Old 1st April 2009, 10:37   #1
Jaskirat's Avatar
Thanked: 175 Times
Default Wheel Alignment Data for Ford Fiesta
Hi Guys,
Would appreciate if someone could share with me the wheel alignment data for Ford Fiesta 1.6 SXi (2006).
Most of the wheel alignment service providers (atleast) in Chandigarh use European Ford Fiesta Data, that too from MkV Fiesta. I suspect this is not correct.
Look forward to your feedback and advise.
Jaskirat Singh
Jaskirat is offline   Reply With Quote
Old 1st April 2009, 16:30   #2
Nikhilb2008's Avatar
Thanked: 6,637 Times
You should raise hell! It is a completely different car.
For the Indian Fiesta, this is the data.
Front:
Camber: -0deg 30'. Tolerance of +- 1deg 15'
Caster: 3deg 30'. Tolerance of : +-1deg
Total Toe: 0deg 24' +-10deg
Rear:
Camber: -1deg 08'. Tolerance of +-1deg 15'
Total Toe: -0deg 32' . Tolerance of +-10'
Nikhilb2008 is online now   Reply With Quote
Old 1st April 2009, 17:11   #3
Front:
Rear:
It should be tolerance of 10'. Not 10 degrees. Typo there. It's too late to edit my post.
Old 1st April 2009, 17:31   #4
unni.ak's Avatar
Thanked: 80 Times
Dumb Question: This will be the same for diesel Fiesta also, right? Mine is a 2008 Zxi TDCi.
unni.ak is offline   Reply With Quote
Old 1st April 2009, 22:56   #5
Yes. It will be exactly the same.
Old 2nd April 2009, 15:48   #6
unni.ak's Avatar
Thanked: 80 Times
Thanks for the clarification Nikhil.
Old 2nd April 2009, 19:12   #7
Jaskirat's Avatar
Thanked: 175 Times
Front:
Rear:
Thanks for the information Nikhil. The information you provided will be most useful. I believe me ... hell I will definitely raise.
Jaskirat
Wheel Alignment Data for MM550XD Jaskirat 4x4 Technical 4 5th September 2011 10:38
Wheel Alignment Data - Ford Endeavour 4x4 ssh1979 Tyre & Alloy wheel Section 7 31st August 2011 21:35
Wheel Alignment Data for i10 NFS2024 Tyre & Alloy wheel Section 8 2nd April 2009 17:59
Newbie questions - wheel balancing, wheel alignment. johy Technical Stuff 8 6th December 2006 10:39
