Old 26th November 2010, 23:00   #256
Thanked: 31 Times
Dear All,
I have booked a GP and awaiting delivery. In the meanwhile, I am finializing on the accessories. I have booked the active variant which does not come with factory fitted alloys. I plan to go for 14" alloys (dont want to sacrifice the mileage for the sake of performance by going for 15" : please correct me if i am wrong when i assume that 15" would mean mileage takes a beating).
My question to gurus is what is the best size of tyres if I plan to go for 14" alloys.
I was suggested 185/65 by a couple of tyre dealers. Is this ok, or should i stick to the 175/70 as is given by the fiat for emotion variant.
Thanks in advance.
vidyasagar is offline   Reply With Quote
Old 27th November 2010, 03:03   #257
torqueyTND's Avatar
Originally Posted by .anshuman View Post
The 195 section tires which come as OE with the Emotion Pack variants of the Punto have adequate grip to take care of the all the performance Punto has to offer(All engines). I Agree, the Goodyear GT3 are not very good tires but they perform really well in my Punto. The Grip in corners and when hard braking is more than adequate.
However, expect things to improve after the upgrade to better quality rubber. Regarding increasing rim size and going in for lower profile tires- The ride quality will suffer. If your local road conditions and your requirements permit, upgrade to 16" rubber.
Personally i like the VFM, Grip, Comfort and Availability combination offered by Yokohama db V550 tires.
I completely agree with , +1 to you
Some how thats what happened with my ride
I had the 14inch stock JK tornados and i really hated it since day one of ownership. I then decided to either stick to better tyres on 14 inchers stock rims or trade it off and settle for 15 inchers alloys with better rubber as the stock Emotion pk and the 195 section (C drive ) is just doing that - no complaints! I think she still has -0.70 error on the odo.
I have set of 4 wheels in 15 inchers alloys with C drives
Use the 5 sparewheel(stock Tornado's) as a babytyre..just in case
if i do end up having a flat tyre scenario
I think 15 inchers with 195 sections better tyres remains an ideal
upgrade - In my opinion
TND
torqueyTND is offline   Reply With Quote
Old 2nd December 2010, 17:22   #258
vsk2009's Avatar
Thanked: 23 Times
I am having an 1.4 Emotion with 175/70 R14 Bridgestone. How is the quality of Bridge stone. Noise is very high inside the cabin. What will be the ideal upgrade
1. Without changing wheel
2. With the option of changing wheel.
Will handling and ride improve lot by changing to alloys?
vsk2009 is offline   Reply With Quote
Old 8th December 2010, 10:56   #259
hemanth.anand's Avatar
Thanked: 7,000 Times
Default re: Fiat Punto : Tyre & wheel upgrade thread
Originally Posted by vidyasagar View Post
Dear All,
Thanks in advance.
Vidyasagar,
You can refer to the table i have put in the previous page.
The tyre diameter is noway linked to mileage.
It is the width of the tyre that affects mileage.
More width=More friction=Less Mileage.
More diameter=error on the ODO thats all.
But in the case of the GP standard tyres, 15 inch tyres are wider as well. so the 15" will give you less FE but very negligible though (1km-2kms max).
When you are buying a Diesel, why are you so much worried about a kilometre of less FE
I'm waiting for options in 98PCD 16" alloys which is what i'm targetting. Linea TJet+ alloys are 11k per alloy so thats out of my budget.
hemanth.anand is offline   Reply With Quote
Old 8th December 2010, 11:04   #260
Thanked: 20 Times
Try to get michelin xm 1+ . They offer good mileage and grip , lasting in my front even after doing 21 k , another 12 k is assured .
swathyd is offline   Reply With Quote
Old 16th February 2011, 11:42   #261
I have bought the 15" fiat alloys and might recieve it in the next 2 days.
I'm now deciding the tyres and I have 3 options in mind.
What do you people suggest?
195/60 R15
205/55 R15
205/60 R15
Also suggest me the brand and the best place for the deal.
Old 16th February 2011, 12:04   #262
Akshay1234's Avatar
Thanked: 7,241 Times
Stick to 195/60 R15 since the car isnt powerful enough to warrant 205s. With those you will probably see a drop in acceleration.
Old 16th February 2011, 14:31   #263
MCR
Thanked: 237 Times
195/60 R15
205/55 R15
205/60 R15
I would suggest 205/60 R15. Go for Yoko S drives. They are a bit noisier but have good life.
MCR is offline   Reply With Quote
Old 16th February 2011, 14:58   #264
Zenster's Avatar
Thanked: 94 Times
195/60 R15
205/55 R15
205/60 R15
Hey Hemanth, good on you mate! how much did u pay for the alloys ?
About the tyres, I'm sure the gurus will advise you appropriately. I would endorse akshay1234 as well. Beside not being very-powerful, the 195 size is standard on the EP variants and hence there will be no warranty issues incase there are any foreseen issues with the suspension and stuff...
BTW, you could ping Nikhilb for quick response. He is from bangalore too.
Zenster is offline   Reply With Quote
Old 16th February 2011, 15:11   #265
I will "probably" see a drop in acceleration. But how much is the key to my decision. My only worry is, will there be any problem if I put the 205/60R15 tyres onto the stock rims?
I sure like the wide fat look but my only worry is what I have stated above.
About the tyres, I'm sure the gurus will advise you appropriately. I would endorse akshay1234 as well. Beside not being very-powerful, the 195 size is standard on the EP variants and hence there will be warranty issues incase there are any foreseen issues with the suspension ans stuff...
This is one of the many advantages of being a TBHP member.
I bought these alloys from another fellow BHPian Raj_5004 who had put this in the classifieds section. We completed the deal for 21k for the 4 alloys. I wanted the Fiat ones and for a 2day old fiat alloys, this was a fair enough deal.
BTW, I have sent a PM to Nikhil already...awaiting his response.
Old 17th February 2011, 01:52   #266
Akshay1234's Avatar
With 195s it wont be too much but with 205s im sure it will be very noticeable. 195/60 r15 is the correct upsize and I suggest you stick to it.
Old 17th February 2011, 10:04   #267
Thankyou very much akshay for your suggestion...I'm now awaiting Nikhil's reply to the price and other details.
I'll anyway go to his "family shop" and check the tyres this weekend. After seeing the tyres physically, I can decide easily I believe.
For me, this is a Mind-over-Heart matter
Is there any BHPian who has put 205s on his/her punto who can give me the best feedback on the drop in acceleration???
Old 17th February 2011, 12:37   #268
Soccerfan's Avatar
Thanked: 56 Times
195/60 section tyre would be the best. I wouldnt recommend the 205s for Punto.
Soccerfan is offline   Reply With Quote
Old 17th February 2011, 13:52   #269
MCR
Thanked: 237 Times
Thankyou very much akshay for your suggestion. After seeing the tyres physically, I can decide easily I believe.
The contact area to the road surface increases with a 205/60 R15 tyre. This can be benefitial in increasing the grip levels. It also helps in improving the braking. However, with an increse in the rolling resistance, the power delivered by the road wheels and the FE will go down. By how much? well, it can range from 5%-10%.
Here are some calculations. May be this will be helpful in your selection.
Old 17th February 2011, 17:35   #270
WasavaTyres's Avatar
Thanked: 255 Times
Wink re: Fiat Punto : Tyre & wheel upgrade thread
I'm running my 90HP punto on 205/60/R15 Yokohama V550 Db Tyres. Didn't go into much of the intricacies of calculating drop in FE / Odo error as I wanted these tyres for increased grip and comfort levels.
Fiat Punto : Tyre & wheel upgrade thread-yoko-205-1.jpg
Fiat Punto : Tyre & wheel upgrade thread-yoko-205-3.jpg
WasavaTyres is offline   Reply With Quote
Fiat Linea : Tyre & wheel upgrade thread vancity Tyre & Alloy wheel Section 237 10th July 2018 16:26
Hyundai Grand i10 & Xcent : Tyre & wheel upgrade thread jkdas Tyre & Alloy wheel Section 18 8th July 2018 21:32
4th gen. Honda City : Tyre & wheel upgrade thread Screwdriva Tyre & Alloy wheel Section 350 9th May 2018 19:30
Fiat Palio : Tyre & wheel upgrade thread shahmotors Tyre & Alloy wheel Section 637 26th March 2017 12:56
