Old 22nd March 2010, 23:28   #136
wingsoffires's Avatar
Naveen,
I suggest you also look at Yokohama A Drives. I got a Ritz for a friend 3 days back with standard 165 80 R14's. I helped him in getting Yoko's installed only yesterday for a price difference of 6000 Rs for four tyres ( 185/70 R14 ). I have the same tyres installed in my Ritz Lxi that I got last year and the performance of the tyres definitely is much better compared to the standard JK's.
wingsoffires is offline   Reply With Quote
Old 23rd March 2010, 11:03   #137
Originally Posted by Nikhilb2008 View Post
XM1+ is 3800/- per tyre. You can get about 2200 for the 185/70 R14 JKs.
Thanks Nikhil for the details. Can you let me know if you know any good tyre shops in Bangalore? You can PM me the details. I remember there was a thread also about it. Trying to find it.
Originally Posted by wingsoffires View Post
Naveen,
Wingsoffire,
Thanks for the tip. I am using XM1+ on our swifts for some time now. You can say i have a liking or a soft corner for Michelins
Last edited by Eddy : 23rd March 2010 at 13:35. Reason: Please use the edit / multiquote option instead of posting back to back posts within 20 mins. Thanks.
naveenvenkatesh is offline   Reply With Quote
Old 26th March 2010, 22:56   #138
Schoudhury's Avatar
Thanked: 470 Times
Thanks Nikhil and wingsoffires . Appreciate your help on this .
I was really confused over it .
Ok then, i would stick to the 14'' only. For the time being planning to just get a good set of alloys and will keep the stock JK for sometime .
Will get a thread created shortly with all the details.
Cheers.
Schoudhury is online now   Reply With Quote
Old 3rd June 2010, 15:39   #139
fiat_tarun's Avatar
Thanked: 586 Times
Guys, how will 195/60 R14's suit the Ritz in terms of ride comfort and FE ? Are S-drives available in this size and profile ? and lastly can anybody suggest a good tire guy for both alloys and tires in Pune...
fiat_tarun is online now   Reply With Quote
Old 3rd June 2010, 16:53   #140
funnyguru's Avatar
Ritz is heavier than its counterparts, also with the upgrade it will definitely impact the FE . The ride comfort may be stiffer depending on where u drive.
funnyguru is offline   Reply With Quote
Old 3rd June 2010, 19:19   #141
pullikutty's Avatar
Hi Nikhil,
How about goodyear G7 of 185/70 R14 size for Ritz
pullikutty is offline   Reply With Quote
Old 3rd June 2010, 19:36   #142
Nikhilb2008's Avatar
Thanked: 5,101 Times
S drives are not available. also, 195/60 R14 is the wrong size for Swift. You need 195/65 R14.
Right. Ride quality with 195/60 R14 will be really bad. Even with 195/65 R14, it will be worse than 185/70 R14.
Originally Posted by pullikutty View Post
Hi Nikhil,
No idea. Dont know much about it.
Old 3rd June 2010, 20:15   #143
fiat_tarun's Avatar
Thanked: 586 Times
Thanks guys. Was for a friend. Will advice him to go with 185/70 R14 A-Drives
Old 3rd June 2010, 20:33   #144
fine69's Avatar
Thanked: 867 Times
I'm driving Swift with Michelin XM1+ 185/70 R14s and the comfort and handling is just brilliant. I'm assuming the size of the Ritz tyres are the same as Swift and there's nothing better than Michelin XM1+ 185s and alloys would look better than how they would look on stock tyres.
fine69 is offline   Reply With Quote
Old 19th June 2010, 09:43   #145
Lemon's Avatar
Hi All,
I will be upgrading my tyres on my Ritz Vxi that came with Bridgestone Tyres as OEM. I understand here in the forum that many of your cars came with JK tyres. Has MUL changes the OEM tyre from JK to Bridgestone.
Also will be upgrading to MOMO alloys with Michelin Energy XM+.
Lemon is offline   Reply With Quote
Old 10th July 2010, 11:03   #146
navan49's Avatar
Thanked: 69 Times
Can any one faced problem of keeping the spare wheel in right position like the Maruti stock wheel. I am worried if I upgrade for Michelin with 185X70X14 will the spare will be accommodated or not? The other question is that I want to upgrade the above in the steel Rim not on Alloys. Will it work.
navan49 is offline   Reply With Quote
Old 15th July 2010, 14:39   #147
rx2389's Avatar
Thanked: 12 Times
There shouldn't be any problem in keeping the spare wheel since Ritz ZXI already comes factory fitted with 18/70/R14
rx2389 is offline   Reply With Quote
Old 18th July 2010, 22:41   #148
just upgraded to Michelin 185/70 and the comfort it's drawing is amazing...!!
Could anyone confirm if the bolt that secures the spare tyre in the dickey can be sourced from the ZXI variant ?
vinayak007 is offline   Reply With Quote
Old 25th August 2010, 19:36   #149
Schoudhury's Avatar
Thanked: 470 Times
I recently changed my stock rims on my Ritz to Neo Dizzy Black Machined red Lip 14"X5.5" alloys,using the stock JK rubbers for the time being and have few quires for same .
1.What should be tyre pressure that i should maintain for the same for the same ?
2. Also i have noticed that the Tyre are slightly projected outwards, not sure if this normal or there is something that needs to be checked or adjusted .
Has any one else also noticed the same on their Ritz after the tyre or alloy upgrade .
Also when i change the rubbers to 185/70 R14 from the stock 165/80 R14 will it get more projected outwards.
I thought upgrading to ZXI size alloys was perfectly safe .
Please advise .
Old 31st August 2010, 11:54   #150
It is more than one year since i started this thread and my car has clocked 25K today. I would say Michelin XM1+ are awesome. I never noticed any wear and tear in the tyres evern after 25K, they still look new. Thanks Nikhil for pointing the right set of tyres.
funda2max is offline   Reply With Quote
Maruti Suzuki A-Star : Tyre & wheel upgrade thread JKBKS Tyre & Alloy wheel Section 61 1st January 2018 09:49
Maruti Suzuki Swift : Tyre & wheel upgrade thread hemlock Tyre & Alloy wheel Section 2062 13th December 2017 17:22
Maruti Suzuki Alto : Tyre & wheel upgrade thread abhibh Tyre & Alloy wheel Section 361 24th October 2017 10:36
Maruti Suzuki WagonR : Tyre & wheel upgrade thread iWonder Tyre & Alloy wheel Section 80 19th September 2017 09:34
Maruti Suzuki SX4 : Tyre & wheel upgrade thread loving_alaap Tyre & Alloy wheel Section 265 2nd July 2017 08:16
