Old 28th April 2014, 17:44   #151
saket77's Avatar
Thanked: 4,254 Times
Default Re: Aftermarket basic plain looking alloys
IMO, you don't have to wary of any of the two. Both the OEM alloys or aftermarket ones seldom fail. Yes, if you hit a pothole at a very high speed, you may break them off, but I have hit them many times at high speeds (happens at times on our highways) but all 4 Neo alloys are just fine.
saket77 is offline   Reply With Quote
Old 28th April 2014, 19:56   #152
Thanked: 30 Times
Originally Posted by CR-V View Post
I do like the linea design and ticks all the boxes, though they cost around 11k each. Would like to explore my options before spending that.
11000 each
In the aftermarket, if you haggle a lot you can get all 4 alloys for that much money. No point wasting that much money for alloy! Try to find something that looks close to the linea OEM design in the out side market.
Mohitkumaar is offline   (1) Thanks Reply With Quote
Old 28th April 2014, 20:04   #153
100kmph's Avatar
Thanked: 92 Times
Another good option is to search for OEM alloys from tyre shops. Some people discard their tyres and alloys on the day of purchase itself. They will be brand new at a fractional price.
100kmph is offline   Reply With Quote
Old 28th April 2014, 20:31   #154
khoj's Avatar
Thanked: 1,253 Times
I believe you would do well to recheck the Linea's alloy pricing.
Fiat currently has an offer going on 15" alloys for an old design that used to come with Palio and later Punto. This is a set of 4 available for 9990/-. Will fit on the Linea too since the PCD is same as is the offset, the design is classic and elegant.
Old 28th April 2014, 21:55   #155
CR-V's Avatar
The entire set? for that much so 2.5k per alloy?
Or is that per alloy price?
Any specific dealer you spoke to? Would appreciate if you could pass on the name and city
Reading through some stuff. Is Hyper Silver the finish you see on most stock alloy wheels?
Last edited by Aditya : 29th April 2014 at 12:50. Reason: Merging back to back posts
CR-V is offline   Reply With Quote
Old 28th April 2014, 22:31   #156
Thanked: 61 Times
That is 19960 for a set of 4.
Mistakenguy is offline   (1) Thanks Reply With Quote
Old 28th April 2014, 22:57   #157
khoj's Avatar
Hi, it is 19960/- so that is ten grand more than what I said it was, guess I wasn't paying attention. See below my mistake pointed out by Mistakenguy.
Old 28th April 2014, 23:03   #158
CR-V's Avatar
Ok, though I am guessing it would 15" rather than 16"
Also punto alloys are a bit sporty looking rather than straight linea ones.
But at least gives me a base to work off from. One possible item is better than none
Old 29th April 2014, 14:49   #159
CR-V's Avatar
Default Re: Tire upsizing on linea
Post deleted by the Team-BHP Support : Please do NOT post messages that add little or no informational value to the thread. We need your co-operation to maintain the quality of this forum.
Please read our rules before proceeding any further. We request you to post ONLY when you have something substantial to add to a discussion.
CR-V is offline   Reply With Quote Received Infraction
Old 30th April 2014, 11:41   #160
WasavaTyres's Avatar
Thanked: 239 Times
Wink Re: Tire upsizing on linea
I'd recommend the 15" with 195/60/R15 tyres, or if you want an even plusher ride, the 205/60R15 tyres.
WasavaTyres is offline   Reply With Quote
Old 30th April 2014, 11:47   #161
Thanked: 239 Times
Wink Re: Aftermarket basic plain looking alloys
I reckon you do a price check. With the anti-dumping duty having come into effect the chinese / taiwan made alloys have moved north of 17-18 K for a set of four 15"and Neo wheels has crossed the 22K mark (with bill)
Old 30th April 2014, 23:09   #162
thumpingbull's Avatar
Default re: Fiat Linea : Tyre & wheel upgrade thread
Having gone through the thread, got a great insight on the tyre scene.
My Linea Emotion Pack has done 35K with the stock Goodyears. Have taken it in the roughest of roads in the North East. I was planning to change the tyres in the near future, however, today I was shocked to see both the front tyres worn out from the inside and showing the steel.
Questions
Could it be due to a faulty allignment?
Do the tyres wear out faster as they near the fair life?
Whats the expected fair life? (of course it depends on the driving skills)
Should I go in for a 195/65? Does it affect the GC without any problems?
Please suggest and help BHPians.
thumpingbull is offline   Reply With Quote
Old 1st May 2014, 13:34   #163
Sommos's Avatar
Thanked: 674 Times
Questions
Ans. : The uneven wear is due to faulty alignment, no doubt. But it can also be due to suspension problem.
Ans. : No, rather the wear depends on your driving style and also on the fact how you use the car (or rather abuse it). If you drive on bad roads, or drive fast and brake hard, you can reduce tyre life by almost half.
Ans. : Roughly 4-5 years and 40K KM. There is a "thread wear indicator" on all tyres and when they are exposed it is time to change your tyres.
Ans. : Ideally, when buying new tyres, stick to the car manufacturers recommended size. Usually this is the size provided on the top-most variant of the model of car that you have and in your case it is 205/55/R16. or 195/60/R15.
The replies are given in bold, hope it helps.
Sommos is offline   Reply With Quote
Old 3rd May 2014, 10:50   #164
CR-V's Avatar
4 tryes on wheel are apollo, but spare tyre is JK tyre for a new linea. Is this normal?
Old 3rd May 2014, 13:51   #165
Sommos's Avatar
Thanked: 674 Times
There is nothing wrong with this and this is common across many brands.
In the 2014 Linea Emotion model, reviewed by NKrishnaP, whereas the regular tyres are GoodYear Eagle NCT 5 205/55/R16, the spare is 195/60/R15 Apollo.
4th gen. Honda City : Tyre & wheel upgrade thread Screwdriva Tyre & Alloy wheel Section 336 15th December 2017 01:48
Fiat Punto : Tyre & wheel upgrade thread furioussphinx Tyre & Alloy wheel Section 651 25th August 2017 21:54
Fiat Palio : Tyre & wheel upgrade thread shahmotors Tyre & Alloy wheel Section 637 26th March 2017 12:56
Hyundai Grand i10 & Xcent : Tyre & wheel upgrade thread jkdas Tyre & Alloy wheel Section 10 29th August 2016 17:08
