Old 25th March 2009, 15:13   #1
sureshshanmugam's Avatar
Default Baleno - Rear wheel scrapping with 15 inch wheels
I have just fit 15 inch wheels with HR alloys in my 2006 Baleno LXI. The rear wheel side walls scrap with mud guard sides in the front when the boot is loaded and go on bumps.
Can anyody suggest a solution and where I can get it done in Chennai...
sureshshanmugam is offline   Reply With Quote
Old 25th March 2009, 15:31   #2
Rudra Sen's Avatar
Thanked: 4,295 Times
Check out suspension. Go through this thread (Baleno Wheel thread) and post your question there. You'll get better response.
Old 25th March 2009, 15:37   #3
rjstyles69's Avatar
Thanked: 795 Times
Suresh my obvious question, what size tyres... hmmm wait let me guess 205/50/R15 ?
Old 25th March 2009, 15:58   #4
Proxima's Avatar
Post some pics dude.
Proxima is offline   Reply With Quote
Old 25th March 2009, 16:06   #5
crazydiablo's Avatar
Thanked: 21 Times
Either you are running 205 tyres or you offset is wrong. Cheapest solution being folding you rear wheel wells to expensive solution being hardening your suspension.
crazydiablo is offline   Reply With Quote
Old 25th March 2009, 18:04   #6
Hi rj, the tyres are 205/55/R15
Old 25th March 2009, 23:44   #7
Thanked: 21 Times
So thats definitely the wrong profile. Your problem is the 205 size compounded by the wrong profile for the baleno. 195/55R15 will not have this issue.
Old 26th March 2009, 00:56   #8
nitrous's Avatar
Thanked: 285 Times
Who sold you the tyres?
Old 26th March 2009, 01:35   #9
revtech's Avatar
Thanked: 35 Times
the correct upsize should be 195/50 R14 or 205/40 R15.as mentioned the profile is wrong
rev
revtech is offline   Reply With Quote
Old 26th March 2009, 01:39   #10
autopsyche's Avatar
Thanked: 15 Times
205/50 works perfect on the baleno... 55 is a bit too tall for the stock car it will definitely foul.
autopsyche is offline   Reply With Quote
Old 26th March 2009, 09:04   #11
kpzen's Avatar
Thanked: 1,655 Times
205/55-15 is too tall for Baleno and also an overkill for the car.
205/50-15 will not foul with the body but may foul with the mud flaps which also depends on the alloys specification.
195/60-14 is a perfect upsize for Baleno IMO.
195/55-15 also works fine but why spoil the great ride quality of the car.
Old 24th April 2009, 11:11   #12
spadival's Avatar
Thanked: 16 Times
Exactly the same problem as I have with my Baleno
Only solution is to get new tyres with the correct size. I would recommend 195/55/R15 - This was the size of the previous tyres on my car. Dunno why I screwed up, but I don't drive the car anymore, so its ok.
spadival is offline   Reply With Quote
Old 24th April 2009, 11:15   #13
iceman91's Avatar
Thanked: 22 Times
if tyres are brand new then to get new tires cost is around 15-16k. depending on tire.
Else get stiffened suspension for 4k, ride is compromised.
Get the wheel wells rolled in a little bit. Cost around 200-300rs labour.
205/40/15 being correct upsize??? rev are you sure?
iceman91 is offline   Reply With Quote
Can I fit 15 inch wheels in Indica/Indigo? vivekgk Tyre & Alloy wheel Section 18 26th September 2014 16:55
Are Indica NA speedos' calibrated for 14 inch wheels? Zappo Tyre & Alloy wheel Section 9 17th June 2010 09:40
Looking for AMG 17 inch Wheels (pic inside) for W124 '96 E220 Screwdriva Tyre & Alloy wheel Section 6 26th August 2008 15:38
13 inch versus 12 inch wheels for the ZEN raghuram.cg Technical Stuff 5 30th March 2006 08:10
