandu's Avatar
Two days since the first post still no reply.Any one
Old 20th October 2011, 08:38   #161
Sn1p3r's Avatar
Thanked: 230 Times
^ Michelin have the best ride comfort as personally tested on 5 ANHCs till date. You may want to upgrade to 195s if you want to upgrade the handling however FE suffers a bit.
No idea about Linea @ecenandu.
Cheers!
Sn1p3r is offline   Reply With Quote
Old 20th October 2011, 14:34   #162
ecenandu's Avatar
Cheers!
Thanks Sn1p3r. I will check out once I go home.
Old 20th October 2011, 16:33   #163
cityvic's Avatar
Thanked: 2,615 Times
The brand X2 are selling the replica of this alloy in 15inch.Though the reliability is unknown.
cityvic is offline   Reply With Quote
Old 21st October 2011, 15:07   #164
Thanks cityvic, any idea though where I could check them out in Mumbai ?
Old 22nd October 2011, 18:17   #165
Habanero City's Avatar
Thanked: 52 Times
What were your OE tires?
Do you plan to upsize for comfort at the compromise of mileage?
If you plan to stick to OE size (175/60/15), then Michelin XM1 is the best choice with respect to drive and ride comfort.
In case you plan to go 185 upsize still you can get Michelin XM1 and in case of 195 you will get Michelin Primacy.
Please read donarun's earlier posts in order to know the benefits as well as loss due to up sizing.
HC
Habanero City is offline   Reply With Quote
4th gen. Honda City : Tyre & wheel upgrade thread Screwdriva Tyre & Alloy wheel Section 350 9th May 2018 19:30
Honda Brio : Tyre & wheel upgrade thread sunnyman_46 Tyre & Alloy wheel Section 40 22nd March 2018 10:30
Honda Civic : Tyre & wheel upgrade thread shuvd Tyre & Alloy wheel Section 616 11th September 2017 14:52
Honda Accord : Tyre & wheel upgrade thread ab500 Tyre & Alloy wheel Section 29 31st July 2017 11:13
Old Honda City Type 2 : Tyre & wheel upgrade thread yuv Tyre & Alloy wheel Section 17 19th June 2015 18:04
