Old 22nd December 2008, 23:28   #1
Default Honda City 2006 - The Right Tire/Size
I have a Honda City 2006 iDSI MT. It currently has the stock tires (General P165/80/r13) in place. Im looking to upgrade the rims and the tires, my research yielded answers to most of my questions however some remain unanswered. I would be grateful for anyone who can help me out with the following queries:
- Upgrading to 15" rims - what adverse effects will it have with respect to: load on engine, pick and fuel consumption.
- Width/Profile - is 195/60/r15 OK or should i stick to 185 in terms of width.
- Tires - I have finalized Yokohama S Drive and Yokohama ES100 as the final choices. which one should i go for and any other suggestions?
thanks in advance.
memphisblue is offline   Reply With Quote
Old 25th December 2008, 20:04   #2
iraghava's Avatar
Thanked: 156 Times
The OE size for the City is 175/65 R14, if you have 165/80 R13 tyres then they are the incorrect size.
Old 26th December 2008, 00:58   #3
hellspawn's Avatar
Infractions: 0/1 (10)
Like iraghava mentioned,your stock tire size should be 175/65R14.
The correct upsizes in 14" are 185/60R14 and 195/60R14 while the correct upsize in 15" is 195/50R15.
You can even try 195/55R15 even though it has slightly more error,but will give you a better ride comfort.Though check whether this size doesnt foul with your wheel arches.
hellspawn is offline   Reply With Quote
Tire size and Speedo error calculator Rtech Tyre & Alloy wheel Section 38 14th April 2016 15:55
Wagon R tire upgrade, inner tire wall touching suspension Wind splitter Tyre & Alloy wheel Section 36 6th August 2012 20:43
Why rim size is as critical as tire pressures or tire sizes !! speedsatya Tyre & Alloy wheel Section 23 12th July 2011 18:00
Use of Old car tire, Tire Art! Beautifully done, Must see. SirAlec Shifting gears 2 18th March 2011 22:02
