Old 19th November 2008, 23:47   #1
Default Can i put 165/70/r13 tyres on alloys that say they need 175/70/r13's ?
Basically my standard wheels require 165/70/r13 but when i got two replaced they put 175/70/r13.So i know you can get 175's on 165 wheels.But im buying some alloys that say they need 175/70/r13 so obviously i can put the two i currently have straight on but can i put the other two 165/70/r13's straight on aswell ?
jcoxy4 is offline   Reply With Quote
Old 20th November 2008, 02:18   #2
aah78's Avatar
Thanked: 1,752 Times
Arrow solve.
There'll be a problem only if your new rim width is more than 5.5" (<6").
If it's 5.5" or less, then no problem.
aah78 is offline   Reply With Quote
Old 20th November 2008, 02:42   #3
the new rim is 5.5j is that what you mean ? sorry i know very little about tyres
Old 20th November 2008, 03:13   #4
iraghava's Avatar
Thanked: 156 Times
Can you please tell us the width of the stock wheels to advise you better on this? And 165/175 will work fine on any wheel with a width of 5 or 5.5J.
Old 20th November 2008, 04:05   #5
Shan2nu's Avatar
Thanked: 89 Times
Theres no sense in having tyres of diff sizes. The diameter of 165/70 R13 will be smaller than 175/70 R13 which makes for an uneven ride height. Moreover, the brake balance and suspension setup of a car is designed to work with the same tyre size on all 4 wheels, changing this car cause the car to behave abnormally while braking and cornering.
U might as well buy 2 more 175/70 R13s.
Shan2nu
Old 20th November 2008, 04:14   #6
aah78's Avatar
Default 5.5j it is.
Yes, that's what I meant. Your tyres will fit just fine but consider what Shan2nu has written.
If you drive a FWD car, then it's better to have same tyres all around.
Sorry boss. His post was awaiting approval. That's why it appears before yours.
Old 20th November 2008, 04:19   #7
iraghava's Avatar
Thanked: 156 Times
That means that if your new allys are 5.5J then both 165 & 175 section tyres can go on it just fine. But if they are 6J or 6.5J then that's an issue.
No problem Sire!
Tyre UP-One Size 0f 155/70 R13 to 175/55 R14 or 185/50 R14 availability in chennai? rajeevrs Tyre & Alloy wheel Section 20 11th June 2013 23:09
Rs 2700 for Potenza GIII 165/60/R13 justified? idly Tyre & Alloy wheel Section 18 14th June 2012 16:35
whats the max size of alloys and tyres can i put to a santro cooldude585 Tyre & Alloy wheel Section 14 19th June 2006 11:09
can i fit 14 inch tyre on my ikon flair 175/70 r13 ravi Tyre & Alloy wheel Section 1 29th October 2004 10:33
