Old 22nd June 2009, 17:44   #16
Nikhilb2008's Avatar
Thanked: 4,801 Times
You mean MXV8. Not MXVX
They are great tyres. Congrats!!
Old 23rd April 2015, 21:28   #17
Arrow Honda Accord 2004 V6 vTec needs new Rubber for the tarmac
Mod note: Please use Search before opening a new thread. Thanks.
Greetings fellow Team-bhpians,
I am new around here and recently had joined this wonderful community.
Currently i have my Accord getting a complete gearbox overhaul and suspension replacements after it crossed 122,000 kms.
Apparently the tyres need replacing too. I am not keen on upgrading the alloys. Like the stock 16 inch rims.
I did find that the standard size tyres 205/60/r16 are quiet small for a v6.
I decided to upsize my tyres to 225/55/r16 with almost no error.
Dear members i need your opinions regarding the following tyres.
1. Pirelli P7 Cinturato
2. Michellin Primacy 3ST
3. Hankook Ventus ME01
The travelling will be in city and occasional long drives.
I am looking for comfort and low or no noise.
Also would it be good purchasing tyres at the shop or online.
Thanks in advance
MrIncredible is offline   Reply With Quote
Old 23rd April 2015, 21:47   #18
Jaggu's Avatar
Thanked: 7,475 Times
Default Re: Honda Accord 2004 V6 vTec needs new Rubber for the tarmac
Do check if they have Yokohama Earth in the size you are planning for. Value for money and very decent tyres for your requirements.
As far as buying i would suggest checking prices online and see if you can get the same at your local tyre shop by quoting the same. Less hazles and better overall deal with alignment and balancing factored in. Even if it is couple of hundreds more
Old 23rd April 2015, 22:28   #19
Akshay1234's Avatar
Thanked: 6,670 Times
Thanks in advance
Would suggest the Michelins at no 1, followed by the Pirellis. The Michelins would give you a comfortable and silent ride, along with improving the braking due to the increase in width.
Do consider a shock absorber upgrade, it is 100% worth it for the extra stability and handling provided without comprising much on ride.
IMO the Yoko Earth is a budget tyre compared to the ones mentioned above, and it will only be better than them in longevity.
Old 24th April 2015, 11:03   #20
Jaggu's Avatar
Vidyut have them on his Altis and i felt they are pretty good VFM tyres, IMHO Michellins are over rated and offer very poor value for money. However good they might be.
Old 24th April 2015, 11:58   #21
Are the Yoko's Grippy?
Old 24th April 2015, 15:28   #22
Jaggu's Avatar
For the usage mentioned above, more than enough, infact much better compared to few of the indian brands. So grip is something i wouldn't worry about. Road noise is there at very high speeds though.
Old 21st July 2015, 10:54   #23
prashant.dinkar's Avatar
Thanked: 52 Times
Default Help with Honda Accord
Hi Guys,
I need your help here. Actually I should have posted this before doing it.
I recently changed tyres and rims on my 2012 Honda Accord (4 Door)
New rims are of 18 Inches with 225/40/R18 Dunlop Direzza DZ101.
My daily running is not much but average speed stays at 100KMPH and highest I go is 160-170KMPH and all this happens in extremely hot conditions as I stay in Dubai.
I want to know if the tyre/rims upgrade is correct or not and most importantly is it unsafe to drive with these specifications (tyre burst etc.)
Though I have invested significant amount of money in this purchase but I am ready to change the setup completely if the current one is not safe enough.
Please help.
prashant.dinkar is offline   Reply With Quote
Old 21st July 2015, 15:50   #24
Rehaan's Avatar
Thanked: 22,604 Times
Default Re: Help with Honda Accord
What size were the stock wheels / tyres?
Two things to check, to ensure your safety:
1) The "Speed Rating" of the tyre you bought
2) The recommended tyre pressure - stick to it.
Rehaan is offline   (1) Thanks Reply With Quote
Old 21st July 2015, 17:12   #25
Thanked: 52 Times
Stock wheels were of 16" with tyres 215/60 R16
Speed rating is W" which translates to 270 KMPH
How do I find the recommended tyre pressure? I was doing 32 psi on my old tyres as it was written on the door sills.
Sorry for the noob questions.
I really appreciate you taking time out and answering my question.
Best Regards
Old 21st July 2015, 18:14   #26
Rehaan's Avatar
I guess 225/45 or 225/50 R18 might have been slightly more suitable, if available - thought it's not a big deal at all.
No issues here. The speed rating means you can drive @ 270 km/h constantly for an hour, without doing any damage to the tyre.
This is where I'm not sure I'm correct (and despite what most people say, they aren't either).
I think the correct way is looking up load/inflation charts for your old & new tyres, and then finding the PSI at which they match.
More info in the PDF attached. (Source)
My guess is that 32-34 PSI should be okay - but if i were you I'd definitely do some more research.
Old 21st July 2015, 18:18   #27
Thanked: 52 Times
Thank You. Much appreciated
Old 27th May 2016, 17:26   #28
thegame's Avatar
Default Re: Honda Accord : Tyre & wheel upgrade thread
I have a 2009 Honda Accord V6 sedan and am looking to upgrade the wheels and tires. The stock wheel is 17x7 with an offset of 45 (I may be wrong about this) with a tire size of 225/50R17.
I'm looking to get a 19x9.5 wheel with offset 25.
http://www.discounttiredirect.com/di...3&wd=19&rw=9.5
The plan is to go for a 255/35R19 tires. I did some research and came up with this.
http://www.wheel-size.com/calc/?whee...=30mm&scl=50mm
Will this fit in my car without rubbing anywhere? Do you recommend any other sizes?
Any help you can offer will be much appreciated.
Cheers!
thegame is offline   Reply With Quote
Old 30th July 2017, 01:25   #29
I bought a Honda Accord V6 2006 a couple of days back. It has Continental 205/60/R16 tyres. They're too thin for the car - feels wobbly at high speeds. Fitting 225/55/R16 Michelin Primacy ST3s on them, along with Momo Quantum Anthracite wheels.
The dealer seemed to insist that I go with R17s, but really didn't want to go with them. After some internal debate between 215/55/R17, 225/50/R17, 225/55/R17, I decided to stick to stock radius and sidewall height and went with 225/55/R16 with almost no error.
samirotiv is offline   Reply With Quote
Old 31st July 2017, 11:13   #30
mrpitt's Avatar
Thanked: 66 Times
Cheers!
I had upgraded my 2.4 Accord to 225/50/R17 tyres and rims. In my search for the used car had also driven an accord with 18 inch rims and 45 profile rubber. My two cents is stick to the 17s. I found the ride quality of the 18s way to hard and bumpy on the stock suspension.
Obviously if you are planning a full suspension upgrade as well its a different matter. Do keep in mind that upgrading your rims and tyres to such a size will also add a lot of stress to the PS Pump/Rack (speaking form experience of the Accord) not to mention possible leaks in the struts.
mrpitt is offline   Reply With Quote
4th gen. Honda City : Tyre & wheel upgrade thread Screwdriva Tyre & Alloy wheel Section 336 15th December 2017 01:48
Honda Jazz : Tyre & wheel upgrade thread Kenneth Tyre & Alloy wheel Section 124 10th December 2017 11:51
Honda City : Tyre & wheel upgrade thread drajesh Tyre & Alloy wheel Section 317 12th September 2017 07:16
Honda Civic : Tyre & wheel upgrade thread shuvd Tyre & Alloy wheel Section 616 11th September 2017 14:52
Honda Brio : Tyre & wheel upgrade thread sunnyman_46 Tyre & Alloy wheel Section 39 7th September 2017 13:06
