Old 11th January 2009, 00:48   #1
Locomotive's Avatar
Thanked: 22 Times
Default Help needed - Road and Tire noise woes
I have a 2007 SX4 ZXI. while I love driving it and believe that it has very good levels of equipment (for its price), I now think that Maruti has cut a few corners when it comes to noise insulation. It is just absolutely appauling. initially it did not bother me much but now its getting on my nerves. The noise is particularly defenning when driving over concrete roads like the Mumbai Pune expressway (almost sounds like a jet turbine!!).
i think a part of the problem may be the stock 205/60 16" JK vectras. according to a tirewalla, these are perhaps the worst tires that one could use. He has suggested me Continentals or Michellins, but says that the tire noise would still persist, although at much reduced levels. my car has done 30000kms and i plan to change my tires just before the rains.
Please suggest me the other ways to improve the noise insulation in my car.
while searching through various posts on sound deadening i came across various options like mats (dynamats, american dynamics, Werth ect), sprays and underbody coating (Bardhal, Dinitrol), interesting options like using fibre glass sheets and some DIY projects. But most of these were discussions on sound damping in the ICE section. I guess the same would apply here but i am sort of illiterate in this area. I have no complains with my stock ICE sound quality (though i do have to turn it up to counter the road noise, something which i am not very fond of doing).
I am desparate to reduce the noise levels in an affordable manner. please help!!
Locomotive is offline   Reply With Quote
Old 11th January 2009, 19:33   #2
Locomotive's Avatar
Thanked: 22 Times
Gurus, where are you? need your advice.
Old 11th January 2009, 19:47   #3
Fountainheader's Avatar
I guess you can change to Michelin MXV8 205/60/R16. The best tyres with hardly any noise.
Fountainheader is offline   Reply With Quote
Old 11th January 2009, 19:54   #4
Akshay1234's Avatar
Thanked: 7,241 Times
you could upgrade to 225/50 r16. i think youd get many tires in that size. check out yokohama c-drive or michelin mxv8s. if you want to get damping done noisekill is the most vfm. i think you can contact lbm for it.
Old 11th January 2009, 20:56   #5
Locomotive's Avatar
Thanked: 22 Times
Thanks would wider tires not bring down the fuel efficiency even further? Thats the reason i might stick to stock size.
What is noise kill and how much would that cost for insulating my car?
Old 11th January 2009, 21:33   #6
my ohc tyres are also noisy i can hear it if roll down window.i am using kumho tyres so planning to replace them.
harry2223 is offline   Reply With Quote
Old 11th January 2009, 21:59   #7
Akshay1234's Avatar
i dont think you would have many options in the stock size or in 215. though ishan would be able to tell you more on that. or even kp.
noiskill is damping which costs 150 per sq ft and it will reduce the outside noise a bit and reduce your rattles.
Old 12th January 2009, 02:20   #8
iraghava's Avatar
Thanked: 156 Times
In the stock size you have the following options:
Yokohama ES501
Michelin Energy MXV8
And I wouldn't suggest anything wider since on a car like the SX4 anything more than 205's is going to be sheer overkill.
Old 12th January 2009, 09:41   #9
kpzen's Avatar
Thanked: 1,655 Times
Michelin MXV8 and Yokohama ES501 would be the best options in stock size as suggested by Ishan.
Yokohama ES501 would be lot cheaper than MXV8.
Old 12th January 2009, 12:39   #10
Akshay1234's Avatar
Yokohama ES501
oh so there are other options in the stock size. in which case id agree 100%.
Old 12th January 2009, 15:08   #11
Raccoon's Avatar
Thanked: 105 Times
Not 100% sure... but upgrading to wider tyes might increase the noise level... as there would be more rubber in contact with the road.
Old 12th January 2009, 21:41   #12
Thanked: 32 Times
My suggestion go for Michellins, MXV8 is very good tyre with excellant comfort almost ZERO noise. It might be costly to buy you would enjoy every bit of it.
Please stick to stock size to get better ride comfort and to avoid decrease in FE.
Ravi.
ravibhat is offline   Reply With Quote
Wagon R tire upgrade, inner tire wall touching suspension Wind splitter Tyre & Alloy wheel Section 36 6th August 2012 20:43
Why rim size is as critical as tire pressures or tire sizes !! speedsatya Tyre & Alloy wheel Section 23 12th July 2011 18:00
Use of Old car tire, Tire Art! Beautifully done, Must see. SirAlec Shifting gears 2 18th March 2011 22:02
Tire woes in 2008 NHC wildsdi5530 Tyre & Alloy wheel Section 32 27th December 2009 22:24
Any advice on Optra 'thumping' tire/road noise at 40KPH Ravich Technical Stuff 12 9th September 2007 21:10
