Old 5th January 2009, 09:53   #1
Question Correct Tyre Pressure for my Hyundai Verna SX?
I have searched a lot but couldn't find the required information. I want to know the correct tyre pressure for my Hyundai Verna SX with Tyre size 175/70/R14 and it also has alloy rims. I have heard that one needs to increase the Tyre pressure after installing alloy wheels. Is that true ? I basically have only city driving in Delhi.
manujkansal is offline   Reply With Quote
Old 5th January 2009, 13:43   #2
iraghava's Avatar
Thanked: 156 Times
No, there is no need to increase pressures after installing Alloys. Please stick to the manufacturer recommended pressures which can be found in either the user manual of the car or on the driver's door sill.
Old 17th January 2009, 13:10   #3
Are the tires that come stock on the petrol and diesel Verna's the same? If so, what brand and model? Are they tubeless?
What about the rim width? Can 6J rims be fitted without any issues?
What would 14" alloys in HR, Plati, Neo cost?
luvjascha is offline   Reply With Quote
Old 13th March 2010, 19:13   #4
predatorwheelz's Avatar
Thanked: 1,122 Times
@manjukansal - The recommended tyre pressure for the CRDI SX (185/65 R14) is 30 psi (f & r) with single/dual passenger, and 33 psi (f & r) with full load. I usually fill 31 psi, runs like a dream with all loads.
@luvjascha - In case you're still out there loving jascha and accessing tbhp, here are the answers:
Yes. Earlier SX models came with 185/65 R14 and all non SX with 175/70 R14. Now afaik the standard tire size for all models is 185/65 R14.
Only 2 brands OEM. Bridgestone B250 and Apollo Accelere. Both tubeless and H-rated.
The stock rim size is 6J.
Typically around 3500-4500 a piece. I got mine for 3800 a piece.
predatorwheelz is offline   Reply With Quote
Old 13th March 2010, 19:52   #5
live2drive's Avatar
Thanked: 25 Times
Stock rim size is 5.0J or 5.5J for 175's and 185's respectively.
live2drive is offline   Reply With Quote
Old 13th March 2010, 21:22   #6
Default Whoops!
I'm sorry, stock rim size is 5.5J for 185/65 R14. My mistake.
Correct Tyre Pressure For Upsized Tyres Xehaust Tyre & Alloy wheel Section 4 2nd April 2018 10:32
Correct Tyre pressure after upsize PatchyBoy Tyre & Alloy wheel Section 20 2nd March 2011 19:11
Correct Tyre Pressure for skoda octavia autozoniac Tyre & Alloy wheel Section 3 31st May 2009 23:08
Correct tyre pressure Ricky_63 Tyre & Alloy wheel Section 4 14th March 2007 11:55
Correct Tyre pressure for ZMA. jazzy_2cool Motorbikes 8 1st March 2007 14:13
