Old 31st May 2015, 08:23   #586
vibbs's Avatar
Thanked: 870 Times
Default Re: Fiat Punto : Tyre & wheel upgrade thread
Guys
Punto Dynamic Mjd. Running stock JK tyres tornado. Four tyres have worn off. One is reasonably fine. Total mileage has been 28k Kms.
I am surprised that JK tryes lasted only this long.
Now looking for change, I want suggestions on tyres that will improve the ride and have low noise. JK tyres were pretty bad on both counts and looking at their longevity, i hope to have a set that lasts atleast the next 40k Kms. The stock size is 165/80 R14. Should I Upgrade the size? I dont want to change the rims though.
vibbs is offline   Reply With Quote
Old 2nd June 2015, 10:37   #587
Aston Singh's Avatar
Thanked: 161 Times
Originally Posted by saurabh041086 View Post
Hi Guys, I bought a pre owned Punto MJD(Emotion Pack) with 43k on odo at that time. The owner before me changed the front two tyres with same GY GT3 at 40k kms. Now at 48k kms rear tyres are about to loose all the treads. Now, i am in a big confusion whether I can put current front tyres to rear and buy new pair of tyres for front. Can this be done with a different brand of tyres or i need to change all four tyres at this stage?
Hey Saurabh, I would say change all 4 and keep a spare from your current set. Tyres are a very important aspect when it comes to safety and comfort. New set with timely rotation and balancing/alignment will last you for a good 40k kms and it will also enhance the ride quality. Lot of brands in the market, do your research on the forum and feel free to post here if you have any questions
Aston Singh is offline   Reply With Quote
Old 2nd June 2015, 10:56   #588
ghodlur's Avatar
Thanked: 2,435 Times
Smile Re: Fiat Punto : Tyre & wheel upgrade thread
I can suggest the below options:
1. On 14" steel rim - Go for 185/70 size tyres. Highly recommended.
2. Buy OE 15" steel rim, and Go for 195/60 size tyres.
3. Upgrade to 15" Alloys (OE or any 98 PCD aftermarket alloy) - Go for 195/60 size tyres.
Hope this helps.
ghodlur is offline   (2) Thanks Reply With Quote
Old 2nd June 2015, 11:48   #589
Thanked: 32 Times
Thanks Aston. I will retain the 6k kms old GY Duraplus and replace the the worn out tyres with new pair of GY Duraplus. Their grip along with ABS has never made me feel nervous or scary on road. Many other tyres might be way more better than this though. Apart from high noise is there any other issue with GY Duraplus. I can live with high noise because most of the time i have trance on my ICE.
saurabh041086 is offline   Reply With Quote
Old 2nd June 2015, 20:32   #590
vibbs's Avatar
Thanked: 870 Times
Hope this helps.
Hi Ghodlur,
Thanks for the suggestions. I m not too keen towards Alloys.
Among your first two suggestions any significant advantages in upgrading the rims to 15 inchers?
Old 10th June 2015, 14:20   #591
sdp1975's Avatar
Thanked: 972 Times
The 195/60/15 ZLOs on my Punto have done 37 K now. They've served well, and they'll last for another 5-6K. If tyre life is the primary consideration , what options are available ? Should I look at the Turanza AR 20 ? Don't want to buy Michelins.
sdp1975 is offline   Reply With Quote
Old 19th August 2015, 12:15   #592
I was upgrading the tyres of my Punto Dynamic 1.3 to 185 70 R14. I'm confused between Apollo Acelere and Yoko A drive. I'm confused because my car will be parked in hot sun during the day as I do not have covered parking in office. So, I believe I need a tyre made of bit hard component to sustain the heat.
Kindly advice
sridharj is offline   Reply With Quote
Old 19th August 2015, 12:56   #593
nkrishnap's Avatar
Thanked: 4,460 Times
Originally Posted by sridharj View Post
Kindly advice
A Drives are no longer available. you could consider the below tyres (185/70 R14) in the below order (prices ascending). The Continental and Michelin are better than Yokos.
1. Yokohama Earth 1
2. Continental Comfort Contact - CC5
3. Michelin - XM2
nkrishnap is offline   Reply With Quote
Old 26th August 2015, 17:27   #594
Thanked: 100 Times
For 195 60 R 15, I was told only Apollo Alnacs are available. No more Aceleres. Not sure about 185 70 R14.
My take on Apollo Aceleres:
My Punto is currently running on Apollo Acelere (factory fit) with profile 195 60 R15 on factory alloys (mine is 90 HP emotion). The car is 1 year old and 38K kms run. The tyres will last for another 2K kms max.
I feel the tyres had worn out fast. I expected it to last atleast 50K kms considering my usage is mainly on highways and I do rotate the tyres every 10K Kms with alignment & balancing done every 5K kms.
Also, the tyre noise is on higher side beyond 20K kms.
@All -
I need your help to shortlist tyres for my Punto.
profile: 195/60/R15
usage pattern: 90% highways. 2-2.5K kms per month.
expectation: better ride comfort and should be silent.
budget: 6.5K per tyre (max)
I am planning to go for Michelin XM2 (safe bet as few of my friends are already having it on their cars) but would like to know:
  • how Yoko C drives, Pirelli, Continental fares compared to XM2?
  • is there any option better than XM2 available in market within my budget?
nfsfreak is offline   Reply With Quote
Old 26th August 2015, 18:54   #595
purohitanuj's Avatar
Thanked: 240 Times
Mine is running on 185/70 R14 and I am planning to up-size to 195/70 R14. I will get 7mm more GC with much more softer ride. She has clocked ~1 lac and I don't throw her around the corners like I did in past! Anyone tried this? I don't think it will foul with the wheel well as I travel alone 99.999%
P.S. 195/70 R14 is the size recommended for Qualis!
purohitanuj is offline   Reply With Quote
Old 23rd September 2015, 22:29   #596
Guys, Mine is running on 165/80 R14, I Tested Both JK & Goodyear Tyres, I ran almost 35K now on it and still 50% Threads available
I suggest Goodyear for better NVH & Life
If anybody Used Yoko C Drive Please share your experience, Sine I never tried
Santoshg is offline   Reply With Quote
Old 23rd September 2015, 22:33   #597
@ Karthik, Try Goodyear this time
Mine is 165/80 R14, and almost ran for 35K, and still 50% thread depth is available
If anybody used Yoko C Drive please share your Experience
Old 7th October 2015, 15:33   #598
bassman's Avatar
Originally Posted by mrohit17 View Post
Need help deciding between 195/60R15 and 185/65/R15.
Now my driving style is 50%city/highway and I have DieselTRONIC installed which I keep in P2 mode 80% of the times, I think this explains how the car is driven. But I drive safe.
OT: I am planning to put in either the RD or Pete in my Punto (Active, 2012 - 50K kms old). How is the RD? Would be great if you could provide a quick review / post a link to a review you might already have here. Apologies for going OT.
bassman is offline   Reply With Quote
Old 12th January 2016, 19:22   #599
hiren.mistry's Avatar
Thanked: 260 Times
Originally Posted by nfsfreak View Post
@All -
profile: 195/60/R15
Hello guys,
My 2015 Punto Emotion is due for as tire change. Which tyres did you go with?
I am thinking of getting Earth 1 in stock size (195/60 R15).
hiren.mistry is offline   Reply With Quote
Old 12th January 2016, 19:23   #600
Thanked: 100 Times
Originally Posted by hiren.mistry View Post
Hello guys,
I went for Michelin XM2. Happy with my decision so far (driven around 5000 kms).
nfsfreak is offline   (1) Thanks Reply With Quote
Fiat Linea : Tyre & wheel upgrade thread vancity Tyre & Alloy wheel Section 237 10th July 2018 16:26
Hyundai Grand i10 & Xcent : Tyre & wheel upgrade thread jkdas Tyre & Alloy wheel Section 18 8th July 2018 21:32
4th gen. Honda City : Tyre & wheel upgrade thread Screwdriva Tyre & Alloy wheel Section 350 9th May 2018 19:30
Fiat Palio : Tyre & wheel upgrade thread shahmotors Tyre & Alloy wheel Section 637 26th March 2017 12:56
