Old 14th May 2009, 17:32   #1
MMY56's Avatar
Default Best Tyre options for Premier Padmini
Hello All,
I would like to know what tyres are best for Premier Padminis.
Im planning to get all four changed on my car.
I need something with will give better traction, provide better control on bad roads.
I am having this problem where my car seems to sway slightly at times when I drive. I got both my fromt and rear suspensions done and got all bushings changed. Havent done wheel alignment yet. The swaying problem has improved greatly but I can still sometimes feel that it can be better.
Will getting wheel alignment help?
A friend of mine suggested Michelin radials, but Im not sure if I can get them in the right size.
BTW, what is the right size for Padmini tyres?
Manish
MMY56 is offline   Reply With Quote
Old 10th December 2009, 22:48   #2
Mehul1100's Avatar
Thanked: 13 Times
Go for Maruti Swift radial tyre, if you really want to deviate from actualls. But the steering will be bit tuff to handle. If your rims are in good condition you can enjoy tubelss too.
Happy driving, wear seat belts.
Mehul1100 is offline   Reply With Quote
Old 10th December 2009, 23:28   #3
Thanked: 360 Times
Yokohama Advan Neova, Perhaps??
Stick to Steel belted Bias/ Crossply tires.
MRF SW 99 or something like that..
wildsdi5530 is offline   Reply With Quote
Old 11th December 2009, 11:50   #4
planet_rocker's Avatar
Thanked: 368 Times
My padmini has 165/80 R14 82T GoodYear GPS2s on all 4. Steering is a bit hard while the car is stationary but works like a charm if you roll the car a bit. the grip is far better.
Most FIAT enthusiasts will NOT recommend Radial tyres - they prefer Crossply-s 5-20-14.
IIRC OE to swift vxi is 165/80 R14.
EDIT: this is a very OLD thread - request mods to lock it or something.
planet_rocker is offline   Reply With Quote
Old 11th December 2009, 22:57   #5
Iamlegend's Avatar
Talking
Could anybody advice me on this-
What would be the best tyres for my premier 118 ne??
Iamlegend is offline   Reply With Quote
Old 12th December 2009, 13:20   #6
predatorwheelz's Avatar
Thanked: 1,122 Times
Well the 118NE came with a 5.60X13 tyre size as standard. Many people say that a car which came with crossplies as original should be kept as such. If you want to stick with them, look for a brand called MRF Twintread which is available in that size. I think Ceat also makes something in that size.
However, if you want to switch to radials (and this would be my personal recommendation) 5.60X13 works out to roughly 165/80 R13. Its a commonly available size. Go for MRF or Apollo and save some money.
predatorwheelz is offline   Reply With Quote
Old 10th July 2010, 12:30   #7
Thanked: 13 Times
My uncle in Kerala needs 2 tyres for the Premier President, he is unable to give me proper specs. I was told 230/14, obviously there is some confusion on thier part.
Few people have asked around but unable to source in BLR/KL
Help from the Fiat fans?
Old 10th July 2010, 13:13   #8
Thanked: 368 Times
if he is looking for radials - then ideal size is 165/80 R14 - some people even select 155/80 R14
if he is sticking to normal cross-ply, then 5-20-14.
Hope this helps.
Old 11th July 2010, 11:54   #9
Thanked: 13 Times
Hope this helps.
Ah this is what was requested, very difficult sourcing these here, apparently multiple dealers were requested.
Anyone? I guess Mumbai will have as there are so many cabbies?
Old 1st September 2010, 11:00   #10
silverado's Avatar
Thanked: 688 Times
Default I found my tyres
Hey Planet rocker!!
I ve recently fitted 155/80 r 14 which are extremely rare - bridgestone S248 upfront and have 165/80 r14 bridgestone S248 at rear.
I am really enjoying them very much , since my older tyres were remoulded ones!
I was planning to buy MRF TWIN TREAD 5.20 - 14, but they are out of stock due to very low supply.
Also TWIN TREAD has smaller contact area compared to MRF LEGEND ( Which is no more produced ).
So if you are lucky you can get 155/80 r 14 upfront.
Alongwith bridgestone , JKTYRE used to produce TORNADO of the same size.
The other option could be fitting New Wagon R VXi's 155/60 R 14, but that will reduce the ride height upfront.
Fitting 165 upfront might make the steering heavy, especially if you do not have a standard steering wheel.
silverado is offline   Reply With Quote
Old 1st September 2010, 12:56   #11
Thanked: 368 Times
This car has 155/80 R14 in the front and 165/80 R14 in the rear:
My car has 165/80 R14 in front and rear - i have not faced any problems since 2007 (steering is a bit heavy - but i love it that way) - oh! this car has a MOMO steering wheel:
Old 1st September 2010, 20:47   #12
Thanked: 716 Times
I have MRF legend in the front(rebuilt, smaller width than the original) and JK tornado at the back. This way, steering is not heavy and ride is a bit better too. 155/80R14 will reduce GC. Even the 165/80R14 is a bit lower(radial, so curved sidewall) than the 5.2 x 14, but no other go.
ramzsys is offline   Reply With Quote
Old 7th September 2010, 19:05   #13
silverado's Avatar
Thanked: 688 Times
Thumbs up Cross plies
Advantage RADIALS :
Better Braking
Better Handling
Better Ride quality
Better looks
Lesser vibrations
Ride height will hardly be affected.
Steering bit heavy, but thats alright.
Old 23rd September 2010, 07:24   #14
Thanked: 716 Times
From a friendly tyre dealer, i got a set of 5 MRF ZV2K tyres which were used in a swift. It has half life left in it, and man, what a change to the Padmini!! Road feel via the steering is not the sameas compared to MRF legend cross-ply, but otherwise in all aspects radial is better.
PS : Front suspension have a negative caster, so the steering is still lighter.
Query : Two tyres have alternate raised edges throughout the shoulder of the tyre. I heard it is inherent in MRF Zv2k. Is it dangerous to use these tyre?
Old 10th January 2012, 23:16   #15
Thanked: 716 Times
Default Re: Best Tyre options for Premier Padmini
Can i fit the Fiat Punto's stock rims(14 inch) to the Premier Padmini?
The car is running on stock rims with 165/80 R14 tyres. There are many bends in the rims, so contemplating a change.
The lovely Premier Padmini S1 (Fiat 1100-D) Ram The Indian Car Scene 393 28th May 2018 15:40
Ambassador, Premier Padmini Specs ?? Technocrat The Indian Car Scene 69 22nd February 2010 16:38
What replacement engine for FIAT-1100D (premier padmini) hasopi Modifications & Accessories 26 11th December 2009 23:26
Used Maruti800, premier padmini , premier 118ne ? sakharamcool Hatchbacks 8 27th May 2008 11:17
Air-Con for 1987 Premier Padmini? newcoolgadgets Technical Stuff 7 14th March 2007 19:13
